View Full Version : DIY: Removing the gauge cluster
magixpuma
10-16-2004, 05:00 PM
Ok guys, I fixed my 1 qaulm with the car the infamous squeeky gauge cluster.
Its that noise you hear when your on bumpy roads it sound like squeek squeek.
Well some jerk asembaly line dude obvously overlooked some thing and now it sqeeks cuz it loose. so what does 1 do pay 400 bux in labor at a Stealer ship? NO!
**** ALWAYS DISCONNECT THE BATTERY BEFORE YOU DO THIS PROsses
It will reset your clock trip miles and radio settings but the results are way worth it.****
Can a admin put this in the do it your self section sorry,
do it your self.
Heres the tools you need 2 hands 2 arms 1 philips head screw driver. and a bit of common sence. and 3 decent size o rings. after you do it youll know what size you need.
First you remove the lower panel under the steering wheel
magixpuma
10-16-2004, 05:11 PM
then follow these steps.
magixpuma
10-16-2004, 05:20 PM
now do this step
magixpuma
10-16-2004, 05:26 PM
now heres the big step
magixpuma
10-16-2004, 05:29 PM
heres the last step then you just reverse everything an d put it back to gether.
RXE16T
10-16-2004, 10:01 PM
Comprehensive instructions to say the least. :)
Omicron
10-17-2004, 02:17 AM
Very nice DIY, magixpuma... Well done! I've replaced your .bmp files with .jpg's so people can see them, and retitled your thread - but other than that, perfect! :D
And why wasn't it moved sooner? Well, sometimes it takes us a few minutes to get these things done... you can thank Elara for getting it moved. But in the future, why not just post it in the correct forum in the first place? ;)
truemagellen
10-17-2004, 02:59 AM
wow great job...anyone want to add to this DIY on disabling the TPMS light ;)
magixpuma
10-17-2004, 07:13 PM
A. thanks for converting the files..
B. thanks for retitleing the thread.
C. I already thanked elara.
d Im a friggen moron and cant put a thread in the right place hopefully this will help some ppl and if it does tell me so i feal good. cuz im needy like that........
Also i was driving today and its still very stable and no new sqeeks so proud.
Nubo
10-22-2004, 02:13 PM
Nice job :)
magixpuma
10-22-2004, 07:24 PM
thanks
irfan
07-19-2006, 11:11 PM
gonna try this tomorrow to see if i canget the lens off to 1- polish it, and 2- cover the blue LEDs in it.
But imjust replying to point out the the manual DOES mention 2 screws... if you look just above the W in SCREW on the diagram you will see a vertical line indicating the other screw.
Thought Id mention that for those that are reading similar diagrams... you have to follow all the lines pretty carefully since they didnt put a screw icon for each screw in most of the manual.
EyeBall Fixer...(o)(x)
07-19-2006, 11:35 PM
Thought Id mention that for those that are reading similar diagrams... you have to follow all the lines pretty carefully since they didnt put a screw icon for each screw in most of the manual.Back from the dead!
Thanks irfan!
I was looking for this DIY a while back.
Please post pix when you're done.
I want to connect an LED to the "Beep" buzzer . Sometimes I can't hear the beep
if the radio is up very high. A little visual aid...
renesis_power
07-20-2006, 12:20 AM
btw can the car dealer modify the mileage meter reading?
because i am planing to buy a rx8 but i am affraid of the mileage meter is too low to be true.
cheers
07-20-2006, 06:08 PM
cheersI'm sure it "could be" changed but most dealers aren't going to do
it because of the stiff fines... Key word = "most"
Asmoran
07-21-2006, 08:27 AM
While it can be done, it's extremely hard to do. Both the guage cluster and the PCM would have to be reset to the same number. This would involve hacking the PCM, since the WDS has no functions to alter the mileage.
olddragger
07-22-2006, 09:28 AM
didnt know the gauge cluster was that easy to remove! Now i am thinking about ditching the factory oil pressure gauge(and maybe cooolant one also) and mounting a "real" gauge in the factory housing.
thoughts ---and sorry I am off thread here.
olddragger
MPG > HP
07-28-2007, 06:39 PM
...Now i am thinking about ditching the factory oil pressure gauge(and maybe coolant one also) and mounting a "real" gauge in the factory housing...
olddraggerolddragger, Please start a new thread for this and link to it, from here. I'd like to see the analog gauges using the stock needles along with stock font-like decals showing the degree markings. Should have 20, 40, 60, 80, 100 for oil PSI and 140, 160, 180, 200, 220, 240 for degrees F (My '8 got up to 248F running at MazFest in 109F ambient and that with the heater & AC on full, before it shut down to sub 3k rpm engine save mode). Seems like there may be room on the lower part of the cluster for oil temp and volt meter.
Zephyrzone
10-22-2007, 07:26 PM
Reviving this one.
I have the gauge cluster rattle in my 07 GT Manual. I followed these instructions perfectly and got to the "scary" part where I'm supposed to pull the gauge cluster out by hand...
NOT happening. I pulled with every ounce of strength I have, and I'm probably of above average strength, and it would not budge. That cluster was not coming out. Something else has to be holding it in. Maybe the changed it for the 07's? I removed the panel, the 3 screws and the 2 screws under the wheel holding the cluster in place. I could get it to move up and down vertically and become very loose, but there was no way in the world it was coming out. :banghead: :banghead: :banghead:
Anyone know what was holding it it? I threw some O-rings in the bottom area since I had access to that, but couldn't get behind it where I think it really needs one.
