DO I have the corrrect Flywheel for an RX-8 from Racing Beat
Old Oct 13, 2004 | 08:49 PM
Jaguar_MBA's Avatar
Folks :
I ordered a light weight flywheel from racing beat and received it today.
The invoice refers to the part as item number 11468 LTWGHT ALUM FLYWHY RX-8 04
The part I RECEIVED has the following tag on it:
PART NO: S11448, ALUM FLYWHL 87-95 TRBO
DO I have the corrrect Flywheel for an RX-8?
I already sent a note to Racing Beat also tonight.
Old Oct 13, 2004 | 08:51 PM
RX8_Ownz's Avatar
someting's wrong. i guess the flywheel u just received is for rx-7 turbo.
Old Oct 14, 2004 | 01:18 AM
socalightning's Avatar
I believe you have the right flywheel and that they are interchangeable between the RX7 Turbo and RX8. It's important that you have the correct counterweight (Mazda OE) for the RX8 though and Racing Beat should have packaged them both together.
Old Oct 14, 2004 | 01:34 AM
this is true
Old Oct 14, 2004 | 06:09 AM
Jaguar_MBA's Avatar
Yes they did give me a counter wieght with RX8 04 on the on the part.
Old Oct 14, 2004 | 09:45 AM
Broke_Apex_Seal's Avatar
Yeah it is the correct part. I was the first person to put a rx7 flywheel on an 8 and it is all the same.
Old Oct 14, 2004 | 10:54 AM
Jaguar_MBA's Avatar
From Racing Beat:
Yes, the flywheel that you have is indeed correct for the RX-8. As with most of the RX-7 applications, the actual flywheel is the same for many of the applications, with only the counterweight being different. In the case of the RX-8, it uses the RX-7 turbo flywheel, and the counterweight from an RX-8 application.
We have changed the part description in the inventory listing and the bill of materials for this part, but it will take a couple of production runs for all the older parts with this decal to rotate through the inventory.
Best regards,
Jim Langer
Racing Beat, Inc.
714-779-8677
www.racingbeat.com
8is>enuff
Sep 24, 2015 08:57 AM
8is>enuff
NE For Sale/Wanted
Sep 3, 2015 07:57 PM
PTQLam
Aug 16, 2015 05:40 PM
AllSeeingChris
Aug 16, 2015 12:35 PM
