View Full Version : DIY: Easy MOD for colder AC
Tigster 10-18-2004, 10:15 AM This weekend I took a heat reflective cloth and wrapped the AC line under the hood that is exposed, I put small cable ties approx. every 2-3 inches. and cut a small square out for the little valve on the line. Today I drove to work and the AC was the coldest it has ever been and remained freezing cold for my 25 minute drive to work. Easy mod and takes about 15 minutes, it even adds 100 HP!!!!! J/K :D :D :D
I'll post pictures once my car gets back from getting the windows tinted.
foxman 10-18-2004, 10:18 AM Sounds interesting and looking forward to the pics, this would be a good DIY, pardon my ignorance, but what is heat reflective cloth and is this some you can get at an automotive store or what? Thanks.
StewC625 10-18-2004, 10:29 AM All of foxman's questions are mine as well. Also, does anyone know AC well enough to comment on if this is a "safe" thing to do ...?
Tigster 10-18-2004, 10:59 AM This is something that Miata owners have been doing for years, espically when they are boosted and are producing much more heat under the hood. I figured if the rotary made more heat than a normal engine it should work great. I used to have an 02 Black Miata and did the same thing. As for the cloth it is a silver reflective on one side and made of a fiberglass. I bought it at a Speed Shop and I think it was called heat cloth.
StewC625 10-18-2004, 11:07 AM Can you post pics so we can see which line to put it on? I'm generally happy with my -8's AC performance, but with a black leather interior and no tint, could use all the help it can get.
RotorGeek 10-18-2004, 12:18 PM Sound like a good MOD for South florida
liqiud 10-18-2004, 12:44 PM can't wait to see the pics, I know i need to do mine here in TX...
G8rboy 10-18-2004, 12:59 PM This is something that Miata owners have been doing for years, espically when they are boosted and are producing much more heat under the hood. I figured if the rotary made more heat than a normal engine it should work great. I used to have an 02 Black Miata and did the same thing. As for the cloth it is a silver reflective on one side and made of a fiberglass. I bought it at a Speed Shop and I think it was called heat cloth.
Is that the same stuff used to wrap headers?
VooDoo 10-18-2004, 01:26 PM How about a move to the DIY forum when pictures are added? Can't wait to try this...
Tigster 10-18-2004, 01:29 PM G8rboy,
It is the same idea of the tape used on headers but I didn't use a tape it was a 2 x 2 foot square piece I started with and cut it to the size I needed. It is more like a flexible thicker fabric, some auto makers use it to line the underside of the hood and underbody where the trans runs under to help control heat. I am thinking of putting some above my trans to help keep the tempatures of my cupholders down a bit.
G8rboy 10-18-2004, 01:51 PM G8rboy,
Gotcha- I used some of that on my Miata underside (I had rattling heat shield above the cat which I removed and used this stuff instead).
brillo 10-18-2004, 04:32 PM where did you guys get the stuff? I did a seach on Miata.net but couldn't find anything under heat cloth.
How much colder would you you say the air was coming out of the vents? Was there any difference in the "cycling" that you noticed? How hot was it outside?
Thanks!! :)
brillo 10-18-2004, 04:44 PM I called a local performance shop and they recommended I call Thermotec (www.thermotec.com). Thermotec recommended I use the thermoshield tape (part number 14002) which reatils for like $17 for a roll. Would this work? My worry would be the condinsation would cause the tape to fall off.....they have some other products on the site as well I'm looking over
Tigster 10-18-2004, 04:57 PM Ok, I put a call into the speedshop where I got it from they are calling me back. They use it all the time espically on his 10 second civic. I would say it makes easily a 5-8 degree difference. Tonight I will put a therometer and check how cold the air is.
Anyone in the Naples Fl area can get it from Dave @ Liberty 1.
I pick my car up at 5:30 from the tint place and will post pics when I get home.
EDIT:
Here is a link to the material I believe: will confirm it tonight
http://www.thermotec.com/products/full/14003/14003.html
PS The outside temp this morning was 76 degrees and I had the air on recirculate. on the low setting.
foxman 10-18-2004, 05:20 PM http://www.thermotec.com/products/full/14005/14005.html
This one looks like it has potential for the application in question.
beachdog 10-18-2004, 06:30 PM http://www.thermotec.com/products/full/14005/14005.html
Those are nice but since they are seamless, they would require the a/c system to be drained, the line disconnected and then the system recharged. Obviously do-able, but not a DIY for most.
Art Hazebrook 10-18-2004, 06:38 PM I found this line of Thermotec products at JC Whitney...
http://www.jcwhitney.com/autoparts/CatalogOrderSearch?sku=thermotec&storeId=10101&catalogId=10101&searchbtn.x=23&searchbtn.y=5
Regards, Art
Tigster 10-18-2004, 07:28 PM Attached is a photo of what I did, it is a strip of heat cloth, I fastened it with small clear cable ties approx 2-3 inches apart. This method you do not need to remove the tubing just wrap around it.
Sorry for the photo it is taken with a camera phone.
93rdcurrent 10-18-2004, 07:35 PM Thanks for the pic. Looks like a winner to me. Thanks for taking the time to tell us about it.
RX-Hachi 10-18-2004, 07:47 PM This weekend I took a heat reflective cloth and wrapped the AC line under the hood that is exposed, I put small cable ties approx. every 2-3 inches. and cut a small square out for the little valve on the line. Today I drove to work and the AC was the coldest it has ever been and remained freezing cold for my 25 minute drive to work. Easy mod and takes about 15 minutes, it even adds 100 HP!!!!! J/K :D :D :D
I'll post pictures once my car gets back from getting the windows tinted.This is great! (looks like an easy fix that Mazda should do themselves.) Can you please describe how your A/C was before this fix? Were you in the group that felt the A/C sucked?
I'm generally content with my A/C (no A/C amp) as is, and I always keep my A/C on fresh air. There are a few times in the middle of a blazing hot Hawaiian day, only when I'm stuck idling in traffic, that I think it could be a little colder. But most of the time, I think it's actually too cold. This fix looks like it might regulate the cooling affects of the A/C better.
Paradox 10-18-2004, 09:06 PM Tigster:
Thanks so much for this info. I think you're also really on to something about heat shielding the cupholders and the center console in general. This would help decrease heating the passengers and their drinks. Ipod users have also discussed malfunctions when putting their ipods in the center console, because of overheating. This heat shield could help with that too. I wonder what is involved in getting to this area. Would this be an exterior mod, or an interior mod?
Rob Tomlin 10-18-2004, 10:15 PM Good tip. I've been lucky, my A/C seems very cold even on 100 degree days here in SoCal.
Razz1 10-18-2004, 11:58 PM I've been planning to do this for some time now, but I work 12 hr. days.
Ned M 10-19-2004, 01:37 AM Pegasus Racing carries the stuff you're talking about, too. Check out the link below and there are both cut-to-fit and self adhesive aluminized heat barrier cloths.
Pegasus Racing Heat Barrier page (http://pegasusautoracing.com/group.asp?GroupID=HEATBARRIER)
Those of you thinking about using it to insulate your center console, it should work fine. I insulated the entire area above the downpipe and catalytic converter on my RX-7 and it did wonders. You need to make sure you place it so the reflective side faces the heat source (your exhaust system), but it can't touch the exhaust.
rotarenvy 10-19-2004, 03:27 AM are there any other lines to do? do you just let the aircon run for a while and insulate anything that feels cold?
That's what gives me pause. Not sure that the insulation is THE fix, since if it were the missing piece, we wouldn't get the "my AC is great in 100 degree heat" posts. But, it's simple enough. Between this, insulating the center tunnel, and heat-rejecting window film one can probably make do with the "sucky" AC that most (but not all) RX-8 seem to come with.
rotarenvy 10-19-2004, 04:07 AM I just had a look and the aircon line is already insulated on my car with foam all it needs is some reflective material
Tigster 10-19-2004, 07:51 AM Here is the difference that I felt, in the mornings the ac was fine. On my way home (I live in Orlando FL) I found myself having to turn the fan up higher and the car never had real cold ac. Now it runs great and took only about 10 minutes (be sure not to drop any of the cable ties onto the motor).
As for the heating issue in the center console I recently put my nextel phone into the cupholder and closed the top. When I got home I got my phone out and the hinge on the flip top on the phone broke and the phone never worked again. After ordering another $250 on a new phone I am going to tackle the heating issue inside the console. I plan on putting lining on the underbody of the car using the self adhesive kind. I will write up a DIY for this. I just have to find the time since I have been working 6 days a week.
Ninja 10-19-2004, 09:18 AM Attached is a photo of what I did, it is a strip of heat cloth, I fastened it with small clear cable ties approx 2-3 inches apart. This method you do not need to remove the tubing just wrap around it.
This is cool, Tigster. Is this the only line you insulated (the one visible in your photo) or were there other lines?
foxman 10-19-2004, 10:14 AM Those are nice but since they are seamless, they would require the a/c system to be drained, the line disconnected and then the system recharged. Obviously do-able, but not a DIY for most.
Perhaps this one then which can be slit.
http://www.thermotec.com/products/full/17062/17062.html
MTLbroker 10-19-2004, 11:16 AM Plastic cable ties are durable enough for this application?
G8rboy 10-19-2004, 11:24 AM Plastic cable ties are durable enough for this application?
Quality ties are made of nylon and can definitely handle the heat and stress of the underhood environment.
Tayninh 10-19-2004, 11:44 AM Just be sure the tie part is not sticking up as I might get in the way of putting the engine cover back on. Not sure how close the cover is to that rear AC hose but one might want to keep the lock tie part to the side facing front of the car. Its a good idea though and makes sense as the engine sure puts out tons of heat.
SpinninAgain! 10-19-2004, 11:47 AM Tigster,
Many thanks for a very cool DIY. It's late in the season up in the NE so I don't need the AC any more, but I'll remember this thread next Spring or Summer.
Great job and thanks for sharing. This should be moved the the DIY forum, and maybe stickied for awhile now and especially next Spring.
Tigster 10-19-2004, 06:08 PM The only line I insulated is the one shown. the rest on the line is insulated with a rubber insulation on mine. The cable ties I used were the smaller ones (about 3" long) so the heads are not so big and the engine cover does fit over it, I just turned the little heads down to make it look a little better. Also if you look under your hood they use cable ties all over the place so they can with stand the heat
Jazper 10-19-2004, 08:15 PM Bare with me because I am new to the forum and new to RX-8 (I bought mine 2 weeks ago)... question... is the purpose of the reflective heat wrap to keep the exhaust heat away from the AC lines? Please explain!
Thanks,
Jazper :rolleyes:
Tigster 10-19-2004, 08:51 PM Jazper,
If you were to open the hood of your car and remove the engine cover there is a a tube that is used to bring cold air into the cab of the car. The motor produces heat (espically a rotary) and will heat up the outside of this line hence heating the air that has been cooled. By insulating the tube you are helping retain the coldness of the AC. Most of this pipe is already insulated by a foam type of insulation from the factory, so not a large portion of the tube needs to be covered. Hope this helps. :o
G8rboy 10-19-2004, 09:10 PM Jazper,
I believe the tube in question is carrying refrigerant back from the condenser to the evaporater in the cabin (which is where the air from the outside gets cooled). Since refrigerant has such a low boiling point, I'm guessing this mod will help keep the refrigerant in a liquid state until it reaches the evaporator.
starbucks 10-19-2004, 10:52 PM It's amazing that Mazda hasn't figured this out already and made the mod to the 2005 models, especially under the center console.
I live in So Cal and the A/C worked fine even on the hottest days when driving out of a shaded garage. However, once I parked, even out of the sun, and let the car sit for a bit before getting back in, the heat from the center console heated up the interior to the point that the A/C needed quite a bit of time to cool the interior even on max/recirc.
On warm evenings, the heat radiating from the center console made using the A/C a must if just cruising on surface streets.
I'll try this mod, but it'll have to wait until next summer to see if it helps. I looking forward to lining the underside of the center console with the reflective heat blanket.
beachdog 10-20-2004, 01:08 PM I believe the tube in question is carrying refrigerant back from the condenser to the evaporater in the cabin (which is where the air from the outside gets cooled). Since refrigerant has such a low boiling point, I'm guessing this mod will help keep the refrigerant in a liquid state until it reaches the evaporator.
Correct. The only place you'll find cooled air is in the cabin.
If I recall the mechanics of refrigeration correctly, there is a manifold in the evaporator that distributes the refrigerant to each of the evaporator tubes/coils. The pinhole in each of the manifold legs allows the refrigerant pressure to drop as it enters the evap.
If you ever find the refrigerant line that tigster insulated iced-over, it means that there is a refrigerant leak because the refrigerant pressure drop occurred before the manifold.
TheDosDog 10-20-2004, 02:42 PM Are you insulating the larger suction line that goes from the evaporator to the compressor? If so, I don't see what that would accomplish. Has anyone put a set of gauges on the A/C to see what effect this mod has on line pressures?
NavyDood 10-20-2004, 02:58 PM That definitely is a good idea. I think you could get by with just regular foam insulation wrap too. (Wouldn't look as nice). Your goal is to keep the heat from under the hood off the line so it's not getting heat soaked. That line gets ice cold when the A/C is on.
ezrider55 04-24-2005, 10:13 PM It is starting to warm up so Bump.
