Running Power Wires
Old Nov 26, 2004 | 02:33 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
Lightbulb Running Power Wires
What is the best way to route power wires to the trunk for an amp? I have searched the forum but have come up empty handed.
Old Nov 26, 2004 | 02:40 PM
philodox's Avatar
Rangers Lead The Way!
If you remove the rear driver side seat and the driver side plastic floor plate near the doors you can run the power wires all the way through the firewall without them being visiable. Took me about 30 minutes to run the wiring when I installed my Basslink setup. Sorry, but no pics...
Old Nov 26, 2004 | 03:51 PM
How many feet of wire did you need?
Old Nov 26, 2004 | 03:58 PM
philodox's Avatar
I ended up running 20 feet of 8 guage power cable from the trunk to the battery just so I had enough. I ended up cutting about 2 ft off each end. If you go to Circuit City and buy their amp instal kit (which I did) it has all you need. That amp install kit also has a 60amp fuse with it that is highly recommended you connect as close to the battery as possible. I ended up placing it about 8inches from the battery terminal. That way if the power cable ever deteriorates (sp?) the fuse will blow well before the break in the wire and stop any possiblility of a fire in your car. That install kit cost like $45 or so.
Old Nov 26, 2004 | 11:12 PM
bureau13's Avatar
Are you saying you went through the firewall on the driver's side? Where did you go through? There was a thread about where to drill through on the passenger side, behind the AC unit under the dash, and I wasn't looking foward to having to do that.
jds
Old Nov 26, 2004 | 11:51 PM
Tamas's Avatar
Registered Lunatic
Here...
No drilling needed.
© Bob The Eskimo
From the other side:
Old Nov 27, 2004 | 12:45 AM
bureau13's Avatar
Ahh, thank you very much! That is perfect...
jds
Old Nov 27, 2004 | 12:54 PM
So I started on the install last night and plan on finishing today. Wheers what I did. I removed the washer bottle and drilled a hole where the wire harness would pass through the firewall on the Euro models. I also used drilled holes through the battery box and used rubber grommets and split loom to protect the wire. I'm about half way done.
Attached Thumbnails Running Power Wires-img_1652.jpg   Running Power Wires-img_1667.jpg   Running Power Wires-img_1668.jpg   Running Power Wires-img_1653.jpg   Running Power Wires-img_1654.jpg
Old Nov 27, 2004 | 01:01 PM
MrWigggles's Avatar
Rotary, that is what we did with my RX-8 as well.
-Mr. Wigggles
Old Nov 27, 2004 | 01:03 PM
More pictures.
Attached Thumbnails Running Power Wires-img_1660.jpg   Running Power Wires-img_1650.jpg   Running Power Wires-img_1663.jpg
Old Nov 27, 2004 | 01:13 PM
philodox's Avatar
Originally Posted by Tamas
Here...
No drilling needed.
© Bob The Eskimo
Thats exactly how I ran the wire. Worked out well and looks very professional.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
uZu
Dec 30, 2015 12:35 PM
CMRine04
Jul 29, 2015 02:07 PM
stickmantijuana
Jul 19, 2015 10:33 AM
