Where is the Racing Beat intake?
Old Oct 5, 2004 | 04:38 PM
Splan8's Avatar
GA RX8 Club Member
I am reallylooking forward to this mod. I know, "it's ready when it's ready" but I want one now!! :D
Old Oct 5, 2004 | 04:50 PM
Icemastr's Avatar
Soon young grasshopper. Soon.
Old Oct 5, 2004 | 05:10 PM
gcar76's Avatar
I know what up with that, Jim you reading this hows that intake coming?
Old Oct 5, 2004 | 05:13 PM
zoom44's Avatar
question:
answer: California.
Old Oct 5, 2004 | 05:32 PM
Icemastr's Avatar
I think its already pretty much finished they are just starting to make them.
Old Oct 5, 2004 | 05:35 PM
gcar76's Avatar
How much you guys think it will go for?
Old Oct 5, 2004 | 05:44 PM
Splan8's Avatar
GA RX8 Club Member
I am hoping for something close to $200 or $250 max with the filter.
Old Oct 5, 2004 | 06:00 PM
zoom44's Avatar
a typhoon costs that much! the RB has a complete airbox plus a filter designed especially for it. a lot more time was spent on this design. The RB will probably be $300. i sent an email off to jim langer so ill let you know.
Old Oct 5, 2004 | 06:18 PM
davefzr's Avatar
Do you personally know him? I envy you.
Old Oct 5, 2004 | 06:38 PM
zoom44's Avatar
i wouldnt say personally but i have met and talked with him. and asked questions via email and been answered a few times. i also met and talked to Jim Mederer, Dr. Ianetti (ceramic seals anyone?), Steve Kan + several others. i feel incredibly lucky.
Old Oct 5, 2004 | 06:43 PM
davefzr's Avatar
Thats sweet.. I wish I could have gone to Racing Beat's open house but I was actually out on the track that day at WSIR.... Thats pretty exciting too though
Old Oct 5, 2004 | 10:25 PM
ScudRunner's Avatar
On time, on target
I talked to Jim Langer today. He said they had run into some "bumps" in trying to get some of the smaller parts fabricated, but they were finally making some progress. But then he finished by saying he had no solid ETA to pass along.
Old Oct 5, 2004 | 11:28 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
Im guessing that you guys arewaiting for this intake b/c its actually supposed to have an effect on performance UNLIKE the current intakes which onlygive you a louder noise. Am I right about thisor will this one be just like the rest? Also isit going to be as loud?
Old Oct 6, 2004 | 12:53 AM
rotarygod's Avatar
Even if Racing Beat's intake gives no more than about 4 hp, that is still no more or less power than ANYONE else's intake out there. Racing Beat's is fully enclosed from engine bay heat, not just shielded. It's intake pipe is designed properly unlike several others out there. The complete box assembly will also make it much quieter than anyone else's. What's not to like about it? This is one nice intake system. Everyone else is just a cone on a stick.
Old Oct 6, 2004 | 01:01 AM
mysql101's Avatar
Can someone explain the large number of people dying for an aftermarket intake? I can understand if you want the K&N for sound, because that's about all you get .. but if the intake makes no more sound than stock, what's the point? I went with the green filter drop in, but these threads make me wonder if I'm missing something.
Old Oct 6, 2004 | 01:10 AM
Ole Spiff's Avatar
The RB intake will probably make a bit more sound than stock, but not so much as to be objectionable. It WILL give more hp which is always welcome; even if it's only 3 or 4. When you add it together with other mods, the increases do start to add up. A few extra hp here, a few there, and at some point those "few" start to make a noticable difference in performance. I'm buying an RB intake as SOON as it's available. Combined with the RB exhaust which I already have, it should sound very good. And I gain 6 or 7 hp too which is always welcome.
Old Oct 6, 2004 | 01:34 AM
rotarygod's Avatar
The quality is very high on the Racing Beat intake. It looks great. The inside surfaces are very smooth and there are nice radiuses on everything. There are no sharp bends anywhere inside that would hurt airflow.
While it does use a cone style filter, it isn't the same type that everyone else is using. RB's is big. It has a nice large internal area that lets the air straighten out after passing through the filter element. Standard cone filters are very small inside and have a sharp edge transition to the intake. The standard K&N filters are also very large but the rest of the system is designed terrible.
They are not done dyno testing yet. So far they have shown about 4 hp or so gain from it. However they are adding a cold air intake to it that at higher speeds may add a couple of more horsepower. Others have claimed that a cold air intake or ram air will not work on this car. That is simply not true. It just won't work the way's that have been tried so far. The key with a smooth idle and good running is the ntake pipe after the filter. The inlet pipe on Racing Beat's system is before the filter. This means it will not affect the maf or make the car run rough. It's going to easily be the best system out there. Everyone else so far has just made an intake pipe, put a cone on the end of it, maybe made a shied around it, and then just dyno'd it to get some numbers. This system is different. Rahter than using the dyno to verify numbers, this piece is the RESULT of dyno testing. That is what makes a truly great product. At the same time, it needs to have the sound they want. They are looking for a little more agressive sound than stock but it has to be a more mature tone that better reflects the more mature middle aged owners rather than the kids who just want it loud. This car wasn't designed for them and the aftermarket shouldn't be either.
Old Oct 6, 2004 | 02:02 AM
Aoshi Shinomori's Avatar
Kaiten Kenbu Rokuren
I don't think any of the aftermarket intakes made 4 hp. I think a few might have made 4 hp at 8000 rpm, but other than that nothing anyone has made has been designed well. This one really looks great and I am glad that there were some people not out to make a quick buck on a crappy product. Thank you Racing Beat.
Edit:
Rotarygod you changed your avatar, and now I don't even remember what the old one has or if you even had one. Haha, I need to sleep. Good night all.
Old Oct 6, 2004 | 06:50 AM
RXE16T's Avatar
'RX-EIGHT'
Good things come to those who wait..... knowing RB, we are in for the most comprehensive, most developed and engineered intake system released thus far.
I firmly believe it will not be glaringly proficient in any one particular area (ie noise. performance, etc) but will be the best combination (compromise?) of all facets.
Very similar concept to the design of our 8, wouldn't you agree?
Old Oct 6, 2004 | 09:48 AM
MyRxBad's Avatar
Fb's rock!
Even after seeing the RB intake @ 7stock I don't think I would get it.
It's a very nice unit and looks stock (which I like) but IIRC it gets rid of the VFAD.
The engineers put the VFAD in place for a reason, so I think I'll keep the stock unit in.
BTW: RB is thinking of marketing this intake in the $300-$350 range when I asked them at 7stock.
Old Oct 6, 2004 | 11:01 AM
Red Devil's Avatar
I thougt it replaced or enlarged the VFAD, but did not get rid of it all together?
Old Oct 6, 2004 | 11:06 AM
zoom44's Avatar
no there was some talk about that and Jim Langer confirmed (last i checked) that it would include the vfad.
Old Oct 6, 2004 | 11:17 AM
gcar76's Avatar
Can we get on a waiting list? Similar to the RB exhaust waiting list when it first came out?
05rx8mazda
Nov 28, 2015 09:42 AM
r-enzyme
Oct 1, 2015 01:27 AM
yapakanichi
20
Sep 10, 2015 07:17 AM
