Ambient Temperature Reading..?
Old Nov 30, 2004 | 06:18 PM
rx8cited's Avatar
Senior Member
Originally Posted by djseto
Is the ambient temp. display showing the temperature outside or the temperatue inside the car?
outside
Old Nov 30, 2004 | 06:25 PM
Mikelikes2drive's Avatar
yah doesnt seem too accurate but whatevers. its a cool novelty
Old Nov 30, 2004 | 07:00 PM
StealthTL's Avatar
Metatron
Sensor......
I find it quite accurate, but the sensor is low at the front, so can read road temp, or radiator air temp if you aren't moving.
The pickup is in the front grille, low on the drivers side, looks like a black pen cap.
S
Old Nov 30, 2004 | 07:21 PM
truemagellen's Avatar
Attracts tree branches
actually it is quite accurate...BUT you need to give it a few minutes to move up and down to the correct temp...you will find that the reading when you turn on the car is what it was prior to turning off the car, this will change
Old Nov 30, 2004 | 07:24 PM
Nemesis8's Avatar
Bigus Rotus
I wonder if you could add different sensors all over the car and then switch between them? Now why would I want to do that... Just sounded kinda cool
Old Nov 30, 2004 | 07:42 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
Mines always off by at least 2 degrees. Its usually 2 degrees higher thanwhat it actually is outside
Old Dec 1, 2004 | 06:19 AM
superscout03's Avatar
I moved my sensor, and mounted it inside my airbox so i can monitor the air temp coming into the engine. I really didnt need to know the outside temp. It works really good.
Old Dec 1, 2004 | 06:33 AM
hotpot's Avatar
Where is the sensor? What does it look like?
Old Dec 1, 2004 | 07:47 AM
Gambit's Avatar
Screw gas mileage
It works well enough to give you an idea
Old Dec 1, 2004 | 10:29 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Mine is extremely accurate- on my 25mile drive to work I pass several banks with the temp on their sign, and mine usually matches theirs. I also noticed yesterday as I drove home it was indicating the weather perfectly - as the rain turned to snow it dropped from 38 to 34, and then then the snow stayed snow when it landed it had dropped to 32.
Old Jun 10, 2006 | 10:21 PM
tiggerlee's Avatar
May Cause Anal Leakage
RESURRECTION!!
When I pulled the car in the garage today the ambient temp read 100 degrees. I shut the car off and went on piddling around in the garage. Garage doesn't have A/C so I turned on two fans to circulate some air. About an hour and a half later I had to run to the store. Turned the car back on and it still read 100. I know it was not 100 in the garage. Didn't move the whole way to the store and back.
I guess I'm wondering if these sensors can go bad.... well of course they can tig! . But how would you know? Innacurate readings? No ambient temp reading at all? dramatic fluctuations? anyone know?
Old Jun 11, 2006 | 01:55 AM
WikkedOne's Avatar
Deals on wheels
The cold air thing is a good idea... maybe I'll move mine back so it can tell me the temp of my amp or something like that... or brakes... now we are talking... something actually useful!
Old Jun 11, 2006 | 08:16 AM
jstkilntim's Avatar
resU deretsigeR
I was thinking the same thing. Thanks for the resurrection Tig, never would have found this one.
Old Jun 12, 2006 | 12:36 PM
crisis's Avatar
A few weeks ago when it was in the 90's here in DC, my car was parked in the sun and when I got in the car the temp read 108 F. I'm glad I can now find this sensor and put it somewhere more useful.
Old Jun 12, 2006 | 12:46 PM
Tamas's Avatar
Registered Lunatic
Originally Posted by Cool-Blue-Dad
Glad you posted the location and description - I'll look for mine.
It is here.
Old Jun 12, 2006 | 12:49 PM
tiggerlee's Avatar
I think I'll call the dealership and see if they'll replace it under warranty. Cuz' I don't think mines accurate.
WranglerFan
Aug 21, 2022 01:29 PM
fistofmeat
Oct 7, 2016 12:15 PM
tommy26Germany
Sep 29, 2015 10:33 AM
yapakanichi
20
Sep 10, 2015 07:17 AM