______ 04-24-2005, 10:32 PM Where and what is liberty 1 in naples???
fullsmoke 04-25-2005, 02:19 AM Not sure why Mazda didn't do this in the first place. However, I know that insulation around a wire (or in this case, rod-like object) could possibly have no effect or so little it's not worth it. It's based on some heat transfer formula I wish I could remember, which gives you a critical radius of how thick the insulation can be until it is useless or harmful. This is all just theoretical shit though. In real life, I think the insulation will help :)
FS
Tigster 04-25-2005, 07:20 AM Where and what is liberty 1 in naples???
Libetry 1 is a tuner shop in Naples Fla, he builds very fast cars.
Chrisbert 04-25-2005, 10:28 AM We talked about this before - Megau brought it up and I never tried it yet.
http://www.rx8club.com/showthread.php?t=7537&page=3&pp=15&highlight=A%2FC
Guess I'll give it a go.
brillo 04-25-2005, 12:18 PM are you guys running the cloth down all the way to the compressor on the right side? I've done the mod from the left side firewall all the way to where the hose goes from aluminum to rubber, but not down to the compressor attached to the engine.
Tigster 04-25-2005, 12:38 PM I only wrapped the line where it is shown in the photo, I may have to look into adding the heat insulation on the side as well... I also used the same insulation under the center console to try to keep the temps down when the center consloe lid is closed.
Chrisbert 04-25-2005, 04:02 PM The reason that line is ice cold is because it is after the evaporater.
The compressor "compresses" the refrigerant. The refrigerant is hot at this point due to compression. It runs into the evaporater via the expansion valve. Expanding gases become colder. The fan blows air across the cold coils in the evaporater and it comes out the vents. It runs from the evaporator back to the compressor in lines that are ice cold to the touch where it starts over again.
Thus, I never tried the mod when we originally talked about it. Maybe though, this is keeping the refrigerant at a temperature that makes the compressor run a more efficient duty cycle?
juikster 04-25-2005, 09:15 PM the reason you want to wrap the line leaving the evaporator is because the refrigerant that has left the evaporator has changed from liquid to a gaseous state and any more heat added to the suction line to the compressor causes the gas to gain heat from engine compartment which is unfavorable(superheated gas)
which screws up the efficiency of the cooling system and its that extra added heat that will have to be removed by the condenser coil up front...So a good wrap of insulation to this suction line is important........
Chrisbert 04-26-2005, 07:44 AM So if the refrigerant in its gaseous state enters the compressor at a lower temperature it will make life easier for the compressor. Less on/off constantly...
Gonna have to try it.
StealthTL 04-26-2005, 11:00 AM I wouldn't bother even wrapping it.
That pipe is not a factor in how cold your a/c is going to be. You will notice that all the peeps who replied said it "felt colder" or "seems better", there are zero measured differences -
Does it get to 44*F before cutting out?
Does the compressor cycle every 23 seconds instead of every 52?
Is the outlet air temp colder at idle?
...and by how much?
Pure placebo effect/conventional wisdom - "It must be colder, because I insulated the 'frosty' pipe" :rolleyes:
That pipe goes from the evaporator to the compressor, if it is 'frosty' it means you didn't put enough cabin air over the coils, and you are wasting cooling. From there it goes thru the comp, then the drier and the condensor. Now it is hopefully back at ambient temp, ready to re-expand and do its refrigeration thing again.
The two feet of insulation on the evap outlet is irrelevant.
Sorry, but save your cash.
S
Brice-RX8 04-26-2005, 11:04 AM Also, in the summer time when you have it on max A/C the compressor is going to basically run non stop anyway, it will not cycle on and off nearly as much as when the temp is cooler and you don't have it on max A/C, if your system is cycling on and off really fast every couple of seconds at idle then you have problem with the system like low refrigerant
lethologica 05-15-2005, 04:58 PM I might not be looking at the same line, but in my car that tube is pretty hot, and I haven't used my AC yet. But I've touched it while changing my oil filter, if you are reaching for it from the drivers side it would touch your right side of your right arm. Is this the same tube?
TeamRX8 05-16-2005, 03:11 AM they sell a special wrap with clamps just for hoses and pipes
http://www.thermotec.com/products/full/11600/11600.html
but I have to question it's effectiveness too
Razz1 05-26-2005, 01:02 AM Yes, it's the same tube and it does get very hot.
The A/C is colder but it will still cycle.
Now mine goes from super cold to warm and the cycles are much shorter.
Before it was: a little cold to hot and consistently cycled back and forth.
Go to: http://www.porterfield-brakes.com/
Zaku-8 05-26-2005, 02:48 AM what other things can be done to the A/C?
also, is refrigerant level something that has to be checked now and then? Ever since it got warm my A/C doesnt seem as effective as it used to be.
Razz1 05-28-2005, 12:56 AM duh......?
It's an inherrant problem. Even the 05's aren't fixed yet.
TeamRX8 05-30-2005, 02:55 PM there'a TSB for faulty AC amplifier, should be factory corrected on later production vehicles though. I think there's another TSB/flash update that delays the AC cutoff rpm point so it doesn't kick off so easily during semi-spirited driving (what most RX-8 owners would call normal)
fwiw, if it was as easy as insulating a hose don't you think the manufacturer would be aware of this? They aren't that stupid you know.
rx8gurl 06-16-2005, 12:55 AM hi, i really want to try this mod. Can anyone tell me where and what product exactly would tackle this mod. Thanks
TeamRX8 06-16-2005, 01:15 AM would suggest an introductory course in how an A/C system works so you can make the informed decision
http://www.familycar.com/Classroom/ac1.htm
as someone so aptly put it, "insulating the frosty pipe", has no bearing on how cold the air blows out the vent :rolleyes:
fwiw the "frosty pipe" is the return line, not the supply line, too funny :D
Blue87Sport 06-16-2005, 03:43 PM This is an interesting thread. One one hand you have the skeptics saying "insulating the frosty pipe is a waste of time". On the other hand you have folks saying that reducing heat absorption in the system will increase effectiveness. Neither side has any direct evidence one way or the other.
Not being an HVAC expert, I'm just think this through out loud and have a couple of questions. Some people say the return pipe gets very hot and others describe it as "frosty". Am I correct to assume that it gets frosty when the AC is on and gets hot (due to high ambient under-hood temps) when the AC is off? If that is the case, then I think it is safe to assume that the (uninsulated) pipe will aborb heat, thus increasing the temp and pressure of the refrigerant gas inside.
So what is the effect of this increase on the system? Does the compressor increase the pressure by X psi? If so, then the warmer return line will result in a hotter than normal output from the compressor. Or does the compressor run enough to produce a target psi? In this case, the higher input pressure just lets the compressor do less work, perhaps decreasing its duty cycle.
Assume that the added heat of the return pipe carries through to the compressor so the temp going into the condensor is higher. At a given airflow, a hotter condensor will shed more heat than a cooler one. Whether it sheds enough heat to compensate for a higher incoming refrigerant temp is unknown. So will mod have any effect on the temperature of the refrigerant entering the evaporator? If it does, then the evaporator has the potential to absorb more heat from the cabin. Of course, whether the design can achieve this potential depends on the heat exchange properties of the evaporator such as its size and airflow and how it is controlled by the AC system.
In my mind, there are two many variables to be able to analytically say whether this would work or not. It ultimately boils down (a little AC humor there) to whether this mod impacts the temp of the refrigerant entering the evaporator.
I guess the only way to know is a controlled experiment. Measure the vent air temperature before and after the mod trying to keep other factors such as outside temperature, driving speed, starting cabin and engine temp the same. Anyone up to the challenge? :)
jaguargod 06-16-2005, 05:07 PM fwiw, if it was as easy as insulating a hose don't you think the manufacturer would be aware of this? They aren't that stupid you know.
So following that line of logic, factory installed protection for the oil coolers and a/c condenser must be really difficult for the manufacturer to envision and engineer. Otherwise they would surely have made them standard issue by now, right?.
I think the system is capable of more BTUs, but is being restricted from doing so. I noticed this the other day, doing the 4000-rpm shutdown procedure after briefly moving the car. I decided to hit the AC button. Since I was now in the garage (door open of course) it was fairly easy to hear the AC clutch engage and I also noticed a decrease to about 3600 rpm, holding the pedal position steady.
But, the compressor clutch did not stay engaged for long. The vent air began the familiar "cycling" behavior -- cool/lukewarm/cool/etc... And everytime it cycled was exactly timed with the AC compressor engaging and disengaging.
It seems to me that a good deal of the problem is related to the duty cycle being imposed on the compressor. This is part of what the upgraded "amplifier" seemed to address (in addition to enforcing recirculate-mode). But the success of the new amplifier is less than stellar by most accounts on this forum. My unit is past the VIN target for the TSB so I don't know if my cycling is more or less than what a unit with a newer amplifier experiences.
Why would the compressor duty-cycle be "detuned", so to speak? I can think of a few possible reasons
1) to aid with an already-disappointing fuel economy
2) prolong the life of the compressor
3) mitigate the heat load on the radiator
4) keep the evaporator coils from icing up
Of those, I speculate that #1 may have been the biggest driver. #4 is always important, but I don't have any idea how close or far away from an icing problem we are -- that is, how much could the duty cycle be increased before it becomes a concern?
I think my next bit of research is going to be wiring an LED into the AC-clutch circuit so I can see on my dash when the unit is operating and when it's not. I'd like to get some accurate measurements of the actual duty cycles and compare that to times when the AC seems to be doing ok and when it seems to be particularly anemic.
My end-goal in this is to see if there is any cheap and reasonable way to increase the compressor's duty cycle to a point where the driver is not constantly aware of the weak AC.
ezrider55 06-16-2005, 11:40 PM I moded mine with grey foam pipe cover from Low's. I had new AC Amp already installed for months. With new AC Amp air was cool. :cool: Wtih pipe cover it is cold. :D My .02 cents worth.
TeamRX8 06-17-2005, 02:01 AM So following that line of logic, factory installed protection for the oil coolers and a/c condenser must be really difficult for the manufacturer to envision and engineer. Otherwise they would surely have made them standard issue by now, right?.
I ran an FD with exposed coolers for years and never had a problem, that said anything can damage your car at any time. You don't have a cowcatcher to avoid gatorbacks too do you? I had a bolt kick up and bust the windshield of my company car. Should they also supply a windshield screen?
FWIW, I live in TX and my A/C will freeze me out, I generally like it colder than anyone else I know
Razz1 06-17-2005, 02:07 AM So, why do other manufacturers cover the A/C line?
Believe me it works. It's not a complete fix, but helps. Helps enough that the A/C is more than tolerable. Add the AMP and it's better yet.
This is the order in which I repaired the A/C problem. Like I said id cycles less frequently and the air is colder.
Vaillant 06-17-2005, 03:38 PM What we need is someone to measure the air temp before and after the mod. Quantitative evidence. Who wants to volunteer?
~ Matt
r042wal 06-25-2005, 09:03 AM I wrapped mine in 1/2" foam used for insulating copper pipes. I then wrapped foil tape around the foam, the same foil tape used to seal heating ducts.
I mentioned this mod to one of the technicians when I was at the dealership buying oil last week. He said that he *could see* how this could make an improvement.
Unfortunately, we are in the middle of a heat wave in Ontario and it is too hot to go outside this weekend to see how well it works :-)
bxb40 07-04-2005, 04:21 PM I just did the insulation mod. I used glass fiber insulating band (4" wide) and wrapped it double layer. Then on top, aluminum body fixing tape (4" wide) in sections around the pipe turns, and length-wise on the strainght portions. Both were purchased from Auto Zone - nothing special. Looks kinda fine - obviously not something to rave about, but it ain't all that ugly either.
The AC worked just fine at 92F we have now in NJ (read on the car sensor). I already have the updated amplifier installed as well. Short of checking the level of the refrigerant - maybe is on the low side? - and tinting windows, there is nothing else to be done about the AC on this car...
So, instead of talking up and down and theoretise on the benefits of insulating that pipe - interested people should just do it ($10 in parts, 30 min installation).
As for the skeptics, no need to discourage people! Let them do it - what's to lose?!? I just don't get it....
therm8 07-05-2005, 12:23 AM And besides, I'm thinking of going on an intake insulating frenzy from the airbox to the engine and saying "piss off" to heat soak, because of this thread :p
krwkenny 07-14-2005, 10:48 PM They use this same theory on housing A/C. Check some of your lines at home for insulation.
wedge357 07-14-2005, 11:21 PM Got mine done today using 1/2" foam copper insulation tube bought from Home Depot. The foam tube is split on one side with adhesive strips to close together, costs $6. I used aluminum tape ($2) and taped it lengthwise covering the foam surface except where the foam is split. I pulled the tube over the a/c piping, pressed the adhesive ends together, covered the remainder with some more aluminum tape then tiewrap ($2/10 tiewraps) the whole thing down. Total cost for the mod: $10.
dwynne 07-19-2005, 02:26 PM I wouldn't bother even wrapping it.
...and by how much?
