How Can I install Handfree Mic?
Old Oct 7, 2004 | 04:33 AM
Thommino's Avatar
I want to install Parrot Mic, but I cannot find how remove a part of my car to pass the mic wire. Who can help me?
Thnaks
Attached Thumbnails How Can I install Handfree Mic?-21_forum.jpg   How Can I install Handfree Mic?-15919_forum.jpg
Old Oct 7, 2004 | 06:16 AM
RotorWheeee's Avatar
04 and still lovin it
You dont want to mess with the air bags . Very good risk of injury , or diabling the airbag.
Old Oct 7, 2004 | 06:50 AM
Thommino's Avatar
Where Can I Install the mic, and where pass its cable?
Old Oct 7, 2004 | 07:41 AM
truemagellen's Avatar
Attracts tree branches
he Thommino listen to RotorWheee, yes that is an airbag, don't touch it unless you know what you are doing....but just be patient someone around here knows what to do
Old Oct 7, 2004 | 12:42 PM
BlueGrimRX8's Avatar
all you have to do is push the wire with a small flathead scredriver into the pillar, there is enough room back there for a lot of wires. I have my radar detector as well as a wire for the antenna of my Viper alarm running down that column.
Old Oct 7, 2004 | 12:46 PM
huhsler's Avatar
BlueGrimRX8, can you expand on that, maybe with a DIY entry or pictures? Thanks!
Old Oct 7, 2004 | 12:54 PM
Thommino's Avatar
But there is space also in that place yellow circled?
Old Oct 7, 2004 | 01:08 PM
Mugatu's Avatar
Even My Dog Searches
yes, i did that too with a radar detector where I wedged the wire between the frame and the pillar. A DIY isn't really necessary.
Old Oct 7, 2004 | 01:11 PM
just make sure you have enough slack to run the wire from whereever up the pillar and across the front, then wrap a small flathead screwdriver with a thin cloth (don't want to scratch anything) then push the wire in and down a little so that it gets stuck behind the pillar. Don't have any pics becuase I am at work but if you don't figure it out PM me.
Old Oct 7, 2004 | 01:42 PM
Thommino's Avatar
Thanks, I hope to successfull with it.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