Zephyrzone
10-27-2007, 11:27 PM
BUMP
Come on, somebody out there has had this problem too...
cmr333
03-22-2008, 12:48 PM
those clips in the back are stubborn as hell man jus be gentle but firm and pull stright back....i know that sounds weird lol but it works.
eddybear
04-04-2008, 12:21 AM
Gotta revive this because I too am frustrated with having a lame ass oil pressure gauge there when all that real estate could be used by functional gauges.
Has anyone contemplated doing this?
Thoughts?
cmr333
04-04-2008, 09:09 AM
ive done it...well alomost done with it. i am working on completeing an sr20 swap into my 8 and i have had to do away with all my stock gauges. I made some smc filler plates and molded them into my stock cluster housing and have holes cut out for all my new autometer ultralite gauges..i will post up pics of the halfway done part if you like.
jessedrifter
05-20-2008, 07:06 PM
what happans if u dont disconnet the battery?
Zelse
06-18-2009, 05:23 PM
Reviving this from the dead. Dealer recommended to me to pull out my cluster and then just pull out the bulb for the TPMS light. Anyone done this or is this easy to get to the bulb or what? Just wanted to check in. Thanks guys. BTW
04 RX8 Mt if that means anything about changes in clusters or something. Thanks!
nuke0907
06-18-2009, 05:32 PM
there's not really a bulb to change out.
Zelse
06-18-2009, 06:09 PM
Really? Thats what the service manager at my dealership had told me that it's not even a LED, that it's a bulb to remove. Have you done it before? I really want to avoid just putting a damn sticker to block the notification. :/
Ross_Dawg
06-18-2009, 06:16 PM
well technically there is... just a super small led. Only way to see of you can disable/take out/cover the tpms light is to get back there and check it out. Sounds like it only takes a max of 15 mins to pull out the cluster.
Edit: just saw your post. That is definitely a led back there.
Zelse
06-18-2009, 07:02 PM
Yeah I think I'll give it a shot and remove it. The service tech though said if I unplug the cluster, I need to get my car to service to have them hook it up to the special mazda computer and redo the configuration as nothing will work right...
nuke0907
06-19-2009, 11:52 AM
its an LED you have to un-solder from the circuit board.
Zelse
06-19-2009, 12:07 PM
Ugh...Seriously? :/ I can't just crack it or something and break that shit.. lol. I really hate this light but want to do it the cleanest way possible.
Vaillant
08-01-2009, 05:30 PM
After listening to the stupid gauge pod rattle for far too long, I finally did something about it today. These instructions were very helpful, so I'm happy to say the rattle is now gone.
Thanks for the DIY!
~ Matt
Zelse
08-01-2009, 05:50 PM
I got recommended by the service manager to pull off the plastic cover over the gauge cluster...and color in over the clear part that displays the tire pressure gauge with a black perma marker... thoughts?
rudiau
02-19-2010, 11:05 PM
OK, call me as dumb as dog doohy, but i can't work out from the final image where the hell the o rings go. Are they the red dots or the three lines (two of which are the connectors).
And how do you keep them in place.
rudiau
02-20-2010, 04:32 PM
Ok, worked it out from other threads.
For others who might be a bit confused, the o rings are the red dots, they are placed there to be padding between the instrument cluster and the plastic body it sits in.
Look at the last image posted by magixpuma at the beginning of this thread.
Didn't work for me so i have a problem elsewhere.
BTW i found if you lift the cluster upwards and then pull it towards you, it comes out a lot easier.
After trolling around the threads for a day here is a summary of things to look for when you have a dash board rattle.
Usually found by pushing, prodding or applying slight preesure.
Check
Outside drivers door handle (i'm RHD so i guess i'll check both).
Demister vent.
Small vents above the circular one.
Siver rings on the cluster gauges.
Volume knob.
Centre steering wheel. (pull on rear lip of the horn/airbag cover).
Plastic covers behind steering wheel.
Push and prod in between door and dash by the round air vent.
Known Cures
Remove coins in coin holder.
Remove or add foam/dynamat to the drivers and/or passengers door(two foam blocks come loose and rub together inside the door).
Push back thin metal behind brake rotors.
Loose nut/bolt on steering column.
Many thanks to the many members who have contributed to these lists.
rudiau
02-20-2010, 09:52 PM
YAY, i found my rattle, it was the airbag/horn cover on the steering wheel.
Putting upward pressure on the back lip of the cover eliminated the rattle.
Now, how to fix. i have read the service manual and safety warnings, but.......not game.
Might let the dealer do it, depending on what he wants to charge, might give me incentive to find my kahuna's.
In the meantime i have packed a wadding of a few folds of leather in between the lip and steering wheel body.
Anyone else taken off the airbag/horn assembly, any real worries of it going off if you follow the service manual.
Chad D.
02-20-2010, 09:55 PM
I have a similar rattle in the plastic abs cover and I am very interested in how to properly fix it.
For now I just turn up the stereo.
rudiau
02-28-2010, 03:16 PM
OK, finally had a go at removing the airbag/horn cover. Piece of cake. Just follow the manual.
Cut out three pieces of leather about 2-2.5cm in diameter.
Used a paper hole punch to cut holes in the two top ones. The bottom one doesn't need it.
Dab of supa glue to hold them in place.
Put it all back together, making sure the guides go thru the newly cut "washers".
RATTLE GONE.
jumpman5272
07-14-2011, 06:31 AM
I didn't disconnect the battery before removing the cluster, now my rx-8 stalls at every stop sign or traffic light, i have to put it in neutral and press the gas pedal to keep the revs at 2,000 so the car won't stall again. I've double check the connection and everything seems to be ok, any advise please.
Daeity
07-20-2011, 05:42 PM
scribed for when i change the dash lights
Nopstnz8
12-02-2011, 06:36 AM
Looking to hit up Home Depot later today... Does anyone know the proper O-Ring sizes that are needed?
