MDRX8
11-16-2004, 12:46 PM
Where is the intake temp sensor module located at?
View Full Version : Where is the intake temp sensor module MDRX8 11-16-2004, 12:46 PM Where is the intake temp sensor module located at? Thanks Soundave 11-16-2004, 01:08 PM Awww...don't tell me you bought one of those chips off eBay for $5 that modifies your fuel/air ratio. :) MDRX8 11-17-2004, 11:36 AM Anybody please respond Thanks RXE16T 11-17-2004, 11:45 AM I believe it's part of the MAF sensor. G8rboy 11-17-2004, 12:02 PM I believe it's part of the MAF sensor. Correct-it's the brown tear-drop shaped sensor on the right in this pic: http://www.rx8club.com/attachment.php?attachmentid=20451 RXE16T 11-17-2004, 12:04 PM Correct-it's the brown tear-drop shaped sensor on the right in this pic: http://www.rx8club.com/attachment.php?attachmentid=20451 Thought so..... wasn't 100% certain though. Thanks for clarifying. conmeng 11-17-2004, 12:29 PM how do you hook up that cheap chip from ebay to your maf???? RXE16T 11-17-2004, 12:35 PM What cheap eBay chip? G8rboy 11-17-2004, 12:54 PM how do you hook up that cheap chip from ebay to your maf???? Not sure which wires you would tap into, but it's irrelevant- the 8's ECU can't be tricked by falsifying the MAF or IAT input signals. zevans 11-17-2004, 01:42 PM Indeed it can't, which is why I made a complaint to eBay. My eBay favourite search no longer shows all those +++++20hp cheap mod annoying items. :D Anybody got a CANScan or similar can tell us what the intake temps run at, just out of interest? G8rboy 11-17-2004, 02:24 PM Indeed it can't, which is why I made a complaint to eBay. My eBay favourite search no longer shows all those +++++20hp cheap mod annoying items. :D Anybody got a CANScan or similar can tell us what the intake temps run at, just out of interest? I can log some readings... I'm planning on doing some intake mods this weekend and want to baseline some data with it stock first (intake temp, airflow, and speed/RPM with acceleration over time) today or tomorrow. demonfire 11-17-2004, 02:26 PM intake temperature should be fairly close to ambient at speed unless you have a turbo / supercharger in the car. sco 11-21-2004, 06:43 AM Last time I did a good run, IAT was about 6 degrees C higher than ambient as reported by the ambient air sensor in the '8... however this was only one run, but it was a decent one (around 100km/h for 20 minutes) |
