Light on in glove box -- normal?
Old Oct 8, 2004 | 09:44 PM
carnut's Avatar
My dealer had to replace my glove box door after something went wrong doing the passenger air bag recall. The light in the glove box now stays on whenever the headlights are on -- I can see it over the top of the glovebox door when the car is in a dark garage.
The dealer checked this and says the glove box light does this in other RX8s. If the glove box door fit more tightly, I probably wouldn't be able to see in. Maybe it was always this way, but I never noticed. Anyone have any thoughts on this?
Old Oct 8, 2004 | 10:48 PM
Rob Tomlin's Avatar
I have to double check, but I doubt it. Doesn't make any sense at all.
Since the glove box door was replaced, I'm willing to bet that it isn't fitting right, which means it isn't closing all the way so the light isn't turning off.
I had the same problem with a loose glove box door on my 93 RX7. Very annoying.
Does the glovebox door look like it is closing all the way?
Old Oct 8, 2004 | 11:02 PM
rotten42's Avatar
Mentalhealth is overrated
we have a light in the glove box?...never noticed....I'll have to go check it out.
Old Oct 9, 2004 | 09:07 AM
Smoknjim's Avatar
If you open the glove box door and turn your lights off and on you will notice the glove box light is controlled by the light switch and not the glove box door.
Old Oct 9, 2004 | 09:28 AM
ACHYellowRX8's Avatar
My first thought when I first read this was how did he get into the glove box to verify his light was ON???????????????
Old Oct 10, 2004 | 10:12 AM
carnut's Avatar
Very hard to get all the way into the glove box; my feet were sticking out. Seriously, though, I do feel the glove box door doesn't shut completely. That's how I can see the light through the crack at the top. Rob is right that it just doesn't make sense that there isn't some kind of momentary contact switch on the dash that shuts off the light when the glove box is closed -- even if the light is wired in with the headlights. Why risk heat build-up and possible fire?
Old Oct 10, 2004 | 08:44 PM
kellybrf's Avatar
mine does the same thing. its nothing i would ever notice b/c its so faint, but it definately was on and it was closed
Warrior777
Jun 24, 2019 04:47 PM
QTdude
Dec 12, 2015 10:23 PM
indadesert
Sep 1, 2015 04:46 PM
MarkX
Jul 31, 2015 07:50 AM
