Borla issues - defective 1st productions
Old Dec 1, 2004 | 06:30 PM
cgrx's Avatar
DRIVEN
I purchase a Borla exhaust months ago from the rx7/8store.com and could not resolve the rattle issue. I tied back the heat shield, etc. with no luck. I was IVO Borla down in Oxnard, CA and stopped by to have them check it out. Before they even put it on the lift the guy in the garage said it was an older one. The customer service rep I was dealing with was not aware of the rattle issue. He took down my name and address and they shipped me a new one. It arrived today. There is a very noticeable difference in the design. The canister is angled differently creating much more room between it and the heat shield.
Attached Thumbnails Borla issues - defective 1st productions-116_1650.jpg   Borla issues - defective 1st productions-116_1651.jpg   Borla issues - defective 1st productions-116_1652.jpg   Borla issues - defective 1st productions-116_1654.jpg
Old Dec 1, 2004 | 06:41 PM
brothervoodoo's Avatar
RainMan is Back
Good to know,
Out of all the exhausts, I prefer the sound and tips of the Borla the best.
Yet, I like the design (less bends) of some of the other exhaust manufacturers.
Old Dec 1, 2004 | 08:06 PM
Sociopath's Avatar
SocioPath
NICE! :D
Just curious, is it normal for the exhaust to turn "brown" after some period of usage?
Old Dec 1, 2004 | 08:10 PM
mysql101's Avatar
can you explain a bit more about how you got the updated borla? You spoke directly to borla about it?
Old Dec 1, 2004 | 08:23 PM
mysql101's Avatar
Originally Posted by Sociopath
NICE! :D
I just checked mine, all the pipes are brown, but the can and the exhaust tips are still bright chrome.
Old Dec 1, 2004 | 08:42 PM
cgrx's Avatar
DRIVEN
Yea, I think they are aware of the issue now. Are you sure you have the old one ?
Old Dec 1, 2004 | 08:47 PM
mysql101's Avatar
the tubing goes all the way up to the hanger on mine (looking at the second photo you posted), so I can only assume mine is the older version.
Old Dec 2, 2004 | 03:57 AM
cgrx's Avatar
DRIVEN
Does it rattle when you go over bump ? (after the DIY fix?) If so, then give them a call and see what happens...........
Old Dec 2, 2004 | 05:08 PM
mysql101's Avatar
I emailed them using their 'contact us' form on their website, but there hasn't been any reply so far.
Old Dec 2, 2004 | 07:36 PM
samsonite1's Avatar
uh.....
I doubt you will get one. I have e-mailed them several times that way over the years and I have always had to call
Old Dec 3, 2004 | 02:41 AM
cgrx's Avatar
DRIVEN
Is your canister angled down like this one ?
Old Dec 3, 2004 | 06:33 AM
mysql101's Avatar
can you explain a bit more? What should I be looking for in that picture?
Old Dec 3, 2004 | 02:50 PM
cgrx's Avatar
DRIVEN
Notice the brown mark at the far end of the heat shield ? That is where the canister would contact the heat shield when I hit bumps. Now it is about 3 inches away because they angled the canister down in the back. Before it was about MAYBE an inch away. See the weld line of the canister ?(from the post above) Before it was parallel to the ground
Old Dec 3, 2004 | 03:35 PM
adrian-1's Avatar
Ex- member.
I'll be giving them a call. Mine was bought back in Feb '04 and has the same brown marks on the heatshield and is very close. Rattles intermitenly.
Hopefully I sent in the warranty registration form cause I can't find my receipt.
Old Dec 3, 2004 | 07:25 PM
mysql101's Avatar
my borla has no such marks on the heat shield, but the unit is so high it is actually touching the heat shield on the top towards the rear of the car, and if i hit the heat shield, it bounces off the can. How does the new borla compare in position to the old one?
Old Dec 3, 2004 | 09:43 PM
cgrx's Avatar
DRIVEN
The canister was angled less, like the pic below
Old Dec 3, 2004 | 10:04 PM
mysql101's Avatar
oh! I think I understand now. My borla can is at a 180 degree angle - perfectly flat horizontally. Does that confirm that I have the old version?
Old Dec 4, 2004 | 12:31 AM
cgrx's Avatar
DRIVEN
I believe so
Is there that much of a gap from the canister to the heat shield when the car is cold ? If there is a noticeably smaller gap, then you have the old one.
Old Dec 4, 2004 | 12:36 AM
Dookie_Rx-8's Avatar
FourOneMuthaFcuknFive
to bad for borla everyones gonna be calling them now bout the "old version" and gonna want to "revised version"
i think i have the old one but i have no problems unless i dont notice,its to dark to check right now i check when i have time
Old Dec 4, 2004 | 12:45 AM
cgrx's Avatar
DRIVEN
if it doesn't rattle I wouldn't worry about it. Mine would rattle when going over the bumps in the road..like when entering schools zones, etc, etc.
Performance is the same....
Old Dec 4, 2004 | 08:44 AM
mysql101's Avatar
I believe so
On the rear part of the can, there is no space at all, mines actually touching the heat shield.
Old Dec 4, 2004 | 08:49 AM
cgrx's Avatar
DRIVEN
call them up for sure
I forgot how bad the damn thing smelled when I first got it. Its sickening
Old Dec 4, 2004 | 08:52 AM
cgrx's Avatar
DRIVEN
From GUy321's post
This is definitely an older one.
Old Dec 4, 2004 | 09:01 AM
mysql101's Avatar
lol, I drove mine about 100 feet, and stopped at a stop sign. There was so much white smoke coming from the back of the car I thought it was on fire!
Old Dec 4, 2004 | 09:53 AM
philodox's Avatar
Rangers Lead The Way!
Mine must be the old one as well. Mine rattles sometimes, maybe once or twice a week I notice it. Nothing big though. I'll probably just keep it as is.
