lighted shift knob fuse
Old Dec 6, 2004 | 09:56 PM
snifferer's Avatar
snifferer
lighted shift **** fuse
I just got my lighted shift **** today. Biggest headache in the world. Copper wire broke at the base so I had to dissemble **** and sodder on new wires.
However, now that I have all the wires installed, the fuse keeps on busting. It uses a 1 amp fuse and I was unable to find any, so I tried 3 amps. However, it keeps on busting too.
Anybody have a similar problem or a solution? I think I'm gonna try to use a higher amp fuse, think that would work?
Old Dec 6, 2004 | 11:05 PM
RX Renesis's Avatar
when u sodder the new wires on did u accidently made the wires touching makeing a short?
Old Dec 6, 2004 | 11:33 PM
snifferer's Avatar
snifferer
ahh crap, the sodder was in one lump connecting the two wires. i separated the sodder but it seems like the LEDs aren't working anymore.
you think i shorted the circuit board?
Old Dec 6, 2004 | 11:35 PM
snifferer's Avatar
snifferer
i don't know if this is connected, but now my dashboard is not detecting that my headlights are on when they are... so the headlight light is not appearing and i am not able to illuminate the blue dimmer lights.
whats up with this????
Old Dec 7, 2004 | 12:53 AM
truemagellen's Avatar
Attracts tree branches
check the fuses pronto...you probably blew a few
your lighted shift **** is turned on by the headilght switch
Old Dec 7, 2004 | 12:54 AM
LEDs are fragile...you may have destroyed them too if not you can solder on some new high POWERED ones which is the good news...but it will be one hell of a job
Old Dec 7, 2004 | 02:00 AM
snifferer's Avatar
snifferer
any idea which fuse is the fuse for the illuminated dashboard? I looked at the fuse chart and wasn't able to determine which one it was.
Old Dec 19, 2004 | 10:26 AM
philodox's Avatar
Rangers Lead The Way!
I have the Mazda Illuminated Shift ****. The real one from Mazda, not a rip off.. It uses 10 amp fuses, not 1 or 3. Maybe you got a fake?
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
Vedivan1
Sep 20, 2015 04:39 PM
erikcamacho15
Sep 12, 2015 11:23 AM
