dropped left battery holddown into compartment
Old Oct 20, 2004 | 11:09 PM
Ophitoxaemia's Avatar
dizzy snake pilot
where did it go? i mistakenly removed the bolt from the holddown and away it went. doh.
any tips for the easiest way to get to it? remove the larger splash panel underneath. at first i though remove the plastic battery holder, but if you have tried this it isnt so easy! (other stuff over the bolts).
thanks!
james
Old Oct 20, 2004 | 11:14 PM
snap-on's Avatar
If you tap the bottom cover you will discover if it fell all the way down..
You may need to use a 10mm socket and remove the cover..
JimmyBlack
273
Feb 10, 2020 10:23 PM
LB2739
Jul 9, 2019 02:25 AM
Azki23
Jun 27, 2018 03:48 PM
Danield97
Oct 10, 2015 05:58 PM
