weird idle issue - any suggestions
Old Nov 23, 2004 | 08:16 AM
silver1.3's Avatar
I've done a search and found seveal threads, but Im not sure whats happening to me is the same thing.
My car (before the M flash last week) idled smooth (for and RX8 that is). It had the constant vibration with only a little inconsistancy in it. Since the M flash the idle is more concsistant in the vibration. Today, same consistancy but every now and then - no particualr pattern - I get this - well it sounds like a missed cylinder or something. Hard to explain. Its like its idleing along: murr - murr - murr - murr -murr - poof - murr - murr - etc. Its the "poof" part. The car shakes slightly when this happens, but barely so.
any suggestions.
Old Nov 23, 2004 | 08:19 AM
slllygrl10's Avatar
EX-Member
Im taking it to mazda after thanksgiving.. Im hearing whining noise on idle as well
Old Nov 23, 2004 | 08:44 AM
TyrellCorpNexus8's Avatar
slllygrl10, I'm not so sure your thing is the same as his.
It sounds almost like a faint backfire that happens every few seconds but at irregular intervals. Open your driver-side door and you'll hear it more clearly. Better yet, get out of your car and bend down at the tailpipes and listen. That has been happening to EVERYONE'S car since the RX8 came out. It has been determined to be a completely normal characteristic of the engine. That is if we're talking about the same thing.
Are you SURE it wasn't already there before the M flash? I'm not sure that heart murmur "poof" thing is associated with the vibration.
Old Nov 23, 2004 | 09:04 AM
galleychief's Avatar
Unbalanced & Unmedicated
Mine idles the same way, periodic muffled backfire type sound, always has. . . The "M" flash significantly reduced the vibrations at idle though.
Old Nov 23, 2004 | 09:16 AM
Mugatu's Avatar
Even My Dog Searches
do you have an intake installed?
Old Nov 23, 2004 | 09:22 AM
Mugatu, I am greatly offended by the negative tone and the inappropriateness of your question.
Old Nov 23, 2004 | 09:29 AM
English's Avatar
So many roads to ride...
Easy, guys.......What kinda fuel ya' runnning there in that silver 1.3?
Old Nov 23, 2004 | 09:30 AM
RotaryNoob's Avatar
Hi
Old Nov 23, 2004 | 09:38 AM
Mugatu's Avatar
Originally Posted by RotaryNoob
He's just being an a$$ from another thread. Totally unrelated to this one.
Old Nov 23, 2004 | 09:39 AM
It's supposed to be a joke.
Old Nov 23, 2004 | 10:33 AM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
It was a joke people...LOL, don't read to much into it...LOL
Old Nov 23, 2004 | 10:38 AM
rx8cited's Avatar
Senior Member
It sure did not come across as one. Try adding a or next time.
Old Nov 23, 2004 | 10:41 AM
I don't have to if I don't want to. So there. Decoding emotional prosody will be up to you.
Old Nov 23, 2004 | 11:01 AM
rx8cited's Avatar
Senior Member
I think you have a point.
Old Nov 23, 2004 | 11:04 AM
Where is your smiley face since I can easily sense it?
Old Nov 23, 2004 | 11:05 AM
mysql101's Avatar
the idle you describe sounds normal. the new flash may have made it more pronunced, but it happens from time to time. aside from a higher idle, I don't think they can remove it completely from your car.
Old Nov 23, 2004 | 11:13 AM
magixpuma's Avatar
IF you installed a new oil filter thats high flow it gives you a rough idle
Old Nov 23, 2004 | 11:34 AM
Mugatu's Avatar
here. Now shut it.
Old Nov 23, 2004 | 12:09 PM
-=Zepplock=-'s Avatar
So which RPM is normal for idle.
I get a 7/8 of 1000rpm (when warmed up).
Is it ok?
Old Nov 23, 2004 | 12:12 PM
rx8cited's Avatar
Senior Member
here. Now shut it.
:D LMAO! Nice. :D
Old Nov 23, 2004 | 12:59 PM
mysql101's Avatar
Is it ok?
it varies for me. When starting up cold, it idles at 2,000 rpm and slowly drops to about 1,000.
Once fully warmed up, mine will idle around 850 rpm, up to around 950 rpm.
Old Nov 23, 2004 | 02:18 PM
Roaddemon's Avatar
Mine started doing the same thing right after the M flash. I took it back to the dealer. they called Mazda and they say it is the normal rotory idle I lhear, characteristic of the rotory engine. The M flash lowered the idle down to 8 or 700 rpm. If I gas it 1000- 1200 rpm the idle evens out. I don't notice it anymore.
Old Nov 23, 2004 | 03:24 PM
silver1.3's Avatar
Thanks for all the responses - smiley posts too - as long as its normal I wont lose any sleep over it.
greg
Old Nov 23, 2004 | 05:08 PM
Rennwagen's Avatar
Not new to this car thing
Is it ok?
So, um that would be a 700 to 800 rpm idle?
:D
Old Nov 23, 2004 | 06:54 PM
:D
1000*(7/8) = 875
