help - re-wiring question
Old Oct 8, 2004 | 12:18 AM
daz1300's Avatar
Just a quick question to 8 owners,
can you re-wire or re-program the control of the side mirror lights, so they stay on when the headlights are turned on that is opposed to just on "when the car is unlocked....
Old Oct 8, 2004 | 07:28 AM
Gomez's Avatar
Shifty Bastard.
I'm sure you meant to ask, "Is there an easy and inexpensive way to rewire the mirror lights?"!!!!
Throw enough time and effort into it, and it's possible. You'd just have to patch in 12v from the headlight or dashlight cct, and probably isolate the 12v with a diode to protect the variable output from the normal supply....which I assume is controlled by the Keyless Control Module? The interior light is controlled by the KCM.....
I don't think the circuits I have will show the wiring, as they are for U.S spec cars which don't have the Ground Illumination lights in the exterior mirrors.
Gomez.
Old Oct 11, 2004 | 12:09 AM
daz1300's Avatar
thanks gomez,
can you just telp me what the abbreviated words stand for...(sorry for the lack of knowledge)
2ndly, what happened to "curiosity sated"....??
Old Oct 11, 2004 | 12:14 AM
Gomez's Avatar
Shifty Bastard.
Sorry...cct is circuit....KCM is Keyless Control Module.
The B&W (black and white :p ) Gomez avatar may make a return....
Gomez.
Old Oct 11, 2004 | 08:21 PM
DMRH's Avatar
The wiring would lead back to the relay box under the dash. You would have to get the relay from the headlights, run a wire across to the mirror lights relay & hook it in. Make sure you electrically isolate it by using diodes to prevent unwanted power coming back turning unwanted features on.
Old Oct 12, 2004 | 02:15 AM
daz1300's Avatar
thanks dmrh,
you are 100% sure this could/would work.....?
cos only then i will try it.
Cheers
Btw do you think wire cutting of existing wires would be neccessary...as i would like/prefer to avoid that.....
thanks again
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
