Help!!
Old Oct 13, 2004 | 08:00 AM
takahashi's Avatar
Help!!
It is all Gomez's fault - no it is not!! :p
I was going to fix the squeaking noise from the seat by loosen the front left corner bolt of the seat and guess what!!
I rounded the corners of the nut - now I cannot unscrew them
HELP :o :o :o
Old Oct 13, 2004 | 08:04 AM
AMG's Avatar
AMG
trust me..this wont hurt
angle grinder????
Try cutting a slot in the nut then use a hammer and a long large screwdriver and tap it free....gently.
Use plenty of RP7.
Good luck.
If you pay for airfare, I'd do it for you ........ LOL!
Old Oct 13, 2004 | 08:24 AM
takahashi's Avatar
The nuts is so tight that I don't think a gentle tap will come out.
I will bear with the squeak coz it never went for more than 2 weeks. It is not really bad.
After searching the net for a while, there is a thing call nut splitter. I might go and find one if the nut starts driving me nuts :p
Old Oct 13, 2004 | 08:27 AM
AMG's Avatar
AMG
taka, you need more than "a" gentle tap, but be sure to soak it overnight with RP7 or WD40.
Might be a good idea to invest in some high quality tools, these will give you less risk of problems such as these.
Old Oct 13, 2004 | 08:39 AM
takahashi's Avatar
I don't think it is my tool but it is me :p
Anyway, I will leave it for another day. I think I will cut the damn thing with a nut splitter. At least the nut slipper will give me a slot and I can have a go with gentle tapsssss. :P
EDIT: Now the nut is soaked with WD40 and the noise went I am sure it will come back
Old Oct 13, 2004 | 09:28 AM
Gomez's Avatar
Shifty Bastard.
I'm sure I've mentioned this before....
This is and old trick they use at the tyre fitters when someone has left their splined locknut socket at home....bang a smaller socket onto it. For example, if it's a 10mm bolt, tap a 9mm socket onto it.
Ugly, but it works every time.
Gomez.
Old Oct 13, 2004 | 04:40 PM
stasis1's Avatar
invest yourself into a wrench set it a good investment i bought 1 set SIDchrome for $90 at agriulture show
Old Oct 13, 2004 | 05:15 PM
RotaryJeff's Avatar
I'm Not Here.
C4.
Old Oct 13, 2004 | 06:13 PM
takahashi's Avatar
Yeah right C4...
I have a wrench set from Autobarn - they are quite good. Not that when you tighten and remove the same nut every 2 weeks.
Yeah I will try to tap a 13mm in. Or I will invest in a universal one first - coz they can mould into anyweird shape.
Old Oct 13, 2004 | 08:11 PM
RXP33D's Avatar
Is it gone for good once you do this unbolt-rebolt trick?
Cause ever since i read up on it since somebody noticed it on this forum, it rings in my head!
Old Oct 13, 2004 | 08:18 PM
takahashi's Avatar
Not in my case :D
Old Oct 22, 2004 | 07:22 PM
Advan's Avatar
Originally Posted by takahashi
Yeah right C4...
You need a Snapon set to get it off, invest one :D
