Imp
10-25-2004, 11:08 AM
Had an auto-x yesterday, about 53-60 degrees (windy and cloudy) over the course of the day, and 8 runs at about 72 seconds each run on a mile long course.
Mods: Stock everything.
Tire pressure: 44front, 42 rear no TPS warning. :) (TPS warning came after my last run, the tires had gotten up to 52 PSi in the front) I never adjusted them during the event. I wanted to find the limit for tire pressure before TPS if the tire pressure increased while running. Found it! So basically, 44-47 on the street tires felt the best.
1st initial impressions: The car is fun. :) 1st run.. cold tires, new car. Power-on oversteer city.. more like ice. 3rd turn, mental note: 'Tame the right foot.'
The balance on the car in the tight stuff (16pace slaloms) is not bad at all in 2nd gear.. it's really nice to be in the low revs with no torque that it actually keeps the car very controllable. Keeping the power steady in the slaloms, you can toss the car and have it come around the cones, but when you nail the throttle to exit the slalom, it builds up gradually not upsetting the car at all (ie: no torque)
We had two sweepers, one was faster, longer, and a little tighter than the other. The 1st was a slight decreasing radius, and taking it at speed, plow. Taking it at 3/4 speed.. plow. Taking it at 1/2 speed, no power. And coming out fast was important because there was an increasing radius turn where you were full throttle at the top of 2nd before having to brake for a tight slalom... so maintaining as much speed (or not losing speed where you shouldn't) was key.
The trick was getting in and either lifting or even a little trail brake to transfer the weight to the outside front tire for grip and then it just carved under power... Not exactly how it would have been in my old car.. but it'll do. :D This netted me hearing the shift beep before I had to brake whereas plowing in the 1st three runs I didn't hear a thing.
So right now, sweepers = plow unless something is done mid-turn, and slow slaloms are, what I will call, 'off boost' (No low end).
For the faster slaloms, lane changes, chicago boxes... theis is where the car is a hoot.
Fast slaloms, give up a little for the beginning where I can get into the entrance, get around the 1st set and 3rd to last cone, I fed throttle... and it stuck. I was leaving slaloms faster than I ever had, and the car had grip in the rear by that time with warm tires.
You can really feel the weight transfer do it's thing in this car. (This is a shortcoming of the stock car.... and needs work) The stock suspension is soft like that. But the car settles rather non-abruptly and again, just says "ok, what do you what me to do next?" I know there were sections I could have gone faster.. but I'm just learning the limits of the car. So in the lane changes.. the car was not a problem. Chicago box... the car just stuck. Again.. no issues getting in and out of it... and I had to take it flat out because thhis element appears just before 2 gates befor ethe finish... so I was exiting at speed, WOT, and hit third gear about 20 feet after the exit of the chicag box before the finish. (It was about 19 paces for the Chicago Box)
At one point on my 3rd run, I trid taking a fast left hander a little faster then I should have under power and the back end came out... my passenger who runs an S2K, said... "I can't believe you saved that" Honestly, I can't either.. the car just communicated so well that it was saying "unwind the wheel before I REALLY come around on you" :)
So yes, this car needs less roll. FSB and endlinks will help out a bit with that. As will struts.
I was about 2 seconds off some fast guys in the region (national drivers in STS) whereas in my wagon, I was about 1 second faster than them in my old car (WRX Wagon). So overall, I'm pleased, but I also know this car will need some more work, both in mods AND driver. (Evo school... here I come again) :)
Tires, struts, swaybar, alignment are going to totally transform this car. I mean really... going from 225/45 street tires to 265-285 R-Compounds. It's a no-brainer.
I have one more event this weekend and that's it until April with the car. I don't know if I'll be running this car or someone elses this weekend (It's a team event with a different type structure than a regular auto-x).
