Think this might fix the fogged tail light issue?
Old Nov 12, 2004 | 08:37 PM
dkelly3854's Avatar
Hey all,
I know a bunch of us, including me, have been experiencing some issues with fogging tail lights.
I searched the internet for solutions to the problem and I found that people with other cars drilled 1-2 very small holes in their tail lights, which allowed the fog to vent and solved the problem.
Does anyone think this might work or has anyone tried it?
Old Nov 12, 2004 | 08:46 PM
Racer X-8's Avatar
Coming thru in waves...
How about a visit to your local Mazda service guy? This must be a defect which must be fixed under warranty. No doubt. Why mess with it?
Old Nov 12, 2004 | 08:52 PM
wndotinter's Avatar
tint-vinyl-clearbra man
I took my problem taillight off and installed some foam weatherstip sealer around the outer edge of the opening where the inside of the light meets the body. Haven't had any moisture buildup since.
Old Nov 12, 2004 | 08:53 PM
djkrys's Avatar
had same problem..took to dealer..problem is from when they prep the car..there is a thread on it..if they use alcohol to remove the glue it will cause cracks in the lights and it will let in moisture..dealer will replace under warranty
Old Nov 12, 2004 | 08:57 PM
RXE16T's Avatar
'RX-EIGHT'
Definitely don't do this under any circumstances..... you're promoting the opportunity for more moisture to enter the assembly through these new holes.
Dealer should cover it under warranty, let them deal with it.
Old Nov 13, 2004 | 01:26 AM
Wankeler's Avatar
zoom freaking zoom
Yeppers warranty it (them). I had the left one fog up and collect about 1/2" worth of water before I had the dealer replace it, 8 days later the other side showed signs of ondensation and they replaced it under warranty too. Put that drill down! Make Mazda replace those!
Old Nov 13, 2004 | 03:44 AM
hotpot's Avatar
nojooc is right. Drilling holes will let more water inside the lens.
I also occasionally find condensation inside my LHS taillight assembly. None so in the RHS one, but there is a very tiny bug in there, about 1 mm big. Don't know how it got inside. I reckon it must have got inside at the factory assembly line.
Old Nov 13, 2004 | 09:55 AM
irish8's Avatar
Get in ma belly!!
Don't be crazy!! Take it to your dealer and have it fixed/replaced under warranty.
- Irish
Old Nov 14, 2004 | 12:32 AM
Megatron_98's Avatar
Very true, I have had this problem a few times, after my car was hit and i had almost a new rear end put on the right side light was broken by the body shop so they repalced it bu the one that was destroyed in the crash. came in and after a wash it fogged up too. So well when I had them replace the one they broke, they ordered another one for the left side that was deffective from mazda and let me know that any more problems and mazda would take care of it.
Old Nov 14, 2004 | 06:04 AM
DOMINION's Avatar
I don't buy Kool-Aid
I dont get
fogging tail lights
. But I once had fogged head lights.
Old Nov 14, 2004 | 06:09 AM
Genesis's Avatar
Driving Me Crazy
Fog-ged about it, take it to the dealer.
Old Nov 14, 2004 | 09:05 AM
quack_p's Avatar
Giant Space Hamster
And the cheesy pun award for the day goes to...
Old Nov 14, 2004 | 09:21 AM
valpac's Avatar
Ahead of its time
Check this service bulletin out..
http://www.finishlineperformance.com...09-021-04.html
small cracks will cause fogging
Old Nov 14, 2004 | 05:41 PM
DOMINION's Avatar
Wink
- Irish
Listen to the man!!!
Old Nov 14, 2004 | 05:48 PM
Genesis's Avatar
Driving Me Crazy
Well thank you....hehe :D
Old Aug 18, 2005 | 08:02 PM
Katchoo's Avatar
Dealer replaced my taillight today due to moisture (car wash I think)...no questions asked! Amazing!
Old Jul 7, 2010 | 04:15 AM
IndoRx8's Avatar
Red face
Can anyone post some links of recommended gasket to fix this problem? Sorry I am new, but gasket is a black rubber part on the back side of tail lights rite?
Old Jul 7, 2010 | 08:50 AM
Roaddemon's Avatar
I have an 04 and my tail light fogged 1 year after the bumper to bumper warranty expired. There was an obvious leak because the tailight had about an of inch of water in the corner from condensation. I removed the tail light and drilled a very small hole at an angle lowest point into the pocket of water. It drained and then I put a bead of clear silicon seal around the lense seam to the base. No more condensation. No more water in lense. Like new again. If you still have warranty let the dealer replace them. It's easier.
Old Jul 7, 2010 | 10:14 AM
ken-x8's Avatar
The latest TSB on this says that water in the taillight is normal, no need to replace anything. I presume this means they're running low on replacement units.
Indo - you can get gaskets from finishlineperformance.com . You can also look up the TSBs there. The gaskets are not cheap. Think about doing what Roaddemon did, or poke around here for other people's home brew fixes.
The only time I had a problem with water in a taillight was on my daughter's Honda Accord. I just drilled a drain hole.
Ken
Old Jul 7, 2010 | 10:51 AM
Cf05's Avatar
Not Faster Thn Ryans Spd3
I replaced three gaskets and the water would stop coming in for a while but it always came back eventually.. Now it was my drivers side tailight that would always leak... I found one day while it was raining the source of the water was the gromet above the tailight in between the body panel and where trunk sits was letting water in through the back of the light. Bought some silicone and put it around the gromet about 5 months ago no condensation or anything since problem solved I can try and post pictures later if necessary
Old Jul 7, 2010 | 11:27 AM
Good job searching. I had mine replaced twice on each side. The upgraded gasket is BS just like the updated visor. Just get some black RTV silicone and cover the oem gasket with it (be generous). You should not have a problem ever again.
Old Jul 7, 2010 | 08:43 PM
SayNoToPistons's Avatar
Wheels, not rims!!
Holy thread resurrection batman. I did black RTV silicone at first on all edges. It worked quite well but it wasn't perfect. I ended up using thin insulation foam with the sticky backside to make a tighter seal between the gasket and the body panels. It can now go through hurricanes and tsunamis.
Old Nov 25, 2012 | 08:37 AM
Marcojono's Avatar
Leaky Lights
Just sorted my leaky lights.
Nothing to do with gaskets, the plastic join between the back of the light and the actual lenses is where my water was getting in. Used a sealant on the join, and so far no more leaks.
Touch Wood....
Old Nov 26, 2012 | 11:26 PM
JamesD31's Avatar
Fogging or water? What I did to solve my "water" in the taillight issue is take the taillights off yourself, buy some cheep $5 weatherstripping **** (one sided sticky, foam looking stuff) and then just follow the "outline" that will be there to where the gasket touches the frame, it will be like a worn out part of the gasket - no problems since.
Old Nov 27, 2012 | 06:35 AM
HiFlite999's Avatar
This works:
Tail Light Gasket Repair Kit
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
