Starting a flooded RX-8
Old Nov 29, 2004 | 05:01 PM
joestewart's Avatar
Just spent the weekend with a flooded RX-8 that wouldn't start. Tried to start it 4 or 5 times. Got the updated procedures from the dealer (pedal to floor etc,) but still couldn't get it started. Have had the car to 1 1/2 years and never had starting problems before. Dealer suggested I bring it into their shop.
However, before I called the tow-truck I pulled out the fuel pump fuse (#22) and turned over the engine for 5 or 6 seconds twice. It started right away (until it ran out of fuel!) Replaced the fuse and got it finally started resulting in lots of smoke in the garage! I spoke to the RX-8 mechanic and he told me that that is exactly what they do at the shop. If necessary, they will also take out the spark plugs too.
Prior to it not starting I had run it without letting it warm up. I do have the latest flash.
For what its worth.
Joe
Old Nov 30, 2004 | 11:23 AM
MyRxBad's Avatar
Fb's rock!
http://www.finishlineperformance.com...1-04-1273d.pdf
Many procedures here for Crank no Start.
Old Nov 30, 2004 | 10:40 PM
Rotary Titus's Avatar
funny thing..... I dreamed I had flooded my 8 last night.... LOL :D
but thanks for the info!!
Old Dec 2, 2004 | 02:27 PM
apaul's Avatar
Always like this
Once was enough > last summer, 30 k outside of Timmins at that! ..story posted in August. After reading it, steve067 kindly pm'ed the fuse removal workaround. Keep it in my glovebox
Old Feb 19, 2008 | 06:49 PM
laulongfei's Avatar
laulongfei
My Wont start RX8
My 04 auto rx8 wont start, i thought its because its a flooded engine, so i tow to a shop, had new spark plug, starter is good, just wont start and technician dont know what cause it, possible engine failure? i have extend engine warranty, to 80,000 miles now my car is currently 73,000 miles, will they cover it if it the engine's problem? Can i get some adivce please, thanks
Old Feb 20, 2008 | 01:47 AM
TurboEight's Avatar
Booost.
Good luck, Have you checked the compression?
Old Feb 20, 2008 | 02:27 AM
HiTMaNN's Avatar
RX-8s Official Cool Guy
Does the engine turn?
Old Feb 20, 2008 | 09:38 AM
rotten42's Avatar
Mentalhealth is overrated
For what its worth.
Joe
I had my first flood about 2 months ago. I took the fuze out but it still took me about 25 mintues to get it going.
Old Feb 20, 2008 | 11:59 AM
delhi's Avatar
Grand Chancellor
I'm not familiar with this fuel pump fuse procedure. Is there a step by step guide? Or is it as easy as just removing the fuse. Crank the engine.... then put back the fuse?
Old Feb 20, 2008 | 08:09 PM
elysium19's Avatar
Yeah if someone can clarify, that'd be very helpful. The standard procedure, pedal to the floor, etc, isn't working.
I'm in the middle of dealing with this myself. My dad moved it and didn't know to let it warm up fully.
QUESTION: So I took the plugs out to verify they are wet and the thing is flooded. They are, and I'm going to let it sit with the plugs out overnight to dry out. However, I noticed that there is a fair bit of oil on the plugs. Exactly how much oil is injected into the engine, and is it possible that perhaps 60 seconds worth of cumulative cranking over the past few days (with no starting) can "flood" the engine with oil? Could this be a problem as well as the fuel flooding??
Old Mar 2, 2008 | 01:28 PM
CowTownWoody's Avatar
I have had 2 floods. The last one I guess I tried to start it too many times, because fuel got in the oil and I needed an oil change. Can somebody please PM me the fuse removal start procedure or post it here? the link in this thread is dead. Thx.
Old Oct 21, 2010 | 05:33 AM
lfraribl's Avatar
These are great tips. I tried them but unfortunately my battery wouldn’t last long enough to clear the flood before starting so had to resort to calling the AA (breakdown service in UK). The guy they sent round had an interesting technique which I’ve blogged about here:
http://spinage.me.uk/228/starting-mazda-rx-8-with-flooded-engine/
Old Oct 21, 2010 | 02:12 PM
bentiac's Avatar
Take off a spark plug and burn the fuel with a long neck lighter...?
Old Oct 24, 2010 | 11:01 AM
Delmeister's Avatar
You don't need to remove the fuse. Holding the accelerator to the floor cuts off the fuel flow but keeps the spark.
Old Oct 24, 2010 | 12:17 PM
dodgingwrenches's Avatar
So holding the accelerator to the floor, CUTS fuel? I was told to never start it using the gas pedal, since I'd just be dumping more fuel? So when exactly do you then hold it? Hold it down before cranking the engine and keep it held down?
Old Oct 24, 2010 | 01:09 PM
Redshift's Avatar
Spinning Dorito Junkie
Hold it to the floor before you turn the key and yes, keep it held down
It's throttle by wire, so you are essentially just telling the computer that you want to crank it over without injecting fuel.
Old Oct 24, 2010 | 01:59 PM
Delmeister's Avatar
Once you're back in business, put the gas pedal to the floor while cranking to prove to yourself that the car will not start.
Old Nov 9, 2010 | 06:18 AM
REV-illusions's Avatar
rotary ninja
uhhh... bump for what exactly?
Old May 13, 2013 | 11:46 AM
bgkast's Avatar
Hands off my wankel!
I stupidly flooded my car this morning. I tried starting it with the gas floored with no luck, and didn't have time to mess with it anymore. I was planning to pull the fuel pump fuse when I try starting it this evening.
Is there any concerns dumping all that raw fuel through the cats and damaging them? I seem to recall that the PO flooded it and had to replace the cats (along with the coils, plugs and wires) just before I got it. I am thinking about pulling the spark plugs along with the fuse to try to dry the engine out. Any reason not to?
Thank you.
Rx808BI
Aug 9, 2015 10:06 AM
Obivious
Jul 29, 2015 05:57 PM
harithac
Jul 25, 2015 04:21 PM
thedragonrotar
Jul 22, 2015 08:46 PM
JPCZONE
Jul 21, 2015 12:02 PM
