View Full Version : Will the automatic RX-8 ever see 250HP?
johnsocal 05-04-2003, 01:21 AM Im wondering if the 2005 version of the RX8 with an automatic tranny might see 250 HP and maybe a more efficient CVT-like tranny to distribute power better then a traditional slush-box. I would be sad to see a Neon SRT kill a RX8 at a stoplight drag.
note: I know if one wants real performance they should stay with a manual but one cant deny the market for more powerful engines and better automatic trannies to really help sell the RX8 in high numbers and make it profitable for Mazda to make it.
Hercules 05-04-2003, 01:23 AM If one wants real performance they should pay attention to numbers other than the straight line ones... *sigh*
I think that if you want a drag racer, or a car that can win on a strip... then you are lookin at the wrong car. And that's echoed in a lot of posts on this forum.
Take a search first and see what this car is about, then decide if it's for you.
Yup If you want a car to drag the RX-8 ain't it. Look for a car with alot of torque.
johnsocal 05-04-2003, 04:03 PM Hey guys thanks for pointing out the obvious. I know that the RX8 is a well rounded great handling sportcars and it isnt a 1/4 mile dragracing musclecar.
Does anyone if its Mazda automatic tranny design is the reason that forces them to cut the HP down on the engine and is there any hope they might increase the HP in the future?
Hercules 05-04-2003, 04:04 PM Originally posted by johnsocal
Hey guys thanks for pointing out the obvious. I know that the RX8 is a well rounded great handling sportcars and it isnt a 1/4 dragracing musclecar.
Does anyone if its Mazda automatic tranny design is the reason that forces them to cut the HP down on the engine and is there any hope they might increase the HP in the future? Yes it is, because maximum horsepower comes at 8500 RPMs, a rate that torque converters find hard to adapt to and thus unless you want a really expensive car, will have to be detuned.
SMG type of a transmission would also work for the RX-8 but then you're talking about even more money than the manual costs... and the idea with this car is to keep it reasonably affordable.
Skyline Maniac 05-04-2003, 04:48 PM I recently read a Japanese magazine, which stated the automatic version of the RX8 actually has better torque response than the manual tranny version. According to the article, more restrictive intake manifold improves torque, which is essential for the automatic transmission. I am not sure if Renesis has variable air intake system, but their explaination seems to make sense. I seriously doubt Mazda decreased power on the automatic model because they couldn't build a tranny strong enough to take the added power.
cueball 05-04-2003, 05:05 PM Yes they would. When they attempted to hook a auto up to a full power car, they kept blowing the torque converter. Why else would they do that?
Sputnik 05-04-2003, 08:16 PM Originally posted by Skyline Maniac
...I seriously doubt Mazda decreased power on the automatic model because they couldn't build a tranny strong enough to take the added power. It wasn't because they couldn't, it was because they were not going to spend money developing an auto that could handle the revs.
---jps
boowana 05-04-2003, 08:28 PM I can't say for certain but I had heard from a very good source that there will ultimately be a "sequential 6-speed transmission available that will handle the RPMs of the Renisis engine. My guess would be to loook for it in the Mazdaspeed veriosn which is probably 24 months or more out into the futureafter deliveries of cars start here. The earliest then would probably be July, 2005.
Gord96BRG 05-04-2003, 10:35 PM Originally posted by Skyline Maniac
They didn't decrease the power of the engine - they decreased the rev limit. The auto trans can't handle 9000 rpm, the problem is revs not power. 210 hp is what the engine makes at the transmission's rev limit of 7 thousand something rpm. There's no easy way to make 40 extra hp at 7000 rpm - so NO, there's no way the current 4 speed auto will get a 250 HP engine.
Further to Boowana's prediction - along with the 6 speed SMT for a 2006 model, I've already predicted that Mazda will have a 5 speed auto trans in the 2006 RX-8 (in a separate recent RX-8 auto thread, I bet Sputnik $20 on this ;) ). If someone wants a better auto trans RX-8, they really should wait a year or two.
Regards,
Gordon
rototlewski 05-05-2003, 08:32 AM hey I know some of you guys have seen the press kit! its not just the rev limiter its the intake ports are timed slightly different plus the auto doesn't have the aux 5 and 6 ports plus it doesn't have the aux intake track that opens at 7250 or around there.
I haven't looked at the press kit in like 4 or 5 months but im sure thats why the power is lower, the reason i know why they are not there is because of the auto but because of that you couldn't just replace the TC and get 250 hp you'd have to replace the entire drivetrain
wakeech 05-05-2003, 10:51 AM Originally posted by Skyline Maniac
this is a bit of a misnomer: it's not "more restrictive" as it is more efficient at lower flow rates... the smaller diameter and longer length help the engine breathe more effectively at lower rpm.
