Fuel door clip
Old Dec 11, 2004 | 03:33 PM
acc3d's Avatar
Fuel door clip
Today while refueling, a small metal clip with plastic coating on one end flew off of the area where the gas door latches. I thought I'd put the clip in my cupholder and fix it at home, but after closing the fuel door it will no longer open. Can anyone take a photo of theirs so I can see how to snap ot back on? Guess I have to fix it before I run out of gas...
Thanks in advance!
Old Dec 11, 2004 | 04:43 PM
Go48's Avatar
Originally Posted by acc3d
Today while refueling, a small metal clip with plastic coating on one end flew off of the area where the gas door latches. I thought I'd put the clip in my cupholder and fix it at home, but after closing the fuel door it will no longer open. Can anyone take a photo of theirs so I can see how to snap ot back on? Guess I have to fix it before I run out of gas...Thanks in advance!
Here are a couple of pics. Hope you get the door open. The part you refer to is probably the little tab that applies a little outward spring on the door so that it will pop open when the open lever is pulled. My guess is that if you apply a little outward pressure on the door with a lever and have someone pull the open lever it will open. You might want to just take it to a dealer for warranty repair.
Attached Thumbnails Fuel door clip-gasfiller_1.jpg   Fuel door clip-gasfiller_2.jpg
Old Dec 13, 2004 | 01:57 PM
acc3d's Avatar
Thanks for the photos, but I can't actually see the clip I was mentioning...maybe if you took a shot of the fuel door from a top angle it would be visible.
Old Dec 13, 2004 | 02:17 PM
Go48's Avatar
The clip I believe you are referring to is located within the circle. Looking at the clip from the side it resembles a ladle and it has a plastic coating on it. I don't have a clue as to what holds the clip in place, so I'm not sure you can reinstall the clip yourself or if the entire assembly must be replaced. In the latter case, take it in for warranty replacement. Of course, if the clip is broken, you will definitely need to see your dealer.
Old Dec 13, 2004 | 04:57 PM
downshift's Avatar
<p><
Not sure if this helps, but this is the only diagram from the service manual:
Old Dec 13, 2004 | 05:19 PM
acc3d's Avatar
Thanks, I was able to snap it back into place today. I tweaked it a little bit so te door doesn't spring open as far, but at least it's functional. Thanks again for the photos & diagram. RX-8 Club is a great community!
And who knows how much the dealer would have charged me to fix that... :D
Old Dec 13, 2004 | 07:15 PM
jsh1120's Avatar
Inside Release?
Can't check my car at the moment, but the problem you cited reminded me that on my previous Volvo and current Saab there is an inside release for the fuel door in the trunk. (The purpose is obvious; if the remote mechanism breaks you can get the fuel door open, fill it up, and drive it to the dealer. )
Anyone know if the RX-8 has a similar feature?
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
czr
Sep 13, 2015 11:37 AM