S
I agree! If this was a chilled air system, then this might help - but this is "freon". As soon as it hits the compressor it is going to be red hot again.
and this just not correct. The cold pipe is the suction pipe that is LEAVING the cabin of the car - the gold color pipe below this one (that will be VERY hot) is the compressed "freon" going INTO the cabin of the car.
http://www.energyquest.ca.gov/how_it_works/air_conditioner.html
http://www.edmunds.com/ownership/techcenter/articles/46869/article.html
are just a couple of the many places that explain how the A/C works - but it does not push cold air into the car at all.
Someone would need to do a proper before and after test to see if there were SOME benefit to this at all. I suppose a cooler temp imput to the compressor might make it work a little better but it is not going to be any sort of "dramatic" cool down of a car that was not cooling correctly to start with. You CAN effect a cooler system by spraying the condenser in the front of the car with cold water. This provides a better heat exchange with the hot outside air and will then remove more heat from the "freon".
Dennis
Despite my skepticism there were enough testimonials to make me try it. For what it's worth I used a roll of "Frost King" hot/cold pipe wrap that I picked up at home depot
http://plumbing.gillroys.com/Plumbing_tools_and_accessories/Pipe_insulation/Pipe_Wrap_Insulation_Tape-s420280.html
Due to the adhesive, a spiral wrap of the pipe is impractical; I just ran a couple of overlapping lengthwise strips and the obligatory zip ties...
More importantly, there may be some new info about programming the amplifier
http://www.rx8club.com/showthread.php?t=66922
I did the wrap last night and will do the reprogram before I leave work. So if it's magically better I'll have no idea how much improvement to attribute to either action. Oh well... I wouldn't want to break the spell :)
pcimino 07-20-2005, 10:27 PM I took temperature readings on my vent, with all settings the same, over three days before doing the pipe wrap, and then after. Short answer is there was no difference. Most of the readings I took on the way to work, pre-sunrise, so no radiant heating, just ambient temperature to deal with.
The interesting thing, is that regardless of the morning readings at 77 degrees or the afternoon readings in full sun at 90 degrees, the vent always cooled to a range of 54 to 56 degrees F. This suggests an artificial limit in the system.
As an engineer, I'm pretty sure the pipe wrap is not a placebo. But I did not encounter conditions where the AC only cooled to 65. I probably needed a 110 100% humid day to test with.
I know one time I took my wife for a ride and the AC started blowing warm air and she thought that was ridiculous. It could have been cycling off to make sure the exchanger didn't freeze up or something. But that was an unusual occurrence, rather than normal behavior.
TeamRX8 07-27-2005, 03:58 AM as an engineer then you should go do some basic research on refrigeration which will confirm your reading results. Kind of funny that you tquestion the conclusion of the actual results
I've only ever seen an issue when the car is not moving fast i.e. not getting good airflow into the condensor, IMO the condensor may not be sufficiently sized to handle low air flow conditions. If this is the case the freon gas will not condense into liquid form, which would result in the system blowing warm if there is gas rather than liquid at the expansion valve. It wouldn't matter if the compressor was running all the time or if the frosty pipe was insulated or not if that's the case.
there's a reason the "frosty pipe" between the evaporator and the compressor does not need to be insulated, just as there is a reason that the compressor cycles on and off, it's all related to the basic fundamental design of how a gas/liquid refrigeration system operates. I am engineer too, having been involved with industrial refrigeration systems. The only time we ever insulate the frosty return pipe is when we don't want condensate forming and dripping down off of it onto whatever is below it. If the whole basis for this kooky thread were true for a small automotive AC system can you imagine the energy savings a large industrial plant would gain by insulating the frosty return pipe?
The truth is in your results.
this entire thread is one of the greatest exercises in ignorance that I've ever seen
pcimino 07-27-2005, 06:40 AM I agree, the proof is in the results. Which is why I ran the test, because I was tired of everyone writing conjecture.
The reason I was surprised is that most AC systems I'm familiar with don't reside next to a hot engine block. My "theory" was the close proximity to the engine meant the system could be soaking up unnecessary heat. Even the return pipe should be at a much lower temperature than the block.
My experiment disproved my theory. Which just goes to show a little science could have stopped this whole thread in its tracks a LONG time ago.
:D
Chrisbert 07-27-2005, 07:13 AM They use this same theory on housing A/C. Check some of your lines at home for insulation.
Home AC is a considerably different beast. The refrigerant in the system is designed to stay colder longer because the compressor is often 100-200' of pipe away from the coils. The refrigerant in car systems is, thanks to our government protecting us from ourselves, quite crappy.
Most home systems I've seen wrap only the supply line. The return line is usually secured to the outside of the wrapped supply line.
If your system is in the attic, they will wrap the condensate line to keep it from dripping due to the cold water inside condensing on the outside from the attic heat.
dwynne 07-27-2005, 12:14 PM this entire thread is one of the greatest exercises in ignorance that I've ever seen
I agree, but logic has no place when it makes them feel better ;)
You should also go read the "Reprogramming the AC" thread - where you hold down some buttons and lose control over your AC. It will now automatically go to recirculate any time it is hot out and you have the control on full cool and in dash vent mode. No duh, on a 100 degree day that would be better than trying to recool the 100 degree air outside the car. But once it is explained that you can do this yourself using the fresh/recirculate button folks are STILL doing the "program" and declaring how much cooler they feel :confused:
Dennis
pcimino 07-27-2005, 03:16 PM How about we sell a placebo button on EBay? A bright blue button labelled "Sooper Cold" and instruct them to glue it onto the recirc button. Could probably get $5 each. ;)
vrpirata 07-27-2005, 03:17 PM I haven't try this yet, but at first I though it was just a placebo.
But actually, by wrapping the line that goes from the Evaporator to the Compressor, the compressor will convert the gas to a slighly-colder-than-before liquid, adding efficiency to the system I guess. Then the Condenser would be able to do a more effective job of bringing the hot liquid to ambient tempeture.
The air comming out of the A/C system should be tempeture regulated; actually there is a "Evaporator tempeture sensor" inside the A/C unit. So I don't think the A/C is going to be any colder with this modification. However, I think wrapping that pipe would increase A/C efficiency, and therefore, reaching the desire tempeture faster, with less work to do and less load to the engine.
A good reference about refrigiration:
http://home.howstuffworks.com/refrigerator4.htm
dwynne 07-27-2005, 03:41 PM Given the length of the exposed pipe and the velocity of the "Freon" travelling through it, I would have a hard time thinking it will pick up much, if any heat from the engine.
Dennis
Are you saying that it's not possible that some RX-8 compressors aren't cycing off prematurely? Ive sat and felt the output as the compressor cycles on and off. The temperature of the output air cycled markedly along with it. I understand the concern over the evaporator coils icing but during this test the temperature of the output air gave no indication of icing being imminent -- it wasn't that cold. Isn't it possible that system can be too conservative with the compressor duty cycle?
Chrisbert 07-27-2005, 04:02 PM Not sure, but I think that the refrigerant that leaves the compressor will be hotter than that returning, even before the wrap. Compressing the gas heats it up tremendously. The expansion of that same gas causes it be cold.
Dennis
:) I'll take the heat for insulating my frosty pipe because I have a general understanding of the principles and agree the potential for meaningful amounts of heat entering there is tiny.
But, I HAVE gotten a distinct and unmistakeable improvement after having done the reprogram procedure (well, yeah at the same time as the FP insulation job). Yes, I understand how/why recirculate benefits. I used it all the time BEFORE the reprogram. This procedure did something else that resulted in improved cooling. No, I don't have thermometer readings but when you go from a car that always reminds you that the AC is barely there, to one in which you're perfectly cool, subjective evidence is enough imo. Yesterday it was 95F and full sun on the way home and it was perfectly cool in the cabin with fan set to 3. And it didn't take long to get there. This was never even close to being the case before. Prior to the reprogram that ride would have been spent with fan roaring away on 4, with recirculate and would just have begun being tolerable right about when I was pulling into my driveway. Well, maybe I was hip-mo-tized by the flashing defrost light but hey, I'll take it. :)
Since the unit is "programmable" and we do not have definitive specs, isn't it possible that a reprogram could be making changes or clearing a condition other than what is described in the brief procedure?
I think it's significant that there is a widespread dissatisfaction with the AC in this car -- among people who are not naive and have driven enough vehicles to have a basis for comparison. And, not all vehicles seem to be affected. To me this rules out any fundamental design flaw in terms of specs. That is, condenser is adequate, compressor is adequate, etc. The answer lies in finding what is different between vehicles. Given the complexity of the control systems in the car I think it is logical that the control logic could be the issue.
salituro64 07-27-2005, 06:05 PM And that reprogramming would be.... :confused:
Blue87Sport 07-27-2005, 07:42 PM The reprogramming is described here:
http://www.rx8club.com/showpost.php?p=963554&postcount=8
There may be multiple ways/levels of reprogramming. It sounds like its still under investigation...
salituro64 07-27-2005, 10:20 PM Thanks
bxb40 07-28-2005, 06:56 PM From my experience, the air coming out the vent is not significantly colder (maybe is the same? no need to measure). But the last two days humidity was 100% and so was the temp in NJ (105F). Temp inside car was OK, I was comfortable after the car was in the sun the whole day (open parking at work). Before the updated AMP and pipe insulation, anything topping 95F would not be cooling down enough for me to feel comfortable (going once at the shore was a sweaty yucky experience). So all this theory is great, but I only care of how the car feels, not why and what changes by which law of physics... By intuition, a system that has as only purpose removal of heat cannot benefit from extra heat input. Heat removed from the air forced inside the car = heat exchanged with the outside air by the AC radiator in front. If that pipe picks up heat from the engine bay, the radiator has to work harder. This is a law of physics too; energy conservation. So, maybe it does not pick too much heat - but what if it does? Can we check? No. And that pipe will burn your hand after driving the car - at least in my case since due to the MS strut bar, the engine cover is gone (maybe that one made a difference? no idea).
Geesh... for few bucks, is worth trying, as all agree that while it might not help, it definately does not hurt anything.
Don't we have real issues to solve on this car? Insulating or not 3 ft of pipe should be at the bottom of the pile with problems...
I only post so people do not get scared reading all the contrary theories and not even try to do it. Laws of physics or not.... just try, one never know (wasn't the Earth flat at some point? how come is round now? theory changes all the time - results don't).
Tigster 07-28-2005, 07:28 PM I never thought the thread I started would get this long with alot of lengthy explinations of why it won't work. I can say I have has this done for almost 8 months and I notice a difference. Call it a placebo effect if you must, but if you dont agree save your $5 worth of supplies and go to McDonalds.
wedge357 07-28-2005, 10:16 PM I just thought about it, but my 05 shinka does not automatically revert to recirc mode when I turn the fan to full blast. So I decided to experiment to see if the programming works for 05 cars, and it did! Now I don't have to remember to make sure its on recirc when I need cool air ASAP, it does it for me automatically. Good thread...
salituro64 07-28-2005, 11:27 PM Is this programming feature a factor of the flash or the electronics of the AC unit? Meaning if the electronic feature was not in the car for earlier models, it won't work.
My understanding is it requires the new version of the AC amplifier, so your vehicle either has to fall outside of the VIN range for the TSB, or you need to get the improved amplifier under the TSB. For a list of TSBs, go here
http://www.finishlineperformance.com/rx8/bulletins_index.html
RetroRotor79 07-29-2005, 03:04 PM I also noticed a significant improvement in the A/C after I reprogrammed it to recirculate automatically when set on maximum. I've tried manually selecting recirculate before and didn't perceive it to work as well as it does now. Either way, it works well enough now to be acceptable.
derwankel 07-29-2005, 05:51 PM I agree retro ... there is a significant improvement (no placebo) in the temp of the air exiting the vents with this configuration. It has been in the mid to upper 90s here in Atlanta with plenty of humidity and there is no doubt my A/C (10/03 build) is much improved since I went through this procedure.
Not only is it acceptable, it's comfortable.
salituro64 07-29-2005, 10:47 PM [QUOTE=Nubo]My understanding is it requires the new version of the AC amplifier, so your vehicle either has to fall outside of the VIN range for the TSB, or you need to get the improved amplifier under the TSB. For a list of TSBs, go here
TSB was acknowldged by the dealer two weeks ago and the new AC amplifer was ordered. Thanks for the clarification.
beachdog 08-01-2005, 07:00 PM I understand the concern over the evaporator coils icing but during this test the temperature of the output air gave no indication of icing being imminent -- it wasn't that cold.
When an evaporator ices, the output air temp rises because the air cannot flow through. The ice blocks the airways. Icing is usually caused by refrigerant leaks, not excessive compressor run times (actually they can be connected in an automatic climate control but not in a manual like the 8.)
hawgwild 08-10-2005, 08:43 PM Ok, after reading through the entire thread, I didn't find evidence supporting or not supporting this mod or the re-programming. Sooo, today, I bought two different thermometers. One a dial face, one a digital. In the store they both read the same temp. So I am making an assumption that both are somewhat calibrated and at least are on the same page as far as temps. Here are my results:
Ambient air temp - ALL tests - 85 degrees - 6pm - 7:30pm
Engine temp two ticks below the thermometer on the dash guage
No Mods
No pipes wrapped
No programming done
2004 RX8
Idle for 5 minutes
AC on RECIRC
Fan on High
Max temp - (after cooldown from the store) - 56 degrees
Low temp - 54 degrees
Highway
Speed 66mph
RPM - 4000
5 minutes
AC on RECIRC
Fan on High
Max temp - 54 degrees
Low Temp - 50 degrees
After the above Highway temp, I wondered if speed/rpm would do anything.
