tranny issues. Too Weak....
Old Oct 1, 2004 | 05:03 PM
bam_bam_39's Avatar
I did a search and never found what I was looking for.
Anyways, yesterday I was taking off into traffic. I started easy enough in first, pulled second pretty hard, and then tried to put it in third and it wouldnt go so I resorted to 4th and then tried all the rest after I was coasting at about 25mph. It was like the clutch wouldnt disengage. So I stoped turned it off and put it in second and then started it. It kick fwd a bit and then it started and I took off. Then it got even weirder, I pressed in on the clutch and it was still engaged. the rpms never dropped. After that I nursed it home. Then today it woudl disengage and shift okay enough thru all gears but the tranny sounds shot and it feels like I have the e-brake half on and a little ft man shaking my tranny around in the mounts. I know I need to get it in the shop, but any clue what is the exact cause??
any reply is appreciated
bambam
Old Oct 1, 2004 | 05:17 PM
zoom44's Avatar
shift fork bent or broken
Old Oct 1, 2004 | 05:19 PM
bam_bam_39's Avatar
muchos gracias 44
bambam
Old Oct 1, 2004 | 05:22 PM
zoom44's Avatar
could be synchros too. but i still bet on shift fork(s). also you should make sure they check the pressure plate bolts. there have been a couple of instances of them backing out. incorrectly torqued at the factory
Old Oct 1, 2004 | 07:50 PM
bam_bam_39's Avatar
thanks again, ill be sure and tell them to check it(pressure plate) out for me
bambam
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
JAYDOH
Sep 24, 2015 01:54 PM
Juan Montenegro
Sep 10, 2015 06:28 PM
