Canadian front Bumper
Old Dec 10, 2004 | 06:27 AM
SilverBullitt's Avatar
Question Canadian front Bumper
hi everyone.
I need to remove my front bumper, got the instructions but I have no idea
about Canadian model (part in front of bumder that spray water on lights)..
How do I disconnect that, don't want to brake anything.
Thank you!
Old Dec 10, 2004 | 12:39 PM
ZoomZoom's Avatar
Drive it like U stole it!
It's very simple... take your rx-8 to the nearest Mazda dealership... there's nothing to it!
Old Dec 10, 2004 | 12:54 PM
Very simple for you,... but not for me since my 8 is stored for winter... and
i rather do things myself....
Old Dec 10, 2004 | 01:07 PM
All you have to do to remove the headlight washer is to disconnect the electrical wire connector, and the supply hose. Both are by the passenger side headlight area. remove lower pan bolts, side marker lights, a few clips and bolts on the top....and it lifts right off slick as can be. Takes about half hour if you are careful
Old Dec 10, 2004 | 08:26 PM
BlueFrenzy's Avatar
Rotary Powered Decepticon
Exactly what dannobre said ... I found that I couldn't disconnect the supply hose because it started to leak wiper fluid despite clamping it ... so I left it connected to the RX8 and just had the entire bumper moved to the side of the car.
Are you doing the oil cooler screen and front air dam mod? Good idea!
Old Dec 10, 2004 | 09:38 PM
I plugged it with a bolt...1/4 inch I think. Worked great. Had the bumper off for three days, and drove to the body shop with it off. If you plan on moving the car.....zip tie the lower pan to the inner fender skirts, and tie up the wires for the corners, and the headlight motor. Then nothing will rub.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
paporx8
Nov 5, 2015 07:20 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