Highway
Redline 1st & 2nd
7000 rpm in 3rd - Held for 3 minutes - about 80 - 82mph
High Temp 52
Low Temp 49
After doing some driving around both city (35 mph) and Highway speeds (55mph) I did find that the temp got cooler. This obviously was due to the cabin cooling down and the AC's RECIRC function working like it should. Lowest temp was 41. I did repeatedly get my lowest temp (41) while the tach was at 3500rpm. Before all of this, I too thought my AC was crappy, but cooling at 41 isn't crappy. I will try a similar test on both of my GM vehicles and see what the low temp is there. In my opinion, just like elbows, everyone has a couple, I don't think the pipe wrapping will do anything one way or the other, but for $5, I'm going to test it to see and will post something here when I do (unless someone else wants to do that part that has already done the wrapping :D ) I have noticed on much hotter days that the AC will switch to the "normal" mode or fresh air mode. This is normal according to my Dad (who is in the refrigeration/AC field) I know my GM vehicle does this by drawing in fresh air to cool, which as mentioned earlier, is cooler than the stagnat/stale air in your car. I think the Mazda does the same. All I can tell you is spend the $10 for a temp gauge and prove it to yourself before trying this stuff. :cool:
No animals were harmed in the testing, however my nipples did get hard a time or two when I redlined it. :D
wedge357 08-10-2005, 08:50 PM good objective testing, hawgwild... Looking forward to your next segment. Thanks!
pcimino 08-11-2005, 07:39 AM After the above Highway temp, I wondered if speed/rpm would do anything.
Highway
Redline 1st & 2nd
High Temp 52
Low Temp 49
Dang. Even after the AC TSB and a system recharge and on recirculate, my system can not get below 51 deg.
Nice write up.
Nice write up.
Keep in mind the important value is the difference between the outside air temp and the vent temp.
dwynne 08-11-2005, 05:29 PM ple, I don't think the pipe wrapping will do anything one way or the other, but for $5, I'm going to test it to see and will post something here when I do (unless someone else wants to do that part that has already done the wrapping :D )
Once you are ready to wrap, you should take some pre-wrap readings - otherwise the numbers may mean nothing. If it is cooler or hotter after you wrap than the day you tested the temps will be different just for that. Higher or lower humidity and more or less sunshine may effect it too.
So if you want to be precise then check it moving and standing still, then wrap and recheck.
I would agree than a system blowing 49 or 50 degree air when it is 85 outside seems to be working pretty good.
Dennis
XDEEDUBBX 09-06-2005, 04:22 PM i just installed mine over the weekend. It took only 15 minutes to do. I havent tested it out yet but hopefully my ac will run colder now.
salituro64 09-07-2005, 08:38 AM FYI...Had the AC Amplifier replaced under the TSB and it appears to be colder. I haven't tested it with a thermometer though.
Razz1 09-09-2005, 01:26 AM I never thought the thread I started would get this long with alot of lengthy explinations of why it won't work. I can say I have has this done for almost 8 months and I notice a difference. Call it a placebo effect if you must, but if you dont agree save your $5 worth of supplies and go to McDonalds.
It's not $5 of material. It's $25 to $30.
You nedd to use the good stuff if you want it to work.
That's the wrapping they use on dragster for fire prevention.
go to : http://www.porterfield-brakes.com/
alcimedes 09-22-2005, 01:23 PM So we ever get any final results from someone who measured before and after temps?
pcimino 09-22-2005, 08:53 PM Yes. Differences were minimal, possibly within boundaries of error.
salituro64 09-23-2005, 08:32 AM I have several cars and IMO the problem with the AC is not the temperature, but the way it's ducted and the power of the blower. It needs more oomf. Because of that the air takes forever to cool down. Once again, I'm no expert and I have not measured the temperature, but the blower and ducting is seriously lacking.
legokcen 10-04-2005, 09:17 PM I have this same stuff too. I also felt a difference in the cold.
therm8 10-04-2005, 09:29 PM I wrapped mine with self-vulcanizing rubber tape, then with the thermal insulation. I didn't want the insulation touching the metal, as I don't know what it's made of and therefore its effects on the metal under heavy condensation. Before and after temps may be the same, as some have said, but my A/C no longer has the warm/cold cycling. Cold all the time, now. $20 and about an hour of work, and I'm happy with the mod.
h-khunterkiller 10-04-2005, 09:55 PM I know their is a difference because mine is blowing condensation which never happen in the year I have had my car
Mantis 11-10-2005, 03:40 PM I have spent the time endlessly reading this post which is god-awful long. There is one think not mentioned in this post, and for those of you who are over this thread, just ignore this you crabby asses :cwm27: ....
I have never had my own Mazda, but my husband has a Miata. It sucks with the AC. I always thought that was because it was a soft top. When I got my 8 I was frustrated by the AC, not because of the coolness but the constant lack of air while accelerating. I felt that the AC system sucked in general because I didnt understand the Mazda. The 8 was my first new car and I was thinking luxury when I was thinking sports car.
When I mentioned this irritation with my husband he looked at me and said, "It's a sports car honey." All Mazda sportscars drop the AC at full throttle. So although the fan speed is cranked and the air coming out is cold, we manuals will feel a decrease in air during acceloration if you are driving the car like a sports car.
The Service guy at the dealer confirmed that the 8 has that same benefit that the Miatas have to keep it from losing power during a desired push. I have been straightened out and am a die hard 8 lover. I may have leather...cough cough plastic seats but I am a sports car minded gal now.
Who uses the AC anyway....
mikeb 11-10-2005, 05:18 PM I will have to try this but my AC is really good anyhow
dastallion951 11-12-2005, 06:19 PM so can u pick up that heat cloth at like any motorsports place??? or auto parts store??? im lookin to find one if not in riverside, ca then close to it, but hey 5-8 degrees minimum difference in riverside heat in the summer makes a big difference..... so if anyone can tell me a place that would have it, i would really appreciate it.
Razz1 07-09-2006, 02:36 AM So we ever get any final results from someone who measured before and after temps?
Close. I drove an hour to the RX club meet then we went up the mountain.
It went from 82 at the beech to 105 plus.
We compared temps. They ran 50 to 55 degrees, and when stopped at a light they would get 75 degrees.
I could not test in tow conditions at lights. Mine ran 48 to 50 degrees. Most of the time 48 degrees going up the mountain.
When I had a chance to get to 46mph it dropped to 46 degrees.
I suspect if I were on the freeway I could get 46 degrees.
So if you use the high temp fire resistant material you should get 1 degrees possibly 2. Note his high was 55, while mine stayed steady at 48 to 50.
Unfortunately we need a new thread to really fix the problem.
I checked the temp at the center consoule from the out side. It was 90 degrees!
The real fix is to insulate the cabin which is another DIY.
Two methods: One from the inside Second from the outside under the car.
I'm gonna check out the second. The culpate is radiant heat from the transmission and engine.
Don't ask about the cup holders. The temp in there seems like it could boil water. just kidding.
Shifty Devil 07-09-2006, 05:57 PM A/C systems will only drop a temperature a certain number of degrees, so even if it is operating at its best, as the input temp rises the output temp will rise accordingly. It is not going to put out the same temperature air at an ambient of 105 degrees as it would at 85 degrees, assuming fresh air input at both. I wonder if the frequent cycling of the compressor some cars are doing is a problem with an RPM/load cutout switch or something similar.
I would like to have better insulation in the car to block heat coming from the drivetrain and exhaust, but that sounds like a BIG job to do right.
dwynne 07-10-2006, 01:01 PM So if you use the high temp fire resistant material you should get 1 degrees possibly 2.
I am not clear on your test methodology, did you use 1 thermoment or 2? If 2, did you compare them in a single car to be sure they indicated the same temperature?
I would think a 1 or 2 degree differences would be within the error in most thermometes, and probably within the tolerances in between 2 car samples. In others words, if you checked 2 cars without wrapped pipes you might see 1 or 2 degrees of difference between the cars.
Dennis
Razz1 07-11-2006, 12:33 AM It was one thermometer. You missed the point. his was cycling 50 to 55, mine was almost a constant 48. His cycled 5 degrees. his peak was 5 degrees higher than mine.
While I did see 46 degrees as a low at 46mph his low was 50, thats's a 4 degree difference.
While a variance of 2 could be normal 4 is out of the range, what caused this? The heat wrap for dragsters. Don't use that garbage crap you read about.
alcimedes 07-11-2006, 12:48 AM Think I'll start with the ac amplifier upgrade first. Need to get the dealer off their asses with that already.
dwynne 07-11-2006, 10:26 AM I don't think the cycling is caused by lack or heat wrap - or having wrap on. I think that is the infamous "A/C amp" and that needs to be replaced.
In addition, I think the software "load" on the car can effect this. I swear after getting my car back from the gas tank recall - where I assume the insulated the tank and load new code into the car - that my AC now cycles off with a very slight hit on the go pedal. Before I would hardly notice it and wondered what folks were complaining about.
Dennis
Paul_in_DC 07-16-2006, 01:27 PM Nice mod Tigster :worship:
I tried this and it works. My A/C is noticably cooler now, even on a sunny 95 degree day. Instead of heat wrap I used pre-formed foam pipe insulation that comes in 6-foot lengths that you can buy in any hardware store. Total materials cost: $1.75
:D:
Speedtoys 08-20-2006, 04:50 PM there'a TSB for faulty AC amplifier, should be factory corrected on later production vehicles though. I think there's another TSB/flash update that delays the AC cutoff rpm point so it doesn't kick off so easily during semi-spirited driving (what most RX-8 owners would call normal)
Youre right, theyre not. They can save $1/car for NOT doing this plus the manpower to do it, times hundreds of thousands of vehicles, if not millions per year if you count ALL cars they make.
Does this make a difference? Yes, for the same reason you insulate this line for your home A/C, its all about efficiency..every BTU counts.
Does it matter enough to do it at the factory? No..typically if the air is "cold" people wont complain.
Its a simple $ to consumer-comfort equation, the manuf. isnt stupid. Just us for debating simple efficiency mods. Its a no brainer if youre looking to refine your car a little more.
farinj 08-24-2006, 12:17 AM Just my 2 cents. (I am actually an HVAC engineer licensed in NJ DE and MD.)
BTUH (Cooling Capacity) = CFM (mass flow rate in cubic feet/minuite) x 1.08 (constant) x delta T (change in temperature).
So if you do want to test this correctly you must do the following:
Buy parts to insulate.
Prior to installing parts record the following:
Record Cabin Temp, Record discharge temp (temp of air from vent), Record Outside air temp, and you want to do all of this after the engine is warm. Don't even turn the A/C on until the engine is warm. Use the recirculation mode and a specific fan speed say 3. Take readings every 30 seconds of both the cabin and the discharge for about 3 minites.
BTUH = (Cabin Temp - Discharge Temp) x 1.08 x CFM (who cares it's the same in both tests)
Insulate the pipe.
Then wait unit the cabin temp is back to where it was previously and take tests again just like you did before. Assuming the Outside air temp. hasn't changed in the 20 minutes it took to insulate.
The assumption is that the fan setting will produce the same CFM (mass flow rate) and the only thing that will change will be the cooling capacity BTUH of the compressor (actually the efficiency of the compressor).
Personally my A/C seems to work fine but the car seams to hold heat after it has been sitting in the sun all day. The $9 sun shades I bought at Wall Mart has made a dramatic improvement on that.
I like the idea of adding some insulation below the center consol I may have to give that a try.
dwynne 08-24-2006, 09:36 AM Yes, for the same reason you insulate this line for your home A/C, its all about efficiency..every BTU counts.
Actually, they normally insulate the lines to prevent condensation from forming (and dripping) on the suction line and prevent damage/injuries from the hot high side line. Also the lines in a home install can be many, many times longer than the ones found in an automobile. Under your hood, there would normally be no danger that someone would touch a hot line and the condensation on a cold line will quickly dissipate.
Again, the line folks feel under the hood that is COLD is the line coming FROM the interior of the car. This is not a chilled water system - it does not cool the interior by running a cold liquid into the car. It sends in compressed refridgerant (in liquid state) and that evaporating back into a gas is what allows your car to cool. So insulating the "cold line" is after the heat exhange has taken place so I would think little would be gained. The only advantage would be slightly cooler refridgerant presented to the compressor and would not have a dramatic effect on cooling the car. If you are going to insulate I would do both lines - to prevent the "hot pipe" from picking up more heat from the engine compartment BEFORE it enters the cabin on the car. I would think insulating THAT PIPE would have more effect than isulating the line that is coming FROM the cabin.
