Does a lightweight flywheel void the warranty?
Old Oct 29, 2004 | 07:31 PM
Nigandahu's Avatar
Silent Assasin
Well does it? Non Mazdaspped, not installed by dealer?
Old Oct 29, 2004 | 07:39 PM
Nemesis8's Avatar
Bigus Rotus
Only if it comes loose and flies out of your car and cuts off someones head off!
Sorry - had to say that. No it will not void your warranty. Go here and read up: http://www.sema.org/main/semaorghome.aspx?ID=8124
Old Oct 29, 2004 | 07:57 PM
thew's Avatar
Thews8
hehe good answer..
Old Oct 29, 2004 | 09:24 PM
Nigandahu's Avatar
Silent Assasin
Well how much does it cost to get one installed? What kind of shop is reccomended, just a normal auto body shop?
Old Oct 29, 2004 | 09:25 PM
thew's Avatar
Thews8
a good shop.. your Mazda dealer can do it.. but i would go to a good Clutch and break guy. its an easy installl..
Old Oct 29, 2004 | 09:54 PM
cortc's Avatar
It is not that simple, SEMA is interested in supporting it's members and having you buy it's members parts...
Using a light weight flywheel other than an original or approved one by Mazda will void your powertrain warranty... Any failure to the transmission or engine could be associated with the flywheel/counter balance...
I have seen several warranty repairs declined at our dealerships due to after market clutches and flywheels with engine and transmission failures...
Old Oct 29, 2004 | 10:34 PM
Nemesis8's Avatar
Bigus Rotus
YIKES! Then I better buy the MS wheel - thanks
cortc - what about your lightweight pulleys then, will they lead to trouble for me if I install them?
duworm
Oct 1, 2015 04:57 PM
Hunterkelley24
Oct 1, 2015 09:11 AM
XianUnix
Sep 29, 2015 03:48 PM