Originally posted by rototlewski
aux 5 and 6 ports
hey!! i won that thread, it's officially "tertiary ports" :p!! AHAHAHA!!! :D :cool: :D
btw: you're right, the lo-po motor has only 4 ports, and the intake system is entirely different (less paths).
Gord96BRG 05-05-2003, 11:21 AM Originally posted by rototlewski
Sure you could add the extra ports and the third intake path and get extra power from 7250 to 9000 rpm - but why bother??? The transmission can not handle input shaft revs that high without blowing up. It has nothing to do with the power, it's the rpms. Those intake mods won't make any extra power below 7000 rpm, and the transmission can't operate over 7000 rpm.
Your desire for extra power via the manual trans intake specs is incompatible with the capabilities of the auto trans. Just buy a manual trans car, fer cryin out loud!!!! ;)
Regards,
Gordon
MikeW 05-05-2003, 05:27 PM Yeah maybe if the rotor width is 100mm
j-apex rx 05-05-2003, 06:06 PM you are all saying the tranny can't take more then210 .so why the rx7 from 93 to 2002 that had auto tranny had 255 to 265 hp .you tell me the answer to the question then i will beave it.
lefuton 05-05-2003, 06:25 PM i don't follow the auto-tranny stuff too closely but i thought it was the torque converter that could not handle the upper rpm's
Hercules 05-05-2003, 06:25 PM Originally posted by j-apex rx
you are all saying the tranny can't take more then210 .so why the rx7 from 93 to 2002 that had auto tranny had 255 to 265 hp .you tell me the answer to the question then i will beave it. I am not even sure but I'd bet that it's because since the RX-7 used a turbocharger, that the power was created at a much lower RPM than in the RX-8.
wakeech 05-05-2003, 06:28 PM Originally posted by j-apex rx
read the thread again: the problem is RPM. because the tranny can't take much more than 7500 or 8000 or whatever the breaking-point is, they've detuned the engine to 210, which is why it's different from the hi-po motor.
it's not in the power, the power is a symptom of a rev-averse transmission, not the other way around. if the RENESIS had the sequential twin turbos from the 13BREW (thank god it doesn't) the tranny could probably handle the extra torque, and you could have 250 horses or whatever at 7000 rpm, and everything would be peachy.
if you want tons of power in the 4-port motor, if you're serious about it, look into FI as an option, as its a far better candidate for it than the hi-po 6 port.
Haris 05-05-2003, 08:59 PM Originally posted by Hercules
Don't acura NSX's auto tranny redlines at like 8K/8.5K RPM? I think mazda could have done this if they wanted to.
Haris 05-05-2003, 09:01 PM Originally posted by wakeech
Could mazda give auto tranny like 7K RPM but with 250 HP it would still be fast? It just seems as mazda didn't even care about auto tranny but just to make extra sales.
rotarypower 05-05-2003, 09:28 PM goddamn wakeech.
your wealth of wisdom and knowledge never ceases to amaze me. i'm 18 and i dream of knowing as much about cars as you do. how old are you and how'd you get to know so much about cars??
your #1 fan
Hercules 05-05-2003, 11:03 PM Originally posted by Haris
Don't acura NSX's auto tranny redlines at like 8K/8.5K RPM? I think mazda could have done this if they wanted to. Doesn't the NSX cost 90K?
I think that might have something to do with it :)
wakeech 05-06-2003, 12:21 AM Originally posted by Haris
...i italisized the important bit: the NSX is, what, a near-exotic halo car at nearly double the price of the RX-8, which is suppost to be a volume sales sports car liek the Miata is for Mazda: there is no way they would sell a tranny 2k more expensive to produce (never mind the Honda-sized budget to engineer one) 30 more horsepower in the non-purist-enthusiast model anyways, right??
and secondly, i dont' think that Mazda doesn't care about the auto, but with this model they're targeting a different kind of buyer: someone who would buy an Accord V6, but wants somethign that can handle, and looks good enough to impress the ladies. it's not for the purist-enthusiast, it's for the sometimes arm-chair-fantasy-racer (hey, i am too: i don't think there's nothin' wrong with wishing you were Kimi) who'd just like to have a nice, refined, easy driving true sports car. it's a wankel motor too, but that's not the only selling point on this very well-rounded vehicle. my point is that the auto doesn't have to be the fastEST: it's not like 210hp is slower than any FWD sports coupe in that price range anyways (RSX-S, Celica GTS... to tired, can't think of other examples).... in fact, i think a 210ps 5speed would be bloody fast and would certainly be enough car for me, had i the choice to get anything.
wakeech 05-06-2003, 12:35 AM Originally posted by rotarypower
goddamn wakeech.
your #1 fan
ahahaha... don't tell Sputnik, he'll yell at you for how wrong you are (about me knowing a lot) ;)
i'm 19, and i just kinda really got into cars with Gran Tursimo (believe it) and F1... that got me started, then i fell in love with the rotary... i've just got a thing for engines: they always seemed like magic (back in '99, i couldn't fathom how a car engine actually worked... i literally knew nothing about the mechanics) to me.
now i've learned, and i'm still constantly learning new things all the time... to really get the basics, start with motorsports: it's automotive performance distilled to its most raw elements... speed isn't complicated once you get down to it: it's just got to be lighter, stronger, and faster. the tricky bit is how to get it done.
