caution to do it yourselfers
Old Dec 8, 2004 | 12:07 PM
bigblockbeater's Avatar
black RX-8 6 speed
the radio and a/c in this car suck! as you know they are one unit. do not do what i did....i ran wires for a bass system and connected a line adapter to the rear speaker wire in the dash. i used quick connect line jumpers so's not to cut the wire. my brother, an electrician who has over 5 years experience installing car audio, was there helping me. the next day after the install, before i even had the speaker box, the stereo and a/c went out! after a week of trying to find the problem i figured the stereo itself had gone out so i made an appointment with my local dealership to see what was wrong. they charged me $90 to tell me my stereo was broken and won't cover it under warranty! so i am out $90 and still no better off then i was. my suggestion would be, if you want something done to your stereo, pay a shop the $50 just incase this kind of thing happens. that way they can be held liable.
on another note, they are replacing my headlights under warranty.
Old Dec 8, 2004 | 12:08 PM
foxman's Avatar
Torque is Good
Why did it go out?
Old Dec 8, 2004 | 12:15 PM
black RX-8 6 speed
i still don't know what is wrong with the stereo and a/c. i do know they want to charge me $300 for a new one.
Old Dec 8, 2004 | 01:19 PM
CactusGeorge's Avatar
Bose HU Uses Differential Outputs
If you have the Bose system and tap into the harness wires that go the the amp, you need to be careful not to short the Negative signal wire(s) to ground, because this will trash an output IC...
Old Dec 8, 2004 | 03:42 PM
black RX-8 6 speed
no this is the basic stereo/cd. i wonder, could it be repaired?
Old Dec 8, 2004 | 04:13 PM
czr's Avatar
czr
RX8 RX8!
Post a wanted in the parts section for the stock non-bose hu, you might get one really cheap. I have a Bose one I'd sell ya cheap if you had bose.
Old Dec 8, 2004 | 04:20 PM
black RX-8 6 speed
good idea czr, thanks. you know what sucks, i have a killer pioneer premier hu in the drawer that i can't use.
Old Dec 8, 2004 | 05:35 PM
truemagellen's Avatar
Attracts tree branches
many have done it...stop scarrying people!
first off...a shop to do it for $50? anywork costs WAY more then that
DIY is the way to go...just be patient and prepared (and read the forums cause tapping the rear amp for bass is on here somewhere)
alsoyou can get a new HU for MUCH less then 300 (try rx8garage.net and talk to the owner thew who lives on this forum :p), second adding a bass system is easy as pie just tap the rear amp (located in the trunk...you don't even need to pull out the HU
you can use your Pioneer system, but if you have the BOSE you will need to replace all your speakers
if you do use the Pioneer system you just take the HU core out (it is small) and hide it where the huge OEM hu was...this way AC controls remain intact...then just hookup your whole system
Old Dec 8, 2004 | 06:05 PM
Southsider's Avatar
Chicago Southsider
I tapped both front and rear speaker levels with a PAC OEM-2 output converter and ran RCA's to the amp in the rear. No problems whatsoever(and I have 0 years experience as an electrician).
Old Dec 8, 2004 | 09:34 PM
haha :P good job
Old Dec 8, 2004 | 10:24 PM
black RX-8 6 speed
truemagellen, thanks for the advice. i still don't know what is wrong with the car. i don't think the mechanic knows either. they had the car for 3 hours and all they could tell me was the "aftermarket device to system caused radio unit failure." i installed a PAC brand 10:1 output adaptor model sni-15. i jumped it off the rear speaker wire just behind the harness. and that is all i did. i still don't see how that could cause the entire stereo and a/c to go out. anyway, truemagellen, could you tell me a little more about hooking up that pioneer unit or direct me to a thread that will?
Old Dec 9, 2004 | 02:18 AM
Squidward's Avatar
Bottom feeder
what happens if you put everything back exactly the way it was?
Old Dec 9, 2004 | 01:52 PM
black RX-8 6 speed
already removed the adapter and nothing
Old Dec 9, 2004 | 09:42 PM
mazradiodoc's Avatar
I AM SURE your HU is repairable. You could have your dealer do an out of warranty exchange or research the companies they use for said exchange and deal directly
Maybe Thew could help you?
Old Dec 10, 2004 | 10:39 PM
Kel Rx8's Avatar
if your not 1st your last
i currently have a 8" solar baric square and a kicker 150x2 in my winter car that
i want to try out in the rx8 but i will make sure to read on teh rear amp connection
thanks truemagellen
Old Dec 10, 2004 | 11:08 PM
thew's Avatar
Thews8
take it out and send it to me.. let me see if its toast or not..
you have nothing to loose now.. and i can save you some bucks
email me and well get it fixed
Old Dec 11, 2004 | 09:26 AM
MI_FamilyMan's Avatar
Sold on Rotaries!
If all else fails and you still want a stock Bose HU w/1 CD (never used), let me know...
Old Dec 11, 2004 | 05:44 PM
thew's Avatar
Thews8
Email me if its new and in box i will buy it..
Do you know the firmware ?
Old Dec 11, 2004 | 10:13 PM
XeRo's Avatar
Normality is Obscene
^Must have slept in a holiday inn express last night...:D..
sorry i had to do that...
Old Jan 16, 2005 | 08:06 AM
Sold on Rotaries!
Sorry, I'm such a clod... it's just the CD player itself... not the whole radio.
Pelleilee
Sep 29, 2019 10:07 AM
Brokegang
Jan 3, 2016 12:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
carid
Vendor Classifieds
Sep 10, 2015 09:26 AM
dafiltafish
Aug 21, 2015 06:56 PM
