Renesis Durability
Old Oct 21, 2004 | 05:56 PM
Creecher's Avatar
Renesis Durability
I am putting some serious thought into getting an RX-8, but I have heard that the rotary engines aren't very durable. Is this true?
Old Oct 21, 2004 | 06:08 PM
Ophitoxaemia's Avatar
dizzy snake pilot
not true. well, not since 1973 or so when they apex seal design was changed. so id recommend getting a post 1973 rotary if you are getting one (maybe it was 74, somebody correct me).
james
Old Oct 21, 2004 | 06:09 PM
Abracadabra's Avatar
2 RX8's...24hrs...full throttle (almost)...enjoy the read...better yet...enjoy the car!
https://www.rx8club.com/rx-8-media-news-11/two-mazda-rx-8s-drive-24-hours-full-throttle-40-records-broken-41846/
Old Oct 21, 2004 | 06:12 PM
Creecher's Avatar
Thanks for the advice. Also, if I get one I will definitely enjoy the car.
Old Oct 21, 2004 | 06:26 PM
PaulieWalnuts's Avatar
Not true. I've owned several RX-7's and they've all gone well over 100,000 miles with no engine problems. Highest one was 153,000. A properly cared for rotary will equal or outlast a piston engine.
Old Oct 23, 2004 | 02:23 AM
Charles R. Hill's Avatar
Owner of BHR
I have put some serious abuse on my Renesis and it still runs great. During my nitrous testing I subjected the engine to way more detonation than was previously thought possible. I have also accidentally run into the fuel cut when the nitrous was activated. NOT GOOD, but the engine has lived through it. If I could find an RPM switch that would work as I need it to, I would install it. Another time, I shifted into second gear at 80 mph(damned aluminum flywheel) and the tach flew to about 11,500 rpm. The dash lights all immediately lit up and flashed wildly and I quickly released the clutch. Obviously, the engine can take some abuse.
Charles
Old Oct 23, 2004 | 05:34 AM
Charles Cope's Avatar
Agreed, I sold my RX-7 with 122k miles on it, had to clean the injectors once! The rotary does have a characteristic that is different from piston engines, a possibility of flooding if you start it when the engine is very cold, then turn it off before it has a chance to retain some heat (less than a couple minutes). Examples of this are moving the car out of the garage on a cold Saturday morning to wash it or, valet parking attendants that move a car after its had a chance to get cold. Rumor has it that the latest software rev, which has been out for at least six months, lessens the possibility of this occurring. I haven't had my RX-8 flood, yet (15 months/14k miles) and I live in Michigan!
Its simple to deal with, but I can understand someone who hasn't been educated would be pretty upset if they can't get their brand new sports car started! Also, its covered in the owners manual, including a procedure to de-flood it.
This shouldn't be a big deal, just nice not to get surprised!
Old Oct 24, 2004 | 01:44 AM
Blue87Sport's Avatar
Rotary only since 1980
My 1987 RX-7 had over 170K miles when I got my RX-8. It still runs strong to redline and I never had to do any engine repairs. The normally aspirated rotary engine is as close to bulletproof as internal combustion engines get. I expect at least 200K miles from the Renesis.
Old Oct 25, 2004 | 09:39 AM
Slims8's Avatar
Piston Traitor
Charles
Wow! That is something. That proves the durability of your engine... That isn't a factory clutch is it?
Old Oct 25, 2004 | 01:23 PM
Owner of BHR
Not the factory clutch. Early on, I decided to go with nitrous so while I was doing the flywheel swap I also installed the ACT Extreme Duty pressure plate/clutch kit. I have mentioned in another post that if I were to do it over again, I may have stuck with the street duty version as opposed to the extreme duty. The pedal pressure takes a while to get used to and can become troubling in bumper-to-bumper traffic. Otherwise, the ACT has taken some tremendous abuse and it still works great.
Charles
Old Mar 16, 2005 | 10:56 PM
williamngRX8's Avatar
Flyboy
engine durability
hey guys out there,
i am very curious to know how long rx8 rotary engine wud last let say base on normal usage.
Old Mar 16, 2005 | 11:08 PM
shakRpahX8's Avatar
Unknown
how the hell would we know
they're new !
Heck mine is only 3 months old
Old Mar 16, 2005 | 11:31 PM
Ike's Avatar
Ike
Blue By You
Do a search, this has been discussed multiple times and fact is it's too early to tell for sure.
Old Mar 16, 2005 | 11:56 PM
robertdot's Avatar
I just merged another "[Renesis] Engine Durability Thread" into this one.
Old Mar 17, 2005 | 12:19 AM
Flyboy
thanks guys for the info.
RX8 is my first car and I might keep it for sometime
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
gtorx7
May 30, 2016 07:46 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
