New brake pads at 10k miles?!?!
Old Nov 19, 2004 | 02:29 PM
04MazdaRX8's Avatar
I have approximately 10,667 miles on my car.. bought it back at February 17, 2004 and I already have to change the brake pads? It seems a little too soon to me but everytime I brake I feel a little grinding on my 2 front wheels. I called Mazda and they said that it is most likely the brake pads and that the 2 front ones wear out faster than the back ones. The price for 2 brake pads is $125 for a set of 2 installation not included.. Anyone else had to replace there brake pads too?
Old Nov 19, 2004 | 02:43 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
It's highly unlikely... I'm at 10k and still have most of my front pads left... and I drive pretty aggressively. I expect at least 25k, and hopefully 35k out of my brakes on the 8... they lasted quite a bit longer than that on my Miata, which was autocrossed often.
Old Nov 19, 2004 | 02:50 PM
Tayninh's Avatar
Normally a set of up front pads will go 24 to 30 K. 10 k is a bit too early. Something is not going on right with the calipers perhaps. Not sure. Look at your rotors. Do they have deep deep grooves on them and signs of burning like blue spots on them. Have your dealer check them out or have a brake place check them. Someone you and trust.
Old Nov 19, 2004 | 02:54 PM
04MazdaRX8's Avatar
If there is something wrong with my calipers do you think that Mazda will cover it under warranty? I dont drive it aggressively nor do I race it. I baby this car and was surprised that I had to change it so soon.
Old Nov 19, 2004 | 08:33 PM
verozoom's Avatar
Mazda will replace any RX-8's pads if you tell them that the brakes squeel. The new pads will also take care of the brake dust problem at the same time. We should have never payed for pads with only 10,000 miles. Go and get your money back!!
Old Nov 20, 2004 | 12:13 AM
irish8's Avatar
Get in ma belly!!
You are probably suffering the TSB squeeling issue w/ the standard brake pads. As stated earlier....take it to your dealer and complain of squeeling, they will then replace under warranty with new pads. The bonus...less brake dust!!!
- Irish
Old Nov 20, 2004 | 12:53 AM
EatMyBanana's Avatar
took mine in several weeks ago , brakes where squeeling bad. Have 7500 miles . told them about TBS and they replaced them , no questions ask. Since i have had this done ,the brake dust is WAY down but , I have a burning smell now that is very stronge. The service guy told me thay not only changed the pads but had to shave something down? . Anyone thats had this TSB done ,what has been your experince?
Old Nov 20, 2004 | 04:03 AM
G8rboy's Avatar
The key here is if they really are squealing. Lie if you want, but I'll bet that my original pads have better stopping distance than the new ones they came up with for people that complained about noisy brakes. If you really think that some dust is more important than stopping your car, then by all means go tell the dealer.
I guess this is all about priorities...
Old Nov 20, 2004 | 04:34 AM
RXE16T's Avatar
'RX-EIGHT'
Brake pads?
That's nothing, there's a guy on this forum that had warped rotors after the same mileage as you.
Needless to say, Mazda replaced them under warranty due to a fault with them.
Old Nov 20, 2004 | 06:38 PM
DOMINION's Avatar
I don't buy Kool-Aid
^^I had warped rotors and needed new brake pads on all 4 wheels.
Old Nov 20, 2004 | 10:31 PM
r8ped8's Avatar
who uses brakes anyway.......................
Old Nov 20, 2004 | 11:23 PM
takahashi's Avatar
Originally Posted by nojooc
Brake pads?
I am going to chew them up and change to a grooved rotor.
Like in Autoexe...
I think our rotor will go much faster than the brake pad ever will :o
Old Nov 21, 2004 | 03:14 AM
truemagellen's Avatar
Attracts tree branches
do you have an AUTO??? Those with the Auto will run their breaks down I'm just guessing here, about 10 times as fast as the Manual owners...no I'm not bashing you
but seriously the only time I ever use the breaks is the final 5-20ft of a stop...whenever I need to slow down I only downshift
there is one exception to this, DSC TCS...will break for you when you are loosing traction to certain wheels...this is a factor that is hard to quantify but will similarily affect the AUTO and MANUAL owners...maybe alittle more with the Manual owners since it runs a much higher RPM bandwidth
I like this quote :
ktec
Jun 26, 2021 10:18 AM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
PotatoCannon
Sep 6, 2015 11:48 AM
talonhart2
Aug 26, 2015 04:14 PM
cschoeps
Aug 6, 2015 12:44 PM
