can some one give me a bulb code for .....
i need help with changeing the light on the outside mirror, locking glove compartment,visor vanity mirrors and the power window and door lock switches
it will be great if some one tells me the bulb code for them and it will be greater if they put picture o how to to install visor vanity mirror and outside mirror light and the locking glove compartment
Mate I only know about the mirror light. It is a 194/W5W. To change it you need to adjust the mirror towards the car. Turn it to the extreme. You need a torch to see the light which is of a shape of a stopper, grey in colour, with a set of wire sticking out. Twist it counterclockwise and the light bulb will come. Change it and put it back.
Warning: Make sure you secure the bulb when you push it in. Coz if it gone loose and drops into the mirror (esp where it suppose to sit), you will spend the next hour "fishing" it out.
The picture says it all:
1. Get a torch.
2. Turn the mirror as so.
3. Torch the gap in between and look for the grey stopper.
4. Turn anticlockwise and pull
5. Change light bulb (194/ W5W)
6. Put back in reverse order.
Takahashi is the name I get from the family I spent time with in japan. They said I like to eat chicken so I am a "Tori" :p It just happen Ryosuke is also a Takahashi. But Takahashi is such a common name
1. Get a torch.
Shankapotamus3
Mar 14, 2021 03:53 PM
drlubell
Sep 26, 2015 11:58 PM
Evan Gray
Sep 26, 2015 12:30 PM
