Rotary Performance Midpipe Problem
Old Nov 28, 2004 | 11:40 PM
Billy04RX8's Avatar
Talking Rotary Performance Midpipe Problem
Hey guyz i am lookin to get the Rotary performance midpipe from www. rx7.com. I have the Greddy Sp2 Cat-Back on my 8 right now.... My concerns are that on the website they sell the midpipe but they also sell the Rp Midpipe bolt & Gasket kit........and they also sell the 02 simulaoter.........now do i need all of these things for the midpipe to ft and work correclty without messing anything up or throwing a check engine light?????????and does this bolt right up to the Sp2 exhaust without a problem?
Old Nov 29, 2004 | 07:34 AM
paradigm's Avatar
Seen Your Member
you will need the bolt & gasket kit, but the o2 fooler doesn't work, so don't bother. I could never get my midpipe to fit with my borla exhaust so I had to have the ends cut off of both and a custom flange & gasket put on.
Old Nov 29, 2004 | 10:13 AM
Mr. Ed's rx-8's Avatar
no more 8
i have the o2 fooler and with a little hard wiring it worked. it is meant to trick you car into thinking what is read by the more forward o2 snsor is being read the same at the farther back o2 sensor. it will keep your CEL from staying on and eventually your car will lean back out. i'm still making some flames but thy have decreased alot since my ECU readjusted. now i just have a small leak around one of the gaskets but i will fix that as soon as its up on a lift...
Old Nov 29, 2004 | 10:43 AM
foxman's Avatar
Torque is Good
They are coming out with a high flow cat pipe with no resonator very soon. How did you know you have an exhaust leak around one of the gaskets and where is it? I am curious due to my own situation. Everytime I talk to one of the exhaust people they say you don't need the gasket package if your car is new but I am not convinced of this.
Old Nov 29, 2004 | 10:59 AM
Broke_Apex_Seal's Avatar
I have the MP and it fits great. RX7.com rocks!
Old Nov 29, 2004 | 12:43 PM
Billy04RX8's Avatar
so if i just buy the midpipe bolt and gasket kit ................will the check engine light come on stil?????????and if so what do i need to do to get it to turn off and have the car run correctly..........please explain thanks!
Old Nov 29, 2004 | 01:01 PM
Nemesis8's Avatar
Bigus Rotus
How is the sound level while cruing at 65 MPH in the car with the windows up??
Old Nov 29, 2004 | 01:03 PM
Nemesis8's Avatar
Bigus Rotus
I'm trying to get answers also, but they seem to not respond to e-mails. Maybe we should phone them... I have the Racing Beat exhaust, and was looking at their mid pipe as well. But I am worried about the noise level at highway speeds.
Old Nov 29, 2004 | 01:06 PM
Billy04RX8's Avatar
i have the greddy and it sounds great atr highway speeds.....not to loud....but i love the rotary sound and i deffinlatly want the midpipe..........i wanna shoot flames lol.........i need toi know this info before i buy it thoguh....
Old Nov 29, 2004 | 01:44 PM
Drift_Mode's Avatar
i was thinkin about gettin a greddy sp2 but didnt know how it sounded
Old Nov 29, 2004 | 01:45 PM
Drift_Mode's Avatar
any1 have a sound clip ?
Old Nov 29, 2004 | 02:07 PM
no more 8
i don't have any sound clips buti have the greddy cat back and b&b midpipe. it was very loud and raspy and souced like a CRX with a glass pack. so i had a high flow silencer welded on by the local muffler shop. it was only about $75 installed and now it sounds PERFECT!!! i will see if i can get some sound bits with my friends digicam.
as for the leak it is right at the header to mid-pipe flange. my Mazda dealership had it up on the lift doing the oil change and he showed me that. you can clearly see where its isn't sealed completely. you just have to be care full about tightening it due to the fact you might stress crack the welds.
as for the o2 sensor eliminator i recomend it so that your car will run more smoothly A/F wise. my car was running extremely rich before i got the eleiminator. i beleive jasperselectronics.com has the sim.
as for the backfiring...my car doesn't do it as bad. as soon as i fix that leak it should tone down even more. but i admit it is pretty bad *** when i am hitting the on ramp pushing hard in second...i shift at 9000rpm(with just a little quick rev while shifting) and BOOM!!! it sounds like a good backfire but people behind me see two nice big blue ***** of fire come shooting out!!! one night(on open highway) i shifted hard into 5th at around 9000 and we could see the oarange flames in my mirrors on the retaining wall...and it was loud and bright. i hit about 138mph then shut it down.
but there you have it.
Old Nov 29, 2004 | 02:25 PM
foxman's Avatar
Torque is Good
Any vibration or tingy sound between 4000 and 5000 RPM? How big is the leak gap?
Old Nov 30, 2004 | 03:48 AM
no more 8
gap is very thin but noticable...you can't really hear due to the loudness of the exhaust combo. i plan on just loosening them up and putting some form-a-seal gasket inthere to help seal it.
Old Nov 30, 2004 | 07:06 AM
I will not lie it is louder than stock but I like it. It is not brutal but it can be in the early morning for close by people.......
Old Nov 30, 2004 | 08:18 AM
foxman's Avatar
Torque is Good
Where the exhaust manifold meets the midpipe is a metal o-ring. This o-ring is intended as a one-time-use part, meaning that once you remove the pipe you should replace the ring. If you decide to save money, as I have, you can get some Permatex "Ultra Copper" high-temp RTV silicone. It is a sealer which is intended for exhaust system use and is O2 sensor-safe. Everytime I swap back and forth between my two pipes I put a decent dose of this silicone on the exhaust flange and have had no problem. Another thing that will help seal the exhaust system is to re-tighten the bolts while the pipe is warmed up.
Charles
Charles, I think you have the sr cat right? Do you have the resonator too? I reused the O ring you speak of and am not sure of the fitment and think it could be vibrating or rattling a bit.
Old Nov 30, 2004 | 09:43 AM
foxman's Avatar
Torque is Good
Charles
I am going to try this and redo the seals when I put on my Greddy cat back. Thanks for the tip!
Old Nov 30, 2004 | 11:15 AM
I re-used all the seals and mine did not leak. (I took mine off because of my shitty motor!)
xAgyex
Jun 3, 2026 03:47 PM
Sifu
Aug 30, 2015 10:51 PM
Jvswan
28
Jul 23, 2015 09:02 AM
netrovers
Jul 20, 2015 03:32 AM
AussieGray
Jul 16, 2015 03:58 AM