In any case, it is inexpensive to do and not much work and the placebo effect (if nothing else) will make you FEEL like the AC is working better :hahano:
Dennis
RX8Carnage 08-25-2006, 01:58 AM I found this wondering the web at night it looks easy have not done it myself but planning on it
http://www.hi-impact.org/ryang/modify/rx8_console/rx8_console.html
Muthafodder 07-08-2007, 09:44 PM I have several cars and IMO the problem with the AC is not the temperature, but the way it's ducted and the power of the blower. It needs more oomf. Because of that the air takes forever to cool down. Once again, I'm no expert and I have not measured the temperature, but the blower and ducting is seriously lacking.
This could go somewhere.....
I want to see someone put this heatshield stuff aroung all of the plastic tues that distribute the air into the car....much like you see on central heat and air in housing....probably would have a bad effect in winter though when you want hot air.
This thread is pretty heated...... :)
Vasichko 08-14-2007, 05:27 PM Finally got some time off from work, sitting at home bored so I decided to give it a try.
I had some Thermo Tec wrap here already.
Living in Dallas, TX, it is 101 right now. I took it for a drive to get the zip ties, just took it for a spin for about 15 minutes. I have measured the air temp at 9 degrees cooler.
Of course there may be some error in my methods, couldnt find my temp gun so I had to use a thermometer and stick it as far as I could in the center vent.
Speedtoys 08-14-2007, 07:05 PM This could go somewhere.....
Not a bad idea, just that the volume of air back there is pretty small, not like under a house or in an attic where theres a TON of surface area on the plumbing and tons of very warm summer air to steal it.
GatoEnFuego 08-31-2007, 09:09 PM This could go somewhere.....
Heat in a vehicle has nothing to do with the A/C lines...
I have just done this "mod" as living in AZ the summers are brutal, 111 today. I can't say it's a definate "oh my god it's soooo cold" result, but the good ol' placebo effect does tell me it's a bit better. $2 for the foam wrap (Home Depot Motorsports FTW), another $3 for metal tape (look next to the dryer vents) and 10 minutes it's probably worth the effort and would do it again.
ken-x8 09-01-2007, 06:25 PM Heat in a vehicle has nothing to do with the A/C lines...
Maybe not, but getting it out does depend on the lines. :)
IMHO, insulating the low line would help. The AC is a closed system that pumps heat out of the inside of the car and dumps it outside. Add heat anywhere to the system, and it's that much less heat it can carry from inside. Since heat flows from hot to cold, and contact area matters, insulating the large-diameter cold return line will keep under-hood heat from entering the system.
...$2 for the foam wrap (Home Depot Motorsports FTW), another $3 for metal tape (look next to the dryer vents)...
Thanks for the tip! I was thinking Home Depot myself, but not quite sure where to look.
VA isn't AZ - not by a long shot - but my AC was right at the limit during some of the 98 - 99 degree days we had here. Okay when moving, but a little shy when stopped at a light.
Ken
GatoEnFuego 09-03-2007, 12:18 PM I'm not sure you fully understand how our A/C system works, it does not pump heat or cold in/out of the cabin. It compresses the freon in the compressor which makes the freon hot, that is the hot line. Then it pushes that hot freon into the evap unit where it rapidly decompresses making the freon very cold at that point a fan blows past the evap "radiator" pushes cold air into the cabin. The cold freon then returns to the compressor, thats the cold line we're insulating and the process starts over. The reason I insulated the cold line is because it is much easier to access than the hot line and keeping that colder may help the overall efficiency. I'm still doubtful it did anything.
ken-x8 09-03-2007, 01:18 PM Yes, I do know how AC works.
Don't get too bogged down in the details, and don't view the components as unrelated. Overall, it does exactly what I said: it removes heat from inside the car and dumps it outside.
You picked the right line to insulate. How much good it does is another matter, but it definitely makes more sense to insulate the low side than the high.
Ken
Of course it pumps heat out. Otherwise, the heat would stay in! Any AC unit is a form of heat pump. What you think of as "creating cold air" is actually the removal of heat from hot air.
You've got that jumbled a bit. The hot freon goes to the condenser, where it *dumps a lot of heat* into the outside air. It then travels into the dash, to the evaporator, where it expands rapidly and absorbs heat in the process. Air is blown over the evaporator and the heat from that air is transferred into the evaporator and into the freon, which carries it away. The air that comes out is therefore colder.
The reason to choose the cold line over the hot line is Newton's Law of Cooling, which states that the rate of cooling (or of heating, which is the inverse), is proportional to the difference in temperature. Therefore the cold line will accept much more heat from the engine bay per second than the hot line. You are wise to be doubtful of the effect, because the thickness and relative shortness of that pipe means that the heat transfer is modest. But I still did the mod anyway :). I had far more of an improvement from reprogramming the amplifier.
ken-x8 09-03-2007, 07:10 PM The hot freon goes to the condenser, where it *dumps a lot of heat* into the outside air. It then travels into the dash, to the evaporator,
Don't forget the state change: turns to liquid in the condenser ("condense"), dumping heat, then back to vapor in the evaporator ("evaporate") absorbing heat.
Without latent heat of vaporization, air conditioning would be really difficult. As would cooling off by sweating or panting. ;)
Ken
For reference.........
Who knows the correct capacity of the A/C system........??
Most cars are around the 750-Grams mark, unsure of the R-8
Say it was 750-Grams. How many more grams of R-134 would it take to trip the "high pressure" switch in the circuit.
REgards
jessedrifter 04-07-2008, 11:14 PM what about using tin foiL????
ahaah
firebirdude 04-14-2008, 04:07 PM Surely this has already been noted, but guys have been doing this or similar to this for years. When I owned my Firebird, people wrapped the entire condenser. If it was exposed, it got wrapped. We used a thinner self adhesive type stuff. Don't remember what it was. Used refrigerator thermometers in the vents to measure the difference. Solid performance mod.
Razz1 04-15-2008, 12:52 AM Tin foil don't do crap. Use the real stuff drag racers use to prevent a fire.
That will work.
Scappini 06-16-2008, 05:16 AM I going to do it for the extra 100 hp :)
XDEEDUBBX 06-16-2008, 06:09 AM here's a snap of mine...did the ac wrap back in 2004...
http://i30.photobucket.com/albums/c336/XDEEDUBBX/6.jpg
jea1989 06-20-2008, 06:10 PM ok so ive read this whole thing and gotten nowhere...
all i wanna know is where. in town. i can buy the proper heat wrap material.
not expensive. not being shipped. right in a normal place.
TeamRX8 06-20-2008, 06:39 PM buy a box of pampers and a bag of ice, that will be more effective than wrapping the frosty pipe ... :lol:
Spinning Sushi 06-20-2008, 06:53 PM I used carpet insulation, warped it around the AC line, and put foil over it.
champi0n 06-20-2008, 09:27 PM I thought I had an AC problem because i could feel the "cycling" going from cold, to not so cold.
Plus while it does help cool the car relative to blistering heat outside... every other car i've had would give girls hard nipples and goosebumps.... the rx8 ac however does not. :(
Spinning Sushi 06-20-2008, 09:28 PM Yep, our car's AC suck... it's weak as hell.
MazdaManiac 06-20-2008, 10:52 PM Who knows the correct capacity of the A/C system........??
490 grams.
Razz1 06-20-2008, 10:56 PM How much per gram?
MazdaManiac 06-21-2008, 02:50 AM How much per gram?
I suppose 1cm^2 before it sublimates.
laythor 06-21-2008, 05:04 AM after reading this whole thread and the "reprogramming thread" I just want to kick a puppy.
fyi, i have some magic beans for sale
dam...well my lady was complaining that the ac wasnt as cold as she would like...so since i felt bad telling her to suck it up since shes caring my baby boy in her stomatch. had a buddi supply me with some carbon fiber sheats and i insulated the ac pipe...i dont knowthe technical shit about all this but is seems to be colder...and she hasn't complained.... by the way...i used carbon fiber because 1. it was free, and also cuz someone told me it deflected heat...this true???
04RX8man 08-09-2008, 05:21 PM yeah thsiis def a great mod to do
Steady, Jack. The reprogramming actually makes a huge difference, if you have the applicable "amplifier".
laythor 08-10-2008, 01:11 PM you and I have a different definition of the word "huge"
firebirdude 08-10-2008, 07:34 PM That's what she said
TeamRX8 08-11-2008, 01:41 AM adobe clay works much better, those indians weren't stupid you know ....
Not necessarily. Note, I said "if you have the applicable amplifier". In my case it was (Jan 2004 build).
This was no placebo. I went from a system that could barely keep up with low-90's temps with fan at max and recirculate, to where I am comfortable with fan at 1 up to about 85 degrees, fan 2 will take me into the mid 90's. I recently drove through 116 degree temps and was switching back and forth from fan4 to fan3, max fan was just too cold after awhile.
In short I went from an AC that was basically uncomfortable on an average summer day, to one that has more than enough cooling for scorching temps. So, does that sound like a huge difference to you?
In my zeal to "fix" the lame AC, I wrapped the pipe and made the programming change at the same time. Logically I don't think the wrap contributes much but there you are. No other changes were made.
Nopstnz8 08-23-2008, 12:37 PM I just did this with some Thermotech Thermoshield by cutting it into small strips lengthwise. My problem is that it isn't staying stuck down completely. When I turn on the ac, it will not stick as well, but it will still stick a little. What can I put over it to fix this issue? Thanks.
laythor 08-23-2008, 01:52 PM zip ties
Nopstnz8 08-24-2008, 01:21 PM So put zip ties on every single strip?
krijpipudht 04-30-2009, 11:08 PM Summer is coming up.
There is still debate if insulate AC pipe helps or not.
But the project cost $2.5 and 5 mins, it worth a shot.
I use pre-slice, peal and seal insulation foam tube, designed hot water copper pipe.
One insulation foam tube from Home Depot is 2 yards, cost around $5 &
can be installed for 2 cars.
Peal and seal. No zip tie.
Planing is 10 mins, and you can skip this.
Installation is < 5 mins.
Picture is pretty self-explanatory.
Note: Length of the tube will change a little if tube diameter change.
Better engine bay view coming up. I just took a snap shot with my phone.
nuke0907 04-30-2009, 11:14 PM looks much better than zipties. i might have to try this out.
LoudxB 06-01-2009, 12:28 PM Summer is coming up.
I did it this way and didn't notice any difference. The heat transfer from that pipe is minimal. Cost me $7 and 15 mins and didn't hurt the car so go for it!
StealthTL 06-01-2009, 12:50 PM I did it this way and didn't notice any difference. The heat transfer from that pipe is minimal. Cost me $7 and 15 mins and didn't hurt the car so go for it!
By the same logic, why not paint it a soothing shade of cool blue?
No difference, didn't cost much and can't hurt?
Go for it.
S
KyGeezer 06-27-2009, 03:13 PM Uninsulated AC tube: 62.4-62.7 degrees...engine at normal operating temperature and 1500 RPM when AC turned on...using outside air at 84.5 degrees...fan speed on 1...77% humidity...car parked in shade.
Insulated AC tube: 54-56 degrees...same conditions 2 days later. It took awhile to get the temp down because the compressor kept cycling on and off when the air temp got to 62. It seemed like the compressor was engaged less than half the time.
[Temps were measured with a little SkyScan Atomic Clock. It agrees within a fraction of a degree with a couple of other Atomic Clocks I have.]
The insulation: Armacell foam hot water pipe insulation. Home Depot item #803014117517. Set me back $1.46 including sales tax. HD sells it in 6' lengths. The display box says it's 5/8", but the inner diameter is a 16th larger so it isn't a tight fit. The outer diameter is 1.25". The wall is 5/16" thick. The surface is not totally smooth, but it's dark gray with a slick finish and I think the color looks nice in a TGM engine bay. HD also sells a black foam insulation without a slick finish that would collect dirt fast and be tough to clean unless you could find something to seal the surface. Multiple very light coats of clear spray lacquer?
The instillation: It was a bit of a battle with some swearing and was done in sections. This thick walled foam insulation does NOT like being bent and I probably got more Super Glue on my fingers and palms than the seams and joints. Acetone, fortunately, is a great Super Glue solvent. There is a 7" strip where I had to cut a slot in the Armacell because the AC pipe is too close to the firewall insulation to get the Armacell around the pipe. Also had to use some spray detergent on the firewall to get the insulation around the pipe in another spot. I used electrical tape on the joints in an effort to keep hot engine bay air out.
Kudos to Tigster for suggesting the MOD!!! It never would have occurred to me. I wish I'd done the MOD on my black IROC and my arrest me red Z28 with a black roof and huge amount of glass.
firebirdude 06-27-2009, 06:06 PM Great post. But does it translate into colder air blowing on me? Use your equipment to measure that. :)
laythor 06-28-2009, 04:01 AM I'm going to start selling my polar bear repellent. 1 dollar + s & h, never get attacked by a polar bear in your home, guaranteed.
Paradox 06-28-2009, 09:27 PM After several years of thinking about doing this mod, I bought some "Cool Tape" by Design Engineering, Inc. and wrapped the tube that others have suggested to wrap in this post. I used "Cool tape" because it is extremely thin and there isn't much room between the back wall and the tube. I used forceps to apply the tape, it's hard to use your fingers. It took me about 15 minutes to do.
