AIR bag help PLEASE QUICK!!
Old Oct 26, 2004 | 04:23 AM
RX8 XTC's Avatar
Question AIR bag help PLEASE QUICK!!
well i just installed new leather rx8 OEM seats and after i did all that the air bag lights kept flashing in a strange order, it flashes 2 times then shuts off after it did it 3 times (( Flashing 6 times in total )) it stayed solid and every time i start the car it will do it again then will stop and stay Solid ?? any one knows what's going on ?? or did i do any thing wrong ?
Old Oct 26, 2004 | 05:10 AM
RXE16T's Avatar
'RX-EIGHT'
Did you disconnect the battery?
Old Oct 26, 2004 | 05:14 AM
Rasputin's Avatar
There are connectors under the seats. Are they connected? One of them might be coming from a presence detector for the passenger air-bag.
Old Oct 26, 2004 | 10:59 AM
Slims8's Avatar
Piston Traitor
LOL... from reading the title I had the feeling you were trapped behind the steering wheel asking your wife to Post a call for help.
Seriously, the connectors under your seat should be the only problem, unless you did something besides the seat change.
Old Oct 26, 2004 | 03:43 PM
titaniumgrey's Avatar
18 year old speed freak
hmmmz .,.. maybe you bought seats without air bags ?
Old Oct 26, 2004 | 04:35 PM
TheDosDog's Avatar
Recovered Modaholic
It is flashing a code that tells you which airbag is not working. Please verify the flash sequence and someone with access to a manual can tell you what's wrong.
Old Oct 26, 2004 | 08:49 PM
RX8 XTC's Avatar
connectors all pluged in because i was testing the seats if they Were heating or not.
Here is the flash sequence thier is 2 Secends Puse in between eatch Flash Number (( 2 flashes )) 2 second Puse (( 3 flahes )) 2 second puse (( 2 Flashes )) 2 second puse (( 3 flashes )) 2 second puse (( 2 flashes )) 2 second puse (( 3 flashes )) 2 second puse (( 2 flashes )) 2 second puse (( 3 flashes )) 2 second puse (( 2 flashes )) 2 second puse (( 3 flashes )) 2 second puse and then Solied Light air bag stayes on ,
that Means it flashed 10 times in total (( 2 flashs 5 times )) (( 3 flashes 5 times ))
Old Oct 26, 2004 | 09:00 PM
TheDosDog's Avatar
Recovered Modaholic
That code is for passenger-side side air bag.
Code definition:
Passenger-side side air bag module circuit short to power supply.
Passenger-side side air bag module circuit short to body ground.
Passenger-side side air bag module circuit resistance high.
Passenger-side side air bag module circuit resistance low.
I would R&R the passenger seat and triple check the connections.
Old Oct 27, 2004 | 07:44 AM
RX8 XTC's Avatar
Crap !!! so i guess their is NO air bag in their after all huh ?? would i be Abel to put one in their if its not their ??
Old Oct 27, 2004 | 08:29 AM
Slims8's Avatar
Piston Traitor
Um... probably not preferred. The best thing to do (if you wanted that air bag) is to find a seat that has an airbag in it. If that isn't possible, you will have to find a way to make the sensor think there is... I'll look at the wiring and let you know what I find.
Old Oct 27, 2004 | 10:15 AM
snap-on's Avatar
Look on the side bolster of the seat..If there is a bag in there it will say "SRS Airbag" on the plastic piece.
Old Oct 27, 2004 | 04:51 PM
RX8 XTC's Avatar
well yeah it dose say thier is an SRS airbag on the plastic thing Now my guess is thier isent one thier so i might just take the Air bags out of the old seats and put em on the New one's or is that goning to be hard to do ??
Old Oct 27, 2004 | 05:17 PM
snap-on's Avatar
Ok..
There are two connectors per seat..One is white for the basic crap like heaters.
The other is Yellow..all the Yellow connectors are dedicated SAS system connectors.
Check and see if one yellow per seat is plugged in. They are kind of hard to snap together.
Good luck
Old Oct 27, 2004 | 05:30 PM
Rotary Titus's Avatar
ditch the seats all together since there's no airbags anyway and get a mazdaspeed one :p
but hmmm why wouldn't there be airbags inside? Unless they deployed? Did you get the seats from a wrecked 8? Careful if you're gonna move the airbags from your old seats to new one cause you don't want to make any mistakes
Old Oct 27, 2004 | 05:56 PM
snap-on's Avatar
I doubt they are deployed because there would be a big hole in the seat.
Old Oct 27, 2004 | 06:04 PM
slllygrl10's Avatar
EX-Member
LOL this is funny thread sorry but making me laugh
Old Oct 27, 2004 | 09:58 PM
i win
Old Oct 27, 2004 | 10:05 PM
snap-on's Avatar
But he has air bag seats.
I think thats what he meant..
Old Oct 27, 2004 | 10:18 PM
RX8 XTC's Avatar
i do have extra air bags seats its just i thought it had them already or they did not go off but looks like they have being taken out since i just opened them and their was nothing in their its only the passenger air bag is missing ill just pull it out of the other seats and problem solved :-D
Snap-on ur the man you know what am talking about LOL and some other's that know that too thanks alot for ur help guy's HOP the air bags dont blow on me LOL
Old Oct 27, 2004 | 10:19 PM
hold on why do you want them anyways? I was in a pretty bad crash before ... they didn't inflate .... the front and front passenger were the only ones that inflated ... this was a side'ish impact too ..
Old Oct 27, 2004 | 10:20 PM
RX8 XTC's Avatar
DO you think you can come and fix the Problem for me ?? LOL :p
Old Oct 27, 2004 | 10:24 PM
RX8 XTC's Avatar
the air Bags will not inflate if it was not hit on one of the DOORS i think the censor are seat between the front door and the rear door their for it dose not trigger them to go off ..well that's what i think it dose
The reason i want them i want to be safe about people who are riding with me + if i did get in to an accident and they found out the air bag was removed and it has its original seats it wont be easy Ex planing why it didn't go off.
Old Oct 27, 2004 | 10:25 PM
cgrx's Avatar
DRIVEN
what ?
Old Oct 27, 2004 | 10:35 PM
snap-on's Avatar
[QUOTE=cgrx]what ?[/QUOTE
LOL
Guys these air bags are not toys..they will explode with DYNAMIC FORCE..
Dealers have the tools you need to remove and install them safely.
Dealers are ask to deploy the bag if they set a code..They explode with the force of a shotgun..they will fly 50 feet in the air if not restrained.
If you insist on doing this yourself..unhook the battery and discharge the voltage by leaving the battery unhooked for at least 5 mins..
Old Oct 27, 2004 | 10:50 PM
Mazda Monkey's Avatar
Oh my!
