Cracked Rocker Panels.. temp change?
Old Oct 6, 2004 | 09:51 PM
Charles Cope's Avatar
Tuesday, I noticed a "Ford emblem" shaped crack about 2" x 4" on my right rocker panel, just in front of the rear wheel well. I washed it on Saturday before going on a rally (my only excuse for it being so dirty) so I know it happened in the last couple days. Monday night we got down to 29 degrees F, my only guess as to why the crack appeared.
Strange enough? Nope, the same shape crack is on the left side in exactly the same position! take a look at the pics.. any ideas?
I'm going in for my new brake pads on Monday, so we'll see what Mazda says.
cc
Attached Thumbnails Cracked Rocker Panels.. temp change?-rocker-crack-right-side.jpg   Cracked Rocker Panels.. temp change?-rocker-crack-rt-closeup.jpg   Cracked Rocker Panels.. temp change?-rocker-crack-lt-closeup.jpg
Old Oct 6, 2004 | 09:56 PM
truemagellen's Avatar
Attracts tree branches
what a bizarre crack it doesn't look like there is any surface marks where pressure would have been placed (unless directly on the crack which still doesn't appear to have happened) yeah have mazda replace it for free....this one is a wacky one
RXE16T's Avatar
'RX-EIGHT'
Eh, I think that's a piece of protective molding put on from the factory, not a crack.
Old Oct 6, 2004 | 10:02 PM
I think you are right...I just went outside and I have something like that but it is longer...you might just have wax caked up against the protector
Old Oct 7, 2004 | 05:20 AM
No, its really a crack. It looks like there is something inside the plastic that expandeed and popped the piece loose. But, this makes no sense, if it is due to the cold snap we had. Another "theory" is there is a defect in the die for the plastic rocker.
I know they weren't there on Saturday.
Old Oct 7, 2004 | 05:29 AM
RXE16T's Avatar
'RX-EIGHT'
Try and peel it off, you'll find that it's actually a piece of plastic put there to protect the leading edge of the door frame.
You'll find another larger piece between the rear door and in front of the rear wheel arch.
Old Oct 7, 2004 | 05:42 AM
This photo shows the protective "patches". I know its hard to believe, but they look like they were punched out from inside.
Attached Thumbnails Cracked Rocker Panels.. temp change?-left-side-crack.jpg
Old Oct 7, 2004 | 05:48 AM
RXE16T's Avatar
'RX-EIGHT'
Here, maybe this can shed some light for you:
https://www.rx8club.com/rx-8-discussion-3/black-sticker-rear-fender-40241/
Old Oct 7, 2004 | 09:07 AM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
What you have there is 3M protective film (similar to the stuff used in the clear bras and headlight protector films) that was applied to those areas to protect them from scratches and rock chips. It just looks more noticable because of the wax residue stuck in the cracks. I just used an old toothbrush to gently scrub the residue out.
Old Oct 7, 2004 | 10:43 AM
Sorry guys, its a crack!
Old Oct 7, 2004 | 10:47 AM
skuzbucket's Avatar
Nope - I have the same thing on my car after I washed it - Rotary Nut is right - just clean out the edges with a toothbrush.
Old Oct 7, 2004 | 10:48 AM
RX-GR8's Avatar
now i have to go outside and check my car to see if i have this. it's a beautiful day so i'll take my time. :D
Old Oct 7, 2004 | 10:53 AM
6speed8's Avatar
It is not a crack, it is a clear protective strip - go to the dealer and check out some other RX-8s. If you used Zaino you would not get the wax buildup on the edge and would not have noticed it.
Old Oct 7, 2004 | 10:55 AM
See photo
Attached Thumbnails Cracked Rocker Panels.. temp change?-left-side-crack-comment.jpg
Old Oct 7, 2004 | 11:05 AM
Feras's Avatar
the Doctor
i have a similar thing on only the right side, and it sure as hell feels and looks like a crack.
Old Oct 7, 2004 | 11:06 AM
I'll try to get a better picture, tonight. I sent my photos to the dealer. He will inspect it Monday night. They are cracks. Sorry you don't believe me! I know the difference between the 3M clear stone guard stuff and a crack in the finish.
Old Oct 7, 2004 | 11:09 AM
clyde's Avatar
www.TeamWTF.org
Originally Posted by Charles Cope
See photo
It is not a crack. It is the same type of protective film as the larger piece.
Old Oct 7, 2004 | 11:18 AM
G8rboy's Avatar
Mmmmm... Rotary Donut
Isn't the rocker panel made of steel? How is it possible to crack like that?
I don't think temp is the problem- I saw -20F last year with no problems.
Old Oct 7, 2004 | 11:36 AM
zoom44's Avatar
its protective film and Charles when you find out all of theses gents were correct i hope you will actually post in here that they were.
Old Oct 7, 2004 | 02:19 PM
Originally Posted by abbid
also, if its a crack, take it to mazda. See what they say, dont worry about what we say, hell what do we know?
BINGO!
If its protective film, I will post an apology to all of you! But... its a crack!
Old Oct 7, 2004 | 02:41 PM
Feras's Avatar
the Doctor
Did you go to the dealer?
the crack in mine has a black line in it and is slightly displaced from the panel and clean and straight on the otherside, im pretty sure he's right that its a crack. and im going to have them look at it.
Old Oct 7, 2004 | 02:53 PM
G8rboy's Avatar
Is it a crack in the paint, or a layer of metal?
Old Oct 7, 2004 | 03:07 PM
Feras's Avatar
the Doctor
well the thing looks to be made of a hard plastic, and is pushed in a bit.
Old Oct 7, 2004 | 04:37 PM
Morgan's Avatar
Lounge Sweetheart
haha, this thread made me laugh..."it's a crack" "no, it's the guard film" "crack" "film" wow..you guys are hilarious! I'm keeping my 2 cents out of this one..i just wanted to say ya'll make me laugh :D
Old Oct 7, 2004 | 04:44 PM
zoom44's Avatar
But... its a crack!
:D maybe you should smoke it :D