I don't know if it makes the air colder as I didn't measure, but comparing back to back on identical days I definitely noticed a difference. Most importantly, during city driving, I could turn down the fan speed one setting below what I would usually use to achieve and maintain the same comfort.
The "cool tape" was $20 and looks like webbed aluminum when finished, a clean look. Do this mod!
gabrod72 07-28-2009, 03:58 PM Afterr eading this thread it is apparent there are strong feelings on both sides. Is it a waste of time? Is the analysis of the engineering dept. a correct one?
Well, like elbows, I've got two and I've been known to be an even bigger one. Sometimes in product development there comes a time when you have to "fire the engineer and ship the product."
Funny how everyone forgets what is at the heart of a placebo..... it "fools" you into thinking you're getting cured. What most forget is that sometimes people heal themselves unexplicably (and some on placebo.) Could it be that they just needed to "feel" they were getting better so their body would kick in and heal?? Dunno, I'm not a doctor.
As for the mod here's my .02 - MY AC SUCKS so I will try it. My friend has an AC Master's licence and was formally in the electronics field where he worked on some contained liquid cooling systems for processors before starting his own business. My cost for the armorflex insulation = $0.00! I'll just re-use some old one off a house that got new stuff.
Hopefully I won't get friggin critiqued for "WASTING" 10 minutes of my life trying this. It's been over 100 for many, many days around here in Texas and the AC in my 1993 POS Grand Cherokee feels much better than the RX-8. While I'm at it, I will check the Cabin Air Filter also but I'm not sure this will have much to do with it as the CFM at the vents seems fine. Funny, I don't remeber seeing any mention of the CAF in this thread but maybe it was because I was skimming?
rodjonathan 07-28-2009, 04:01 PM i actually just did this and am yet to try it out ... will post here if i notice any change
SPHINX144 07-28-2009, 04:43 PM hmm... I'm somehow dubious this procedure will yield the claimed results. Perhaps the colder A/C temperatures was due to different atmospheric conditions--clouds, cooler day, less humidity etc-- or perhaps the temperature variance was falsely perceived by the subject, ie it was all a placebo effect.
bureau13 07-29-2009, 11:40 AM It would certainly be easy to set up controlled before-after test. Not as easy as doing the mod and NOT testing of course. Then again...if the mod does nothing but make people feel like they're cooler maybe that's good enough!
I'd try it but..my AC worked fine before it stopped working completely. No amount of pipe wrapping can help me now!
jds
SpIcEz 07-30-2009, 01:46 PM I have a natural way of getting colder A/C.
The Nature MOD.
While driving in the country at midnight with your wife and 6month old in the car and still 1h30mins to go on your trip...
1. Hit a Racoon at 125km/h on the road.
2. Inspect damage
3. Rip off front lip and complete undertray
4. profit... uh I mean COLDER A/C.
:wiggle:
lepichichi 08-01-2009, 02:43 PM Summer is coming up.
hey man i did mines like yours last week and i couldnt be happier, thanks!
krijpipudht 08-09-2009, 07:03 PM ^
You are welcome.
This mod is only necessary for Left Hand Drive Cars..
RHD 8's have "plumbing" on the same side as the compressor and evaporator, therefore they don't have the pipe that goes over top of engine left to right.
Butters 01-19-2010, 03:27 PM After all this time, no one has decided to find some definitive results by measuring the temp of the air blowing into the cabin before and after the mod?!
longpath 07-13-2010, 03:08 PM I am debating this modification due to my car's AC becoming temporarily non-functional under the following conditions:
100F/37C ambient
3.5 hour highway trip across 4 states in the US (CT, NY, NJ, & PA)
daughter (2.5 years old) fell asleep half an hour before my wife, daughter, and I arrived at our destination
our room was reserved under my wife's name so she insisted that while she got us checked in, my daughter and I stay in the car with the engine running in order to keep the air conditioner running
coolant temperatures reached 243F/117C according to my ScanGauge II
My only cooling-related modification to date was switching to Evans waterless coolant late last Summer.
My RX-8 is a late 2004, made in June of '04 and purchased in October of '04. I am the original owner. I do not know if the amplifier was upgraded or not prior to my taking delivery of it; but it did not happen while the car has been owned by me.
I tried the "reprogramming" sequence this morning; but the blinking of the rear defroster indicator that was supposed to show that the reprogramming was successful never happened. I made five attempts, following the steps from the forum to the letter, failing every time.
If I implement this process, I will perform before and after measurements. I am also considering wrapping the OEM header to reduce under hood temperatures, and opening up the front fender well thermal exhausts for the oil coolers (I should mention that it was hot enough that my tyre pressure climbed to over the 42psi that my gauge could read and tripped the tyre pressure warning light on the dash).
FastFreddy61 07-13-2010, 04:09 PM We have an 04 6speed, the aircon works so well,after about 10 min driving on the autocest (Hiway),at around 180 k's,the air is so cold it exits the vents looking like steam, scared the crap out of me and the wife the first time it happened.
longpath 07-14-2010, 05:34 AM My main concern is not AC when on the highway. It's when the car is idling. I'm wondering if the problem I'm seeing is more a matter of whether the fans aren't able to move enough air through the engine bay when the car is stationary and the AC is running. Could the refrigerant be seeing such high temperatures at the condenser, that it is remaining a gas? If so, perhaps a more powerful fan and/or relocating the battery and switching to the Mazdaspeed intake might improve airflow in the engine bay. Given the angle of the fan and the sandwich of the condenser and radiator, I'm debating a vented hood/bonnet as well, if I could get one where the vents lined up with the direction of air flow.
longpath 07-14-2010, 09:07 AM After looking at this page on the HVAC system:
http://isomerica.net/~fluffy/Ren/RX8%20FSM/10Hvac.pdf
I am wondering if I might want to insulate the return line from the condenser to the compressor. Bear in mind that the time that I had a specific failure, where even on recirc the AC was blowing hot air, the engine coolant temperature had spiked to 243F/117C and the ambient temperature was at 100F/37C. Now I am also hypothesizing that I erred in letting the engine idle instead of bringing the revs to 3000 r.p.m.; but I think that would have only made the difference between the air emerging from the vents as cool instead of cold, not actually hot. I don't know what the temperature was at the vents; but I would say it was at least 80F/27C and very likely significantly warmer than that (if I equate it to water temperatures, the air emerging from the vents felt as warm as any jacuzzi I've ever been in). I am going to get a refrigerator thermometer and keep a log of temperatures (coolant, ambient, and vent).
When I saw something similar starting to happen again last weekend, I opened the hood/bonnet while the car was pulled over and parked. This kept the AC running acceptably well while I was waiting for my wife and my daughter and I waited in the car.
laythor 07-14-2010, 09:52 AM i hate this thread.
If your AC is weak the first thing you should be doing is checking that you have enough refrigerant in the system.
At idle the compressor spinning slowly and the lack of air movement make the AC less effective.
Wrapping these lines is a placebo
Highway8 07-14-2010, 10:47 AM i hate this thread.
I agree but I disagree.
yes if the ac is not cold you have a problem, and at idle the ac is not going to be very effective.
However, insulating the lines doesn't hurt, and it's actually fairly common for lines to come insulated from the factory, usually when near a heat source. Because the mentioned lined on our car is not near the exhaust or cooling system mazda felt insulating it was not needed.
IMHO, test it. If it makes the ac colder, then great. If not, then lesson learned.
longpath 07-15-2010, 10:42 PM I agree but I disagree.
In my own case, I was thinking of insulating the low pressure line between the condenser and the compressor, which is, in my opinion, exposed to heat from the radiator.
I am also considering insulating the line that goes over the engine along the firewall because the instance where my AC was completely inoperative, my engine's temperatures were climbing through the ceiling (I regard 243F as extremely high).
I don't know if the problem was that a stable bubble of hot air in the engine bay is preventing air from flowing through the condenser or if the problem is due to the compressor being unable to overcome the load of pressurised refrigerant having its pressure increased even more due to extreme heat in the engine bay. I don't know enough about the design of the compressor to even know if the latter conjectured scenario is even possible (HVAC engineers, please feel free to chime in here).
I purchased a thermometer with a long probe to let me monitor the temperatures in the centre AC vents. I have observed temperatures ranging from 47F to 55F. On my drive home this evening (19:15 EDT - 19:30 EDT) at ambient temperature of 80F, the vent temps showed as 47-53F. Intake temperature stabilised at 100F and coolant temperature was about 200F most of the trip home. The car was in a concrete parking garage all day, so it was not exposed to direct sunlight. I set the AC to re-circulate.
I am taking these initial measurements to establish a baseline of what the AC can actually do. Once I have some more readings, I'll insulate the lines I indicated above and then take new readings to compare. I will, in particular, take readings before and after on the actual day the modification is made, so that hopefully we can finally determine if this is mere placebo or actually achieves some detectable benefit.
longpath 07-15-2010, 10:53 PM Assuming the whole real issue is nothing more than inadequate airflow through the condenser when the car is not moving, is there an aftermarket fan that moves more air and will fit?
laythor 07-16-2010, 01:04 AM or just realize the AC will be so-so at idle
longpath 07-16-2010, 05:44 AM or just realize the AC will be so-so at idle
"so-so at idle" would be an improvement over hot like a hair-drier. Hot like a hair-drier is what I observed and what I am trying to work around. If I can get it to be only "so-so at idle" I'll be quite happy.
It works perfectly well when the car is moving. My problem is when the car is stationary. If you have suggestions on how I might correct that, feel free to make them; but accepting the current situation is not an option and neither is moving further from the equator until Summer is over.
Opening the hood/bonnet does work. Does anyone have any suggestions on how I might achieve the same result without having to get out of the car? That's why I asked about the possibility of an aftermarket fan. I did not mean for the ventilation system. I meant a better fan for the engine bay, radiator, and AC condenser.
Highway8 07-16-2010, 10:47 AM "so-so at idle" would be an improvement over hot like a hair-drier. Hot like a hair-drier is what I observed and what I am trying to work around. If I can get it to be only "so-so at idle" I'll be quite happy.
The ac stopped working on you because the ect were too high. The ecu might have done it automatically or it was just a result of heat. Adding another fan is not a good option, the stock fans flow plenty of air. You need to address the overheating of the vehicle. Over 240 is tooo hot at idle, it's too hot period. I see you changed to evans npg. Is that the NPG-R? Remember the car will run warmer with it but you shouldn't be 240w at idle.
Check all your basics first. Good rad cap? Make sure there is no air in the system including the heater core and of course that it's full but not overfilled.
If it checks out, go with upgrades. Battery in trunk and AEM for better air flow, BHR or mazmart radiator, mazmart pump and t-Stat.
longpath 07-16-2010, 09:07 PM The ac stopped working on you because the ect were too high. The ecu might have done it automatically or it was just a result of heat. Adding another fan is not a good option, the stock fans flow plenty of air. You need to address the overheating of the vehicle. Over 240 is tooo hot at idle, it's too hot period. I see you changed to evans npg. Is that the NPG-R? Remember the car will run warmer with it but you shouldn't be 240w at idle.
I'm using NPG+. I'll double check the levels and see if air has gotten into the system. The radiator cap and thermostat are original (the care is from 2004).
I'd also been thinking of applying Ash8's front fender liner mod to increase air flow through the oil coolers. The day I saw the coolant temperature spike, the air temperature was 100F and I'd been driving on the highway for about 3 hours beforehand. I'd spent another half hour in stop and go driving before arriving at our destination.
Thanks Highway8!
Highway8 07-16-2010, 10:19 PM I'm using NPG+. I'll double check the levels and see if air has gotten into the system. The radiator cap and thermostat are original (the care is from 2004).
Thanks Highway8!
Air should not get into the system unless you have had hoses off. Easiest sign you have air is that the ECT are very erratic, big temp swings and you can also hear water moving from inside the car. Be sure to turn the heater on so it circulates through the heater core.
I have doen the oil cooler thing too. It makes a small difference with oil temps at free way speeds but not when going slower and the ect wont really come down if at all.
You should be using NPG-R, it has a higher viscosity and will do a better job of removing heat. Although evans npg is not needed unless you are tracking the car a lot.
5 minutes or 5 hours on the freeway wont make much difference. I have a supercharger with the intercooler on my car blocking air flow and I was driving freeway and stop and go the other day in 100 deg weather and I never went above 210. You have another problem if you are seeing 240+deg anywhere except the race track.
If I was you. (assuming the fans work fine and there is nothing leaking on the car), i would get a mazmart t-stat and waterpump, a new radiator cap and new coolant. Evans npg-r or just regular coolant for 1/3 the price. Drain the system (drain out the block), replace the pump and t-stat. Fill it up, make sure the air is out and the system is full and go from there.
olddragger 07-17-2010, 09:15 AM you need a secondary radiator installed AFTER your primary system is working properly.
That helps everything including the a/c
OD
Mazurfer 07-17-2010, 09:21 AM Wait........let's make that more clear Denny.
"AFTER your primary system is working properly". :yesnod:
Razz1 07-17-2010, 10:11 AM Well if it's not this thread it was anotherone and I believe it was in the DIY section too.
