OIL Pressure wiring ?
Old Dec 6, 2004 | 07:48 AM
RX8 XTC's Avatar
Dose any one have the OIL Pressure wiring diagram ?? or any one know where i can find a place to see it ??
Old Dec 6, 2004 | 02:41 PM
Gord96BRG's Avatar
Why?
From what we know - oil pressure sending unit is input to the ECU. The ECU controls the dash displays, including gauges - if you want to convert your idiot gauge to a functioning gauge, you're going to have to reprogram the ECU.
Regards,
Gordon
Old Dec 6, 2004 | 07:11 PM
GiN's Avatar
GiN
ロンリードライバー
In addition..
As with many newer modern cars, the ECU communicates all the information on your dash via (2 wire per bus) high speed CAN protocol. Therefore you cannot do any sort of splicing in the gauge pod wire harness to isolate the oil pressure signal. However you MIGHT be able to break your gauge pod apart and physically replace the needle assembly with something else if you're creative and/or daring enough.
Otherwise, if you want to get a true oil psi signal you'll have to plumb a sensor into the port under your oil filter and run separate wiring to an external gauge.
Old Dec 6, 2004 | 10:31 PM
RX8 XTC's Avatar
so U are saying that if i wanted to use the aftermarket OIL Pressure gauge that i cant ?? well i was not asking about that all i asked for is the diagram and nothing els ?
Old Dec 6, 2004 | 11:56 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
As they mentioned- it's not going to be easy- we have a oil pressure switch (binary) instead of a working oil pressure sensor (analog)... so you'd have to replace that as well... but here's some schematics that might help if you want to tackle it...
Attached Thumbnails OIL Pressure wiring ?-opsensorschematic2.gif   OIL Pressure wiring ?-opsensorschematic.gif
Old Dec 7, 2004 | 04:55 AM
RX8 XTC's Avatar
thank you Man that's all i wanted to see :D i Might have something in Mind !!!
Old Dec 8, 2004 | 08:07 PM
Ninja's Avatar
Yeah! Zoom Zoom Zoomin!
I'm not an expert, but it appears to me that it should be doable without reprogramming the ECU.
Basic outline of steps looks like:
1) Short the PCM input 2E to ground to keep the PCM happy.
2) Replace the existing pressure switch with one that returns an analog signal.
3) Convert the analog switch signal to something the guage can represent.
4) Route the converted signal to the guage.
I guess the next question, is what type of signal does the gauge on the instrument cluster need compared to what sort of signal is generally reported by an analog pressure sensor.
Old Dec 9, 2004 | 08:31 AM
bureau13's Avatar
The problem is that the PCM doesn't interface to individual gauges....it interfaces via some kind of bus to the gauge cluster controller. God only knows how that controller, inside the cluster, controls the gauge. I was going to basically do this, until I figured out I would have to crack open the cluster to find out if it was even possible....not worth it to me, and the clusters are way too expensive to get one to play with.
I also wouldn't mess with the stock pressure switch-to-PCM section. Just put a real sender unit somewhere else and route that to the gauge (if/when that is figured out). I am pretty sure the PCM does more with the pressure switch signal than simply control the gauge.
jds
Old Dec 10, 2004 | 06:16 PM
Ninja's Avatar
jds
Well, that blows chunks over anything I can think of for an EASY oil pressure guage fix...
Old Dec 11, 2004 | 12:51 AM
bureau13's Avatar
I know. Stupid computers!
Old Dec 26, 2004 | 07:21 PM
slow_eddie's Avatar
pressure wiring
Anyone have access to the rest of the wiring diagrams. My local dealer can't get an OEM manual for at least 2 months, and they want $190US for it. Too bad , as my SC miata is ailing , and I want to see what in the gizzard of the 8.. I would never try to mod my previous two 7s, but my toying with the miata makes me more likely to do some stuff to the 8, once the warranty is up. Anyone know of a SC , or TC, or anyother mods easily done. Was going to install an air horn, but was surprised the 8 has a real horn, not a typical meep-meep Mazda bleeper. The only mod so far is getting new wheels, tires, and sensors to use in the winter.
slow_eddie
Old Dec 26, 2004 | 07:50 PM
snap-on's Avatar
9999-95-040G-04 2004 RX-8 Wiring Diagram Available RX-8 2004 2004 $50.00
This is the part number for the wiring diagrams.
The 50 bucks is cost..190 is alot of mark-up.
Damn stealerships.
Old Dec 26, 2004 | 07:57 PM
slow_eddie's Avatar
ok, the price is $50, but who, where, how to order such a thing? In Miatadom it is easier to locate such things, but those have been around since 89. TIA for the answer to a newbie on this site.
slow_eddie
Old Dec 26, 2004 | 08:06 PM
snap-on's Avatar
https://www.rx8club.com/rosenthal-mazda-68/
The $50 is dealer cost so expect a little mark-up.
This is the diags only..
mr. GrandGame
Sep 9, 2025 10:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
talonhart2
Aug 26, 2015 04:14 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
