Problem
Old Oct 2, 2004 | 10:27 AM
layzieb36's Avatar
Question Problem
Ok guys..I need a lil help with an issue I had driving home last night. I was driving at about my normal speed of oh say 85 mph my check engine light comes on I'm like ok no biggie this has happened before, but then something really weird happened my windsheild washer fluid would not spray, has anyone had this issue or maybe some advice as to reset it or if you know that it is a bigger problem? And yes I have plenty of fluid in the holding tank. Thanks in advance.
-Chris
Old Oct 2, 2004 | 10:45 AM
layzieb36's Avatar
no one out there has any ideas?
Old Oct 2, 2004 | 11:09 AM
truemagellen's Avatar
Attracts tree branches
well check engine light usually means an electrical problem...maybe a fuse blew...don't worry be patient...someone will answer your question soon
not to be a jackass but did you check your wiper fluid levels?
Old Oct 2, 2004 | 11:13 AM
layzieb36's Avatar
lmao....yes i did thank you, hopefully some one will have an answer.
-Chris
Old Oct 2, 2004 | 12:37 PM
Low Fly'n 8's Avatar
Make sure your gas cap is tight. If loose, it can trigger a check engine light.
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
