Anyone in sg have problem with their gear/clutch?
Old Oct 23, 2004 | 07:06 PM
Manwe's Avatar
Zoom zoom!
I remember reading it somewhere in the tech threads and it happened to me once.
At the traffic light, I engaged gear 1. When I release the clutch, I heard a extremely loud grinding sound(you know the sound you hear when you accidentally engage reverse while on the move? Sounds exactly the same except louder and lower frequency).
Happened once only. Hope it won't happen again. Anybody recall reading it or have encountered it and know how to prevent/solve the problem?
Old Oct 24, 2004 | 11:13 AM
Genesis's Avatar
Driving Me Crazy
Manwe, have the same car as u, but haven't noticed that grinding noise when releasing the clutch off 1st. Strange that it should only have happened once....perhaps it's just a fluke, the gears/tranny not meshing properly that one time. For sure I wouldn't be concerned if only a one time instance.....
Old Oct 24, 2004 | 12:14 PM
Manwe's Avatar
Zoom zoom!
yea.... so far so good. It sounds like the the collars allowed the gears to engage tranny without sync...which is not supposed to. But since it is one-off, i'll wait.
Oh by the way, I think I know why you might have problem with the car jerking...the clutcg's bitting point is low....as in it will engage the gear when the clutch pedal is released very slightly. Maybe you released it too much b4 you step on throttle.
Old Oct 24, 2004 | 12:24 PM
Genesis's Avatar
Driving Me Crazy
Yeah, that's probably it. Had a friend drive my 8 tonight who's been driving left stick for years...no jerking, doesn't matter on revs...wants to buy my 8
Old Oct 24, 2004 | 08:47 PM
Manwe's Avatar
Zoom zoom!
Hahaha... and I am pretty sure you wouldn't part with your new baby... it is good. I had pumped 3 full tanks already.
Old Oct 25, 2004 | 04:52 AM
Neon's Avatar
Black Ace
Hmm...i still feel the biting point is too high le!
Me gonna lower it when change clutch+flywheel.... To bloody high for my liking...
Old Oct 26, 2004 | 08:09 PM
Manwe's Avatar
Zoom zoom!
Think changing the flywheel is good. Heard lots of nice stuff about it.
Old Oct 27, 2004 | 08:00 AM
Genesis's Avatar
Driving Me Crazy
Hmm, changing the flywheel, assuming a lighter aluminum type, would lower the biting point even further no? Does it matter much unless you're planning to drag at Sepang?
Old Oct 27, 2004 | 06:25 PM
Manwe's Avatar
Zoom zoom!
You don't have to drag to benefit from a good flywheel. It can smoothen out the vibration and make shifting easier.
Lowering it? No...the flywheel is just another of the gearing assembly connected to the clutch assembly. Lowering it would mean looking at the fork and release assembly within the clutch assembly(adjusting the pedal and clutch linkage).
The only concern is...would we void the warranty if we change the flywheel? They could claim we damage the clutch assembly etc when we change the flywheel...
Old Oct 28, 2004 | 12:43 AM
8citing's Avatar
Silly question here. Read thru the threads in the US regarding performance enhancements. Seems like flywheel is more effective. Has anyone changed the flywheel? Is this flywheel thing relevant to AT models?
Old Oct 28, 2004 | 01:02 AM
Manwe's Avatar
Zoom zoom!
AT also has a flywheel but due to the design of the torque converter, it is somewhat different.
I don't think ppl do actually change flywheels for automatic transmissions and you might have a problem finding one that works but i could be wrong.
Old Oct 28, 2004 | 03:51 AM
M-ster's Avatar
there are a few guy in Sing have already installed flywheel, on the board here we have Fab8.
search for his tread, he did post here after his install.
Old Oct 28, 2004 | 12:05 PM
Manwe's Avatar
Zoom zoom!
I am not sure but I think mm may void the warranty...must check b4 installing. If I am on the PI, I would do too cos the warranty is only one year...Think I would still wait till 3 years or 100k(think this is more likely).
Old Feb 19, 2005 | 12:05 PM
OBTIQ's Avatar
>> Motion
HELP...
all i know is that i was driving and as soon as i switched to 2nd gear i heard a snap under my foot... from then on i ouldnt switch gears..... but i could turn the car on and off....
MAZDA dealership is saying that it is my clutch bracket (clutch pedal assembly) .... i have only had the car for 4k miles... they say that they have neva seen nething b4 so they dont know if it is covered under warranty or not.... nor do they know how it couldve happened.....
Old Feb 20, 2005 | 07:29 AM
Manwe's Avatar
Zoom zoom!
Insist that they change it. It should be covered under warranty. This is not normal wear and tear.
Old Feb 20, 2005 | 03:06 PM
wootwoot's Avatar
!w00ty! Run Chicky ruN...
well.... i've problem engaging 1st gear while moving off from a traffic light from a standstill... happen many many time..
its like a lock feeling which dun allow u to push it into the 1st gear box with the clutch fully clutch in! gonna bring it in to MM & let them inspect...
anyway FYI guys my brake eeeee sound come back after 3 weeks of 10K servicing @ MM
Old Feb 20, 2005 | 07:59 PM
Manwe's Avatar
Zoom zoom!
I have similar problems sometimes too. What I do is release the pedal, then clutch in and engage again. Maybe when I am doing my next servicing would let them know. But this problem happens in a few cars i had driven b4 so i am not too concerned.
Old Feb 22, 2005 | 09:35 AM
wootwoot's Avatar
ok... i guess u know wat i mean... going to let MM know bout it... this is not allowed to happpen!!!
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