I tested this with a thermometer and compared it to other RX8 memeber on the same day same time during a club run.
My system was consistantly cooler from 2 to 4 degree's.
Remember you need to use the fire retardant material from a race shop. The other crap doesn't work.
Since it's a 2004, its time to flush your A/C sytem and replace it.
In the early days.. many members reported having the AC system only 80% filled from the factory.
And yes... once you get over 90 degrees the system begins to degrade. There is nothing you can do about that. The car runs 2.5 times hotter than a piston engine.
You can raise the back of your hood with a couple of washers. Look for the DIY on that.
laythor 07-17-2010, 08:14 PM 2 to 4 degrees? someone fetch me a coat! :)
TeamRX8 07-17-2010, 08:26 PM I agree but I disagree.
I heard the same thing about having an index finger shoved up your butt. Let us know what you find out ....
HiFlite999 07-17-2010, 09:11 PM I heard the same thing about having an index finger shoved up your butt. Let us know what you find out ....
Talk about thread crapping. :icon_bs:
I've found insulating that pipe useful (though don't use water pipe foam unless you like the smell of melting urethane). However it won't have any positive effect on your engine cooling. I think the Mazmart water pump is a more effective water mover which seems to help, since I've had none of the issues I had last year with the stock. But I doubt if minor fiddles like that are going to help much in those extreme circumstances. There are many threads on the subject - and not that many successful fixes.
longpath 07-18-2010, 08:14 PM I'm not convinced that both my fans are working properly, so I will be investigating that. For one thing, the only time I run into trouble is when the car is not moving, and the same car, two Summers back, had no issues with being stuck in traffic and going nowhere. Also, the fans seem quieter than I remember (though maybe I'm losing my hearing since my toddler loves to scream out of the blue). I'll verify that the airway for the radiators are not blocked, that the fans aren't jammed, that I don't have a blown fuse (G_d, that would be embarrassing), and that I can make the fans run when connecting them directly to the battery.
After I get everything working properly, then I'll look into these and report my findings, before and after. I apologise for the unintentional thread-jack.
laythor 07-18-2010, 11:05 PM Talk about thread crapping. :icon_bs:
it's not crapping when it's true
As Razz pointed out in another thread, Check your FAN MOTORS, if they are not spinning correctly your Cooling system and your Air Cons will suffer...BAD.
Sorry to point this out again, BUT, Mazda did Upgrade the two electric motors in the Series 2's for a REASON, the two Fan Blades are still the same , but the fan shroud is different for the new motors.
You can purchase a new FAN Shroud, Fan, Bolts and Motor SET from a Series 2 for $366.00, or individual parts for a little less, but you have to assemble those.
It would be interesting to see one fitted to a Series 1...to confirm the fit, but I can't see why it would not install.
olddragger 07-19-2010, 09:47 AM you are the Man again Ash! Thats good to know.
OD
OD Sent you a Hotmail....
On the fans...The FAN BLADES (not Motors) Date back to 1997, and one of these two were first used in the 626 and some 323's and Premacy or Mazda 5 1999-2001.
The 2006~ Tribute uses these RX-8 Fan Blades (both of them).
Tribute also uses the S1 RX-8 Electric Motors (one of them)...the 626,323 use a different electric motor.
So, to me this proves the ELECTRIC Motors are the KEY to cooling performance, reliability and RPM speed of these same FAN Blades used in ALL series RX-8's.
IMO, the upgrade to the Series 2 Motor, Fan and Shroud SET would be a definite Mod to do..
BTW, YOU MUST Replace the Shroud, as the new Series 2 Electric Motors appear larger and mount with different screws on the Shroud.
BTW2, The Series 2 RX-8 FAN MOTORS are Not Used in ANY other Mazda, they are Model Specific and ALL New.
Razz1 07-19-2010, 05:40 PM Unless you attached the wrong picture... the motor is the same part number but the pitch of the blades are different. Hence new part number.
And don't forget.. above 90 degrees the AC system starts to gegrade pretty fast even with the mod.
The New Part Numbers are for the Motors NOT Fan Blades...please READ again:)
ALL Correct with what I have shown...the Fan Blades are the SAME part Numbers for BOTH Series.
The Numbers Shown are Not Part Numbers, but Description Part Number Code, you then look up actual part number from the codes 5 or 6 number/alpha.
Mazda try to use same codes for ALL their cars as it Does represent "PART" of the PART Number in most but not all cases....in this case of the S2 Motors the Full Part Number is N3R1-15-150.
I can also assure you the part number for the Fan Blades are ALL the same, even though in this instance the sketch shows the blades free of the shroud and diff pitch when compared to S1..it also does not show the fan nuts like the S1 does. I am sure they are there but been overlooked in S2 EPC, It can and has happened before, can show you many between the two Series. ;)
Obviously around 6 years between the graphic work done by Mazda for their EPC's on both series 8's.
TeamRX8 07-19-2010, 08:17 PM Sorry to point this out again, BUT, Mazda did Upgrade the two electric motors in the Series 2's for a REASON
Yes, but what specifically was the reason? Was it performance, cost, availability, supplier change etc etc.?
Unless you know the specific parameter differences between the fans you're just taking a wild swag. Larger and different only means that. You can't assume it means anything else without the facts to back it up.
Razz1 07-19-2010, 09:04 PM Well... I could assume they're bigger... mu ha ha....
Oh, thanks for the clarification on the sketches.
If the pitch of the blade is greater, it will push more air but will take more power, hence the bigger motor.
It's not cost availabity or supplier since all the other Mazda used the same old part.
So that eliminates alot of reasons.
The "Pitch" of the Fan Blades as you put it has not changed...there are the Exact Same PART Number for ALL series RX-8's and as I pointed out through part number model 'codes' these Exact same FAN Blades were first used back in the 1997 626,323 and 2006 Tribute.
For the 3rd time it is ONLY the Electric Motors and the Shroud that Has Changed in S2, the FAN Blades are the Same as S1..
The S1 has a Left and Right Motor of Different Part Numbers, in the SERIES 2 Both Electric Motors are the same New S2 specific Part.
S2 N3R1-15-150 Motor (2) Left and Right.
S1 N3H1-15-150 Motor (1) Left
S1 N3H2-15-150 Motor (1) Right which Changed to a RF1S-15-150 (Right) at Production Date 1st June, 2008.
Geez...
In the 2009 Service Highlight it says...
"Electric cooling fans No.1 and No.2, which operate according to the fan control signal from the PCM, have been updated."
In my 30 years with Mazda they Change a part in a Series 2 Upgrade like all the other 60 plus Non Interchangeable NEW PARTS for a "Technical Reason", virtually ALL updates/upgrades in ANY of their cars are done because of Reliability and Warranty Claims from ALL around the World over the life of the first Series of any Generation Mazda.
Just like the Series 2 2010 NC MX-5/Miata, there are nearly as many changes for the same reason.
The Series 2 RX-8 also has an additional Cooling Fan Speed making it 3 where the S2 has 2.
I don't give a Rats Testicles what you think...:eek:
longpath 07-20-2010, 05:50 AM The Series 2 RX-8 also has an additional Cooling Fan Speed making it 3 where the S2 has 2.
Would the variation in motor speeds available in the new motors introduce a compatibility issue if I installed the S2 motors and shroud on my S1?
TeamRX8 07-20-2010, 09:13 AM Yet you still can't claim ant knowledge what the actual difference is other than there's a 3rd speed, not what any of the justifiable differences are. For all we know if you don't have that 3rd speed capability you may not see anything to justify the expenditure. Whether you give a rats ass or not about what I think is irrelevant. It's just common sense to understand the specifics before you leap, not personal.
If the fan blades are unchanged then the only way for them to operate differently is the revolution speed. All I'm asking is that if these parts are installed on an S1 as was suggested what will the operational differences be? I can't see a 3rd speed operation being possible without a software and/or hardware change also being done.
longpath 07-20-2010, 09:51 AM Are the actual rotational speeds of either the S1 or S2 motors known? Are the electrical connectors for the S1 and S2 motors the same?
If my S1 PCM can only trigger the slower 2 of the 3 S2 motor speeds; but I can wire in a switch and/or timer to trigger the 3rd speed, I'm ok with the extra hassle; but I don't have an S2 shop manual with which to compare the connectors and wiring diagrams.
This REAL issue is not So much the Speed which is controlled by the Additional Relay Now 5 in the S2, the S1 has 4 of the Same Relay's in Fuse Box.
THE ISSUE is there appears to be a "Wearing out" or "Slowing Down" of S1 Fan Motors with Age...There is more than one person who has replaced a motor.
Obviously IF YOUR FAN MOTORS are Slowing Down, they are NOT Cooling.
Lastly...and FINALLY.
Cost Justification..
What would you rather do, Purchase the TWO S1 motors at $159 and $166 Each, total..$325.
Or the S2 N3R1 Motors at $59 Each??, plus the shroud at $92 plus $8 motor Bolts, so
I make that a total of $220 for a complete S2 upgrade.
NOT MUCH MORE THAN JUST ONE S1 MOTOR!
BUT YOU WOULD SAY MAZDA HAVE CHEAPENED THE S2 MOTOR..Wouldn't you?
The Motors in Both Series RX-8 are Variable speed types...speed is varied by PCM and Relays in Hood Fuse Box.
And thanks, you are correct, I can not confirm IF the Wire Connectors are the same from S2 motor to S1 Wiring Loom...I should take my car apart and find out...or someone else.
BTW..Here is the S2 Wiring Diagram for the Relays..it is the best I have. I don't know how you are going to Control or "Fool" your PCM, as you know in S1's the Coolant Temp Controls FAN Speed, from Temp Sensor (Behind Water Pump) to PCM, Relays, Fans., Plus your Air Con Switch and Refrigerant Pressure Also controls Fans.
Another motor failure...
http://www.rx8club.com/showpost.php?p=3642704&postcount=9
longpath 07-21-2010, 05:26 PM BTW..Here is the S2 Wiring Diagram for the Relays..it is the best I have. I don't know how you are going to Control or "Fool" your PCM, as you know in S1's the Coolant Temp Controls FAN Speed, from Temp Sensor (Behind Water Pump) to PCM, Relays, Fans., Plus your Air Con Switch and Refrigerant Pressure Also controls Fans.
I'm still comparing the diagrams to see if it's possible to rig an interface so that my S1 PCM will trigger the 1st and 3rd fan speed, leaving the intermediate one unused since my S1 PCM only knows two speeds. I don't know if this is possible yet; but that is what I am trying to figure out now.
SayNoToPistons 07-24-2010, 04:06 AM How do i check the electric motors? I do have some concerns because I have driven my RX8 short distances on days where the ambient temperature is over 95 degrees. I did grandma my RX8 though. I have NEVER (EVER) heard the fans come on for my RX8 after I have turned the engine off. Even yesterday during a local RX8 meet, i heard two RX8s with the fans on after the engine is turned off.
It says in Service Highlights (Series 2) that the default or safe mode for Cooling Fans occurs if and when Coolant Temp Sensor fails, I see no reason why this would not be the same for all RX-8's as they have the same temp sensor.
The sensor is at the rear of your Water Pump, I have not tried this, But, if you can get to the sensor wiring Plug and DIS-connect it, it should put your fans in fail safe mode...in other words on High, you should also have to have start car or Ignition ON.?
From Factory WS Manual..
COOLING SYSTEM CONCERNS - OVERHEATING....POSSIBLE CAUSES..
Improper Coolant Level
Blown Fuses
Coolant Leakage
Excessive A/C system pressure
A/C system operation is improper
Improper water/anti-freeze mixture
Fans Reverse Rotation....HUH??
Cooling Air Passage to Radiator Blockage
Poor Radiator Condition
Thermostat Malfunction
Radiator Hose Damage
Improper or Damaged Radiator Cap
Cooling Fans are Inoperative
Coolant Overflow system Malfunction
Improper Tension of Drive Belts
Drive Belt damage
Eccentric Shaft Bypass Valve Malfunction (stuck closed)
TeamRX8 07-24-2010, 09:43 AM The Motors in Both Series RX-8 are Variable speed types...speed is varied by PCM and Relays in Hood Fuse Box.
What I wouldn't do is make a blanket recommendation to go spend several hundred dollars on parts without being sure or knowledgable about it. You keep replying back at me like I'm some idiot riding your ass, but this admission wouldn't have come out if everbody just oooohed and aaaahed rather than ask some simple, logical questions.
Variable speed is irrelevant to my point. I would still recommend trying to find out what the net differences are before proceeding with any parts swap. You clearly haven't done this recommendation i.e. no direct firsthand knowledge with it just something you read coupled with assumptions, like assuming the S1 fan signal will generate equal or faster fan speeds with the S2 fans.
You will need to know all the intimate details between the two systems to assess whether a parts swap recommendation is worthy. The literature and arguments you've provided so far don't accomplish this. Maybe somebody will go out on a limb to drop the cash on the parts and prove you right, but if you're wrong it's not your money down the drain.
Stop acting like this is personal because it's not. I'm only asking for people to use some common sense before they leap. If right your ego has nothing to fear from a few simple questions
I am not talking to YOU am I, so don't include a REPLY or Quote to someone else in your "Comment" as IF I am talking to you because I am not...
