How "LOW" can you go!! -- for the risk takers!!
Rating: Thread Rating: 4 votes, 5.00 average.
Old Oct 25, 2004 | 10:14 AM
PimpinAintEazy's Avatar
Physician Recruiter
Exclamation How "LOW" can you go!! -- for the risk takers!!
I was wondering the lowest everyone has decided to go on the gas light.. I was at my all time riskiest this weekend.
the number im looking for is the most gas you have had to put into your tank, without have completely ran out of gas. i barely made it into the gas station and filled (15.335) gallons in the tank !!! that is the most I have ever put in.. therefore the ballsiest i have ever been on pushing the most gas out of a tank!!!
Old Oct 25, 2004 | 10:17 AM
Mugatu's Avatar
Even My Dog Searches
holy cow. you definitely have ***** to let it go THAT low. The most I have ever put in is something like 14.25.
I think you must have pulled up to the station running on fumes.
Old Oct 25, 2004 | 10:28 AM
RotorGeek's Avatar
Still spining
The most i've put in was 14.9
Old Oct 25, 2004 | 11:07 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Damn... are you Cosmo Kramer?! Looking at my spreadsheet, my riskiest tank has been 14.39 gallons... I remember the needle being way below the E line- I was on a rural highway in the middle of nowhere, Indiana... pucker factor was very high.
Old Oct 25, 2004 | 11:09 AM
VooDoo's Avatar
Exclamation Damn!
My ***** ran out and $/gallon no longer mattered. I caved-in, putting in 14.2-something. To quote another post, I had SERIOUS pucker factor...
Old Oct 25, 2004 | 11:16 AM
VooDoo's Avatar
Originally Posted by abbid
Funny you ask. i ran out of gas friday. i put in 15.613 gallons.
Damn!!! 15.613 gallons @ ~20 mpg =312.26 mile range. Damn, I wish it were more...
Old Oct 25, 2004 | 11:19 AM
G8rboy's Avatar
Well, I'm glad someone took a bullet for the team and found out the true capacity... thanks abbid
Old Oct 25, 2004 | 11:25 AM
MazdaManiac's Avatar
I've run out twice now.
First time was back in the spring. IIRC, it took 14.9 gal plus whatever was left of the gallon I put in with the filler can 5 miles from the gas station.
Second time was a few weeks ago, but I didn't fill it because I left my wallet at home and only had a $5 bill in my pocket. Lame.
In both cases, the light came on slightly under 30 miles from a completely dry tank.
Old Oct 25, 2004 | 12:15 PM
Straight8's Avatar
As soon as my fuel light comes on i always note the mileage. i know right then and there that i have about 25 miles of granny-shifting left.
most i've ever pumped in was 15.3ish....whole way to gas station i was getting myself in to push mode.
Old Oct 25, 2004 | 01:46 PM
murix's Avatar
I am a wuss. Most I have ever filled is around 14 gallons. Glad to know I still had some to go.
Old Oct 25, 2004 | 09:52 PM
RenoIV's Avatar
Rotary powered since 1988
With the E (enough) light on ....the most I've ever put in is 14.002 gal 300mi 21.426 mpg
Old Oct 25, 2004 | 10:18 PM
quack_p's Avatar
Giant Space Hamster
Isn't that bad for the car?
Moostafa29's Avatar
Storm Trooper
My car started stuttering on the freeway about a month ago, but i was able to make it to the gas station. Once I filled up I was only at 14.8 gallons.
Old Oct 25, 2004 | 10:19 PM
Straight8's Avatar
Hard on the heart - thats for sure.
Old Nov 6, 2004 | 08:15 AM
MultiSync's Avatar
Red face
I ran out of gas on the expressway yesterday. Just in case you were wondering, my car didn't sputter, knock, or give any warning prior to going dead. Luckily there was a gas station close by so I filled up the car using a gallon container. I put 14.3 gallons in afterwards.
Old Nov 6, 2004 | 08:21 AM
RXE16T's Avatar
'RX-EIGHT'
I don't understand why you guys would drive your car until it was empty?
Is there some satisfaction in doing that?
Is it out of pure curiosity?
Or, are you guys so tight that you want to be able to extract the last drop of fuel?
Seriously, I don't get it.
Old Nov 6, 2004 | 09:57 AM
CERAMICSEAL's Avatar
It's not good for the car. First off the fuel pump is fuel lubricated if I'm not mistaken. You really don't want to run it/them dry too often.
Old Nov 6, 2004 | 10:14 AM
Kid_Icarus's Avatar
Nojooc I don't think they get an satisfaction from it other then finding out in an emergency how long they can go if they after the light goes on. Also sometimes it can be a case of tiredness since after work I sometimes leave work with less then a quarter tank and I'll just tell my self that I'll fill it tomorrow until I wake up the next day and completely forget about it until I see the light in the corner of my eye.
Old Nov 6, 2004 | 10:56 AM
Tbone's Avatar
NW enthusiast
poor fuel pump
The fuel pump is cooled by the fuel around it. Getting below the fuel light is just overheating the pump with no need. I 'm not sure how long they will last to begin with, but overheating them sure won't help any. I rarely let mine get below the 1/4 tank level. In fact I haven't seen my fuel light go on yet.
I'm betting a new fuel pump for these cars is pricey, so don't push your luck if you don't have to.
Old Nov 6, 2004 | 11:08 AM
You would have to run the tank completely dry and then operate the fuel pump for several minutes for it to even be an issue.
Running low on fuel is the same as a full tank to the fuel pump.
A new pump is about $300 and can be replaced in about 1/2 hour (it is under the rear seats).
Old Nov 6, 2004 | 11:46 PM
Loaded8's Avatar
The most I've ever put in is 14.05 gal. I thought the tank was larger than what some of you guys that ran out completely are reporting. I always get nervous if I go over 240-250 miles, I start doing calculations in my head and worrying... I think of my worse mileage to date and then multiply by 15 and it's always less miles than I've driven so I think about the average, around 18 and decide to stop asap... the last time I had 265 miles when I stopped and added 14.05 gals. almost 19 mpg, about the best I ever get. :D
Old Nov 10, 2004 | 10:38 AM
zevans's Avatar
Ran it below the empty mark the other day - wasn't paying attention on the track
I put 6 litres in at a no-name petrol station and then drove 5.5 miles to the Shell where I put another 51 litres in! I can only have used a litre or so between garages so that's 55 litres altogether...
Old Nov 10, 2004 | 10:40 AM
zevans's Avatar
By the way - the portion of the gauge below the halfway mark disappeared a LOT quicker than the portion of the gauge above... the gauge is NOT LINEAR. (Especially considering my driving was smoother and better in the afternoon session and so mpg likely went up.)
Just so you know... 9.5mpg!
Old Nov 10, 2004 | 10:47 AM
dmp's Avatar
dmp
RX8 and a Truk....
what fuel around it? I'm quite sure the pump runs via a pick-up; and the pump is located at the very top of the tank. Surely the fuel pick-up doesn't require cooling; it's simply a metal? tube. Perhaps fuel-pump placement is different on an rx8? Could be I'm full of crap.
Old Nov 10, 2004 | 10:52 AM
1.3L's Avatar
I think the most I've pumped into the tank is 13.6 gallons. I start experiencing ball shrinkage when the warning light comes on :D
1.3L
RicerX1
Jan 11, 2016 05:59 PM
p8ntman442
Sep 22, 2015 08:06 PM
PotatoCannon
Sep 6, 2015 11:48 AM
CA441914
Aug 5, 2015 11:33 AM
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
