Loose storage compartment door
Old Sep 27, 2004 | 02:10 PM
HeelnToe's Avatar
Does the sliding cover over your storage compartment have any play in it when closed?
You know, the one hiding the cupholders, where you rest your shifting arm.
The front of mine (towards shifter) moves side to side. I can't remember if it used to do that.
If you open the cover (tilt up), you'll see an L-shaped tab which slides into a groove in the box, securing it. If you look close, you'll see a small plastic piece snapped onto that tab... which keeps popping off on mine.
However, even when snapped back on, the cover wiggles back and forth.
I'll have Mazda look at it eventually, but I'm just curious if that play is normal...?
Old Sep 27, 2004 | 05:09 PM
Liquid Rhino's Avatar
Keepin' It Real Since '79
Mine does this all the time since the day I got it... it's ANNOYING to say the least, and after taking it for my first service, now the button that slides the armrest is also popping out & slanted. A friend of mine has an 8 & says hers doesn't do this at all.
GRRRRRRRRR
Old Sep 27, 2004 | 05:42 PM
romulus's Avatar
I had the button pop out slanted after 8K miles but I was able to fix it my self. I am working on a DIY to show how to fix it. Basically with the heat of the summer one of the tabs/stopper started to flex to the point that it pops out of the housing. I did fixed the tab by using a hair dryer. Hopefully I will have the DIY posted soon. By the way, after the fix it hasn't happened again at 12K miles
Old Sep 27, 2004 | 08:27 PM
They replaced my lid under warranty............I kept the extra clips off the old one that weren't broken for next time one breaks......I'm surprised that you can't get the clips.......
they seeemed OK with replacing the whole part
Old Sep 27, 2004 | 08:40 PM
snap-on's Avatar
The over is not designed to open when it is in position under your elbow.
It needs be slid rearward so the tabs won't break. Once is all it takes to tabs and it will never be the same.
Old Sep 27, 2004 | 09:48 PM
HeelnToe's Avatar
True, I'm sure I've popped it open before it was slid all the way back.
And I take one thing back: it does NOT wiggle when the tab is on. When I tested it earlier and it wiggled, I didn't realize the dang thing had popped off again, lol. So hopefully a new tab thingie will fix it for good.
Lemme guess... those tabs probably run around $25 each?
Old Sep 27, 2004 | 09:51 PM
snap-on's Avatar
You can't get the tabs last I checked..Some were replaced WAY back when the sales guys (no caps on purpose) broke them.. If you have a good dealer maybe they can replace the console lid... :D
Old Sep 27, 2004 | 10:20 PM
RotorGeek's Avatar
Still spining
My clips are also broken and I plan on getting them fixed when I go to the dealer for my oil change
Old Sep 28, 2004 | 08:41 AM
JCaldwell's Avatar
I also had the problem of the 'slanted button', and there is a LOT of play in the sliding lid.
Took my car into the deal for my oil change, he looked at it and said they'll replace entire lid assembly under warranty. No problem at all.
So far very happy with dealer service (Bob Moore in Oklahoma City).
Old Sep 28, 2004 | 10:26 AM
zoom44's Avatar
i dont rest my arm on there.
Old Sep 28, 2004 | 10:34 AM
rx8pilot's Avatar
Watch your six
Bottom line is guys.. this is a problem with EVERY SINGLE RX-8.. and the ones without the problem don't use it as an armrest or are very careful with it. Don't let your passenger use it as an armest or to push off of when they get out..and don't do it yourself and it will last alot longer. Mazda engineers really should have spent an extra 30 min. branstorming this one....
Old Sep 28, 2004 | 10:45 AM
Jump120MPH's Avatar
Soccer Fan
What happend to ya? We had a meet on Sat.
Old Sep 28, 2004 | 11:22 AM
romulus's Avatar
I just posted a fix for the slanted button in the DIY section for those who want to fix it by themself.
Old Oct 7, 2004 | 12:06 AM
newcastle's Avatar
Carbon Fiber Roof
Yeah I too have the slanted button in addition to the loose lid (it annoys the hell out of me). I'll eathier end up taking it to the dealer or just have my friend at the machine fhop make me a METAL button.
Old Oct 7, 2004 | 12:15 AM
thew's Avatar
Thews8
broken clips
Old Oct 7, 2004 | 07:21 AM
Deslock's Avatar
WWFSMD?
Yeah, I notice that it often gets pushed off its track because my passenger has been resting on it. I just pop it back on when that happens... it doesn't appear to be a big deal.
Old Oct 7, 2004 | 08:19 AM
DukeGG1's Avatar
until the day I die
Dealer fixed mine when I was in for my first oil change. Has been fine since.
Old Oct 7, 2004 | 09:23 AM
JM1FE's Avatar
Originally Posted by newcastle
have my friend at the machine shop make me a METAL button.
I'd be interested in either a metal frame/clips so that it wouldn't get broken by normal use, or an entire aluminium cover. If your machine shop friend could make these, I'd buy 1 or 2, and it might become a staple of this group like the grills from Hymee and others.
Old Oct 7, 2004 | 05:25 PM
w0rm's Avatar
PUSHER ROBOT
A clean, machined cover or even just clip assembly would be great if we could find someone to make them.
Old Oct 11, 2004 | 08:52 PM
newcastle's Avatar
Carbon Fiber Roof
Once I get one made i'll test it out and verify that it will fit and work properly (I dont know about the aluminum cover part though, I just need the damn clip to be metal/aluminum). Anyways i'll keep you guys posted.
Old Mar 23, 2007 | 09:10 AM
Krasnog's Avatar
Official Reposter
Thread revival... anyone ever find a 'sturdy' fix for this?
Old Mar 23, 2007 | 10:54 AM
New Yorker's Avatar
Mine was slanted, too—dealer replaced under warranty. My new one doesn't slide back completely smoothly, feels a little rough. I wonder if a little WD-40 would help.
Old Mar 24, 2007 | 01:54 AM
Targatheory's Avatar
My whole cover actually comes right off. Mine is terrible. It doesn't "click" and lock when I slide it back. And the whole thing wiggles hella bad. My car is a used 04 and it has no more stock warranty. I got an "extended" warranty from my dealer, would that be able to fix it?
Old Dec 17, 2009 | 03:13 PM
K.C.C.'s Avatar
I know this is a very old thread but does anyone have a picture of the said "clip" that pops out? On my used RX8, the cover has a play, but I can't figure out what and where the clip is.
Old Dec 18, 2009 | 03:54 AM
rodjonathan's Avatar
silent assasin
can you get the clips separate from the other part