...road cars on the other hand pose a far far greater challenge to the car designer (IMO) with all the countless comprimises and very subjective features of design (like "beauty" and whatnot).
the old tech forum i used to haunt (most stuff blew over my head at light-speed) was www.f1mech.com , which has sadly disappeared almost 1 year ago i believe... i've not checked back in probably 8 months, and only thought of it now that you asked :) (checking site now as i write this)... nope, still the same as always... *sigh*
anyhoo, yeah, thanks :o
Sputnik 05-06-2003, 09:03 AM Originally posted by wakeech
...don't tell Sputnik, he'll yell at you for how wrong you are (about me knowing a lot) ;)... That's an inside joke, btw...
---jps
Gord96BRG 05-06-2003, 11:38 AM Originally posted by Haris
There's only so much development money to go around when developing a new car. Since the RX-8 is all-new, it would have been a very expensive project. I'd bet that Mazda didn't have the funds to engineer a new transmission at the same time.
As I said in a previous post, I'm certain that there will be a new 5 speed automatic in the RX-8 by the 2006 model year, along with a sequential 6-speed semi-auto. Both will likely be engineered to handle the revs of the current Renesis, along with the 300 hp of the 1.5 litre version that will be in the new RX-7.
If you can't drive a stick and have to have an auto - either buy one now and live with only 210 hp, or wait a year or two and get all the power and a much better auto trans!
Regards,
Gordon
MikeW 05-06-2003, 12:57 PM The NSX automatic makes 250 hp@6600 rpms
& 210 ft-lbs@5300
maverikk 05-06-2003, 01:26 PM Hmmm. Need some advise. I believed until now that the standard engine with 192HP and the manual 5-speed here would be o.k. for me. But if I read this carefully about the engine, ports etc. I get some doubts.... Any idea? Is the high power the "real" thing against the standard?
wakeech 05-06-2003, 02:30 PM Originally posted by maverikk
...as i've said many times before, i think that getting the el-cheapo model (which is still quite expensive, and still very very nice) in Europe with the 5speed and the 4-port motor might be a far better tuner's car than the hi-po motor... 4 port + turbo = fun fun fun, and (oooh la la!!) torque (:p) through a lower range of revs (with maybe some very low rpm throttlr response tradeoffs...)... basically you could make as much or more hp on a turbo 4 port motor for as much or a little more than the high-power motor, of course sacrificing the anemties, trim, and even the sport suspension package??? (i don't know what the deal is with that stuff)
...the only real unknown (at least to me) is the strength of the 5 speed tranny... the 6 speed has been proven in countless turbo Miatas which have way more force per rev than the RX-8 will see in the hands of most, so it's not a huge problem in that regard.
maverikk 05-06-2003, 02:51 PM Wakeech, many tnx for the reply. What I actually meant: NOT tuning the car but leaving it like it is. 192HP, not more. Against the hi-po version??? :confused: :confused:
wakeech 05-06-2003, 02:57 PM well, i'll say again that 190hp isn't slow by any measure... that's a helluva lot more power (30hp) than the last incarnation of the 6 port motors were making back in '91.
rototlewski 05-07-2003, 08:30 AM yeah it is
the turbo option you speak of is what i have been saying ever since i read through the press kit
i mean 6 ports suck on fi. any of those vortech supercharged fc's show that
and to reply to how you learned about cars, i learned much the same way but i just happened to have a father who was a mechanic
I have always hd a thing for engines I have like 3 of those clear plastic engine models 4 cyclinder a V8 and a rotary
i built the 8 with my dad when i was 9 that was fun
im 16 now and alas wakeech does know more than me and it pisses me off, well at least he has better writhing skills
MikeW 05-07-2003, 09:55 AM If my Grand Turisimo memory serves me, the Rx-7 had maximum torque @ 5500 rpm and maximum horsepower @ 6500 rpm. and I thought the rev limiter was 8K, but power dropped off quickly, so I would upshift @ 7K
Haris 05-09-2003, 06:04 PM Well automatic NSX with 3.0L runs 0-60 in like 5.8 seconds. If mazda made a good auto tranny, or at least used mazda6's 5 speed auto but to redline at 6500 rpm, then RX8 auto would still be sporty. I mean right now, if it's slower than mazda6 auto, then I dont know whats so good about it except better looks and RWD. I guess I'll just wish that mazda makes or somehow uses mazda6's 5 speed auto insteaad of 4 speed.