I have said there is a COST Benefit...Work it out...
I have already ALSO said I can't confirm the wiring PLUG connection...
Both series have 120W motors, the ISSUE is the S1 Motors are slowing and or failing..
Someone will "try" this soon, I will put my ego at 97% correct...
BTW: What more "intimate" details would you like to Know????
Both Series use 120W Motors..
Both Series use the Exact same fan speed switching Relays and Fuses...
Same Temp Sensor, same Fan Blades..
SayNoToPistons 07-25-2010, 05:49 PM It says in Service Highlights (Series 2) that the default or safe mode for Cooling Fans occurs if and when Coolant Temp Sensor fails, I see no reason why this would not be the same for all RX-8's as they have the same temp sensor.
I will try that as soon as possible. Thanks for the information.
Had a quick "physical look", you will have to remove your alternator (at least) to get o the temp sensor plug as it is not visible to the naked eye...
See attachment for location..
longpath 07-25-2010, 07:15 PM Has Mazda published specifications for the rotational rate that should be expected respectively for the S1 and S2 motors? I didn't find them in my shop manual (maybe mine is obsolete) but instead found the seemingly insane instruction to make sure that they aren't rotating backwards. Is this something that they realistically could malfunction into doing?
Yes, I was surprised to Read that "an Overheating Condition" in the S2 WS Manual could be the Motors/Fans Running Backwards!!...which is somewhat concerning as you would hear your fans running but are they going in the correct direction??...you would have to get out and put your hand in front of the Air Con Condenser and "feel" the draft direction.
All Instructions I have seen refer to fans at Low, Medium and High, S1's do not have the Medium speed...there is no RPM figures given.
You cars PCM determines watts to motors depending on info from Temp Sensor.
IMO I believe these fan motors are going to "slowly" go south with age/use..speed wise.
I would also go out on a limb and 'suggest' all motors should be replaced at about 7 years of age/use.
longpath 07-30-2010, 06:06 AM Yes, I was surprised to Read that "an Overheating Condition" in the S2 WS Manual could be the Motors/Fans Running Backwards!!...which is somewhat concerning as you would hear your fans running but are they going in the correct direction??...you would have to get out and put your hand in front of the Air Con Condenser and "feel" the draft direction.
I do find it troubling that there's no real test in the shop manual for whether the motor is actually turning fast enough and therefore performing as desired.
On the other hand, I've been unable to perform the testing I wanted because my car only seems to malfunction after conditions of 98F/37C, direct sunlight, and running the car well past fully warmed up. I've not had a weekend afternoon available to me in several weeks where the weather cooperated by giving me hot enough conditions to reproduce the failure I saw earlier in the Summer. Irritatingly, my AC and engine temperatures have all been annoyingly normal for weeks.
On the other hand, I am still working out the feasibility of swapping out the S1 motors and shroud, if only because the cost of the parts is lower than replacing my 2 S1 fan motors.
I am also looking to insulate the exposed metal line that emerges from the condenser and feeds to the compressor as it seems that on very hot days, that line would be exposed to very high air temperatures from the radiator. I did notice that the air inlet temperature to the engine would climb to well over 20F above ambient under those conditions where I saw malfunctions, so I am guessing that there was a very hot air bubble around the radiator. If my guess is correct, and since Mazda does insulate the bulk of the line from the condenser to the compressor, it seems reasonable that this exposed metal line could cause degradation of AC efficiency on very hot days, especially if air flow rates are reduced.
Advance auto parts sell cool tape . But it only goes up to 400f.. Degrees. Is that good enough? 18.00 a roll 15 ft.
IMO the Fan Motor issue is also another "Heat" one, the durability of the little motors sandwiched between all that Summer Heat...more than likely the S2 motors will go the same way over time.
What I have to caution you in using S2 motors in an S1 are the connections, the S2's are a 4 pin plug..the S1 could be the same?, more than likely they are.
Would be interesting to compare the Sales Stats for these motors in Cooler climates like Germany and UK.
The S2 Factory WS manual says Current Draw between 7.7 and 10.7 AMPS with a fully charged 12V battery, both fans on.( I guess max speed)....it does not say..
Just says replace fans if not running smoothly or correctly.
HiFlite999 07-31-2010, 07:24 AM Advance auto parts sell cool tape . But it only goes up to 400f.. Degrees. Is that good enough? 18.00 a roll 15 ft.
It should. I used this with no problems so far:
http://www.summitracing.com/parts/DEI-010408/
I like that it is not just pure aluminum, but has a little fiberglass to help with insulation (and not just reflection). Because a tape is so thin, I took some fiberglass (not urethane!) water pipe wrap, wrapped the tube with that first, then put the tape around that. It's not as "neat" but gives much better insulation. I also put just the tape around the black hoses coming from the A/C compressor. That helps reflect heat from the engine sitting 6" away.
This little trick makes a big difference. During last month's heat wave, the interior remained passibly comfortable with 100 deg F outside temps while the comfort limit was only 85-90 F before.
It is interesting to note that the temperature of the water coming from the radiator (measured in the lower radiator hose), rises by 10-12 deg F when the AC was switched on while cruising down the highway at 75 mph in ~90 deg outside heat.
saad84 08-24-2010, 05:52 PM This weekend I took a heat reflective cloth and wrapped the AC line under the hood that is exposed, I put small cable ties approx. every 2-3 inches. and cut a small square out for the little valve on the line. Today I drove to work and the AC was the coldest it has ever been and remained freezing cold for my 25 minute drive to work. Easy mod and takes about 15 minutes, it even adds 100 HP!!!!! J/K :D :D :D
I'll post pictures once my car gets back from getting the windows tinted.
Pics please.
There sure is a lot of confirmation bias in here...
I did this mod, and saw zero improvement. I live in florida where it has reached 100F quite often these past couple weeks, which is why I tried it. Until someone makes a video showing a *measured* improvement I will remain skeptical.
What did make a huge difference, however, is getting a reflective sun shade. I didn't realize how much of a difference those could make, but now my car is almost colder than the parking lot when I come back to it. My A/C now takes about 5-10 mins to get the car cool and comfortable compared to 30+ mins. And it was just as cheap.
Paradox 06-15-2011, 07:29 PM Agree with above. And tinting the windows helps. I'm glad I wrapped my line, though. It makes me cold when I think about it.
Brettus 06-15-2011, 07:39 PM Agree with above. And tinting the windows helps. I'm glad I wrapped my line, though. It makes me cold when I think about it.
You have a very apt user name then ....
Well, I can't see where insulating or covering the "Cold" exposed pipe would not hurt, and IMO has to help as the pipe would be insulated/protected from engine heat, it may not make the air cond "colder" but it would improve it's efficiency...compressor on/off cycling.
Remember Left hand drive RX-8's ONLY have this long pipe which travels over at top of bulkhead (firewall) and back down to the right side into cabin and evaporator.
Right hand drives have a very short pipe as Evaporator inlet is on the left side of car, as is the Compressor position/mounting for both Left and Right drive 8's.
olddragger 06-27-2011, 12:02 PM anyone checking the a/c charge? May just need some freon or whatever they call it now a day?
rob4001va 07-28-2011, 08:42 PM With the 100 degree days here in DC lately, in figured I'd give this a try. I have an early 04 production model with no A/C amplifier. It's alwya been ok, but idles a tad rough when the A/C is running. Gotta clean the MAF next.
I used this stuff
http://www.thermotec.com/products/17062-thermo-flex.html
Bought 1" diameter x 3' long, and slit it so it wrapped around the line and scutes with cable ties. Tomorrow is supposed to be quite hot, so I'll give it a road test.
Probably gotta get to the store for contact cleaner for the MAF next...
I got some catching up to do with my mods and tweaks as I've been stock for too long.:p:
HUH??....
I am pretty sure ALL RX-8's come with an Amplifier... how does your AC system work without one??
There is a "modified unit" just for your car...can give you the Part Number if you are interested, or look in the TSB's..
http://www.rx8club.com/showpost.php?p=3258091&postcount=2
http://www.rx8club.com/showthread.php?p=3258119#post3258119
APPLICABLE MODEL(S)/VINS
2004 RX8
VIN: JM1FE17**40 000001-118171 (up to 9/11/03 production).
FEY2-61-540 A/C Amplifier $490.54!!...OUCH!!
Z0oMzo0m 07-31-2011, 01:00 AM http://www.rotaryinsider.com/diy-tac38/rx8-ac-reset-gap58.htm
RX8 AC reset
AC RESET:
1. Make sure the car is off AND the HVAC fan is off AND the A/C on/off button is off.
2. Press and hold the front defroster (on the left) AND air source (recirc/fresh air) buttons
3. Continue pressing the buttons in step 2 and turn the key to ACC for 3 seconds
4. Continue pressing the buttons in step 2 and further turn the key to ON (NOT START) for 3 sec.
5. Verify the programming update by observing the REAR defroster LED blink 3 times.
6. Release the two buttons from step 2 and start the car.
Has anyone ever try this? came across this info on the web...
twin_rotors 08-13-2011, 09:40 AM Not to be the bearer of bad news but I do a lot of A/C work. By this I mean that I used to be a heating and cooling engineer for Ford. Wrapping the lines may give you colder A/C but you also risk freezing up the EVAP core.
This system should have a post EVAP temperature sensor. This will cause the A/C to cycle more often and creating more stress and load on the A/C system. When the HVAC module monitors the EVAP temperature, if it sees near freezing, it will start to pulse the compressor on and off to alleviate an EVAP freeze up condition.
Cant speak for RX-8 but earlier Mazda's had the Evaporator Temp Sensor located In the EVAP Fins...so if it gets too cold or freezes, compressor turns off as you said..
So how can this be an issue.
RH Drive RX-8's have a more direct line into EVAP from Compressor (LH Side of Engine), (no long exposed pipe going over top of engine)..and it is not an issue.
Harlan 08-14-2011, 12:50 AM Ok, a few things. If your AC is cycling then insulating your lines is probably useless, the most likely causes are an overcharged system or dirty condenser causing it to cycle on high pressure, or a dirty evap or even more likely dirty cabin filter causing it to cycle on low temperature. If it's running full blast and not cooling then it's probably a low charge, but the previous conditions can also cause inferior cooling if they aren't bad enough to cause the system to cycle.
Is insulating your lines usefull? Probably. It lowers the heat load on the system, and in the case of the high pressure liquid line it can also lower the pressure if the line is hotter than the condenser. But either way it would increase overall efficiency, but should not make or break the cooling cycle.
I really can't believe in 10 pages nobody mentioned the cabin air filter. Between that and overcharged systems I bet 90% of the cooling problems could be solved.
HiFlite999 08-14-2011, 09:23 AM Not to be the bearer of bad news but I do a lot of A/C work. By this I mean that I used to be a heating and cooling engineer for Ford. Wrapping the lines may give you colder A/C but you also risk freezing up the EVAP core.
There is an evap temp sensor (see page 31 of the FSM). Are you saying there needs to be a second one? :dunno:
Too, remember that the RHD Japanese/British version doesn't have the long pipe over the engine. Insulating that pipe in the LHD versions will still not bring it up to the effeciency of the RHD's, so one would think the system would have to take that into account anyway.
I just did the re-program as well, got the 3 blinks for confirmation, and guess what? No measured difference. I dug up the official mazda bulletin, and all this re-program does is makes the re-circ default. Really, more confirmation bias/placebo effect?
Yes, and the LHD's have a different Amplifier Control Box to RHD.
Check out the TSB's here...
There is one on the Temp Amplifier Box, and a "modified" version is also available for Customers who complain of poor AC Cooling Performance, I think within a certain MY or VIN numbers from my memory?)
twin_rotors 08-15-2011, 09:50 PM There is an evap temp sensor (see page 31 of the FSM). Are you saying there needs to be a second one? :dunno:
No, you would not need a second one. The original one is just fine.
I really wasnt that clear on how to explain this.
The HVAC module will have programming to keep the compressor cycling. This will monitor the a/c pressure and the EVAP temp sensor. If you wrap the lines, this will raise the pressure of the high side. The compressor will cycle more due to the higher pressure and the lower EVAP core temperature.
If you try and lower the temperature, the EVAP core will freeze. This will all depend on ambient temperature, humidity, and altitude.
HiFlite999 08-16-2011, 08:24 AM But I don't think the target temperature will be changed unless the controller is reprogrammed. With the wrapping, in principle, the compressor will cycle more, which, carried to extremes, is bad. However, in practice, at least with an all-black car and in 80-85 deg plus temps, I'm not detecting any cycling at all from the compressor. Without the wrap, it was running 'full blast' all the time. With, and with the air mixing flapper closed, I have to manually shut off the the AC intermittantly, 'cause it gets too cold in the cockpit.
Anecdotal I know, but wrapping seems to help.
RAWKSTAAR69 08-30-2011, 11:22 AM Not sure if this is the ideal location but I do have a question and searching has failed me, My HVAC fan speed 2 doesnt work, All the others work fine. What should I check or look into? I wouldn't imagine there is a fuse for individual fan speeds, so what do I look at? Thanks guys.
