In what order should I do these....
Old Sep 23, 2004 | 07:41 PM
LittleJohn's Avatar
Hi,
I know this has been discussed before, I tried search but I'm obviously using the wrong keywords..
MS Sway bars
MS shocks & springs
MS F&R strut bars
MS Performace bars (chassis bracing)
Light weight flywheel & heavy duty clutch
Lightweight Wheels
UD pulleys
Hymee exhaust
Hymee SC :-) please hymee please...come though with this :p
TIA
Old Sep 23, 2004 | 08:16 PM
epitrochoid's Avatar
Riot Controller
in that exact order, but skip the UD pulleys and use some lightened ones
Old Sep 23, 2004 | 08:20 PM
shelleys_man_06's Avatar
Not anymore
It's okay to make a thread of your own.
Personally, I would focus on extracting more power from this engine, if the resources were available. Your path is fine for the time being. Good luck with your project.
Old Sep 23, 2004 | 10:25 PM
mspeed11's Avatar
drift addict
i really think you should focus more on handling for now. there are so many great products for suspension and brakes and the same could not be said so confidently about hp gainers. the sways and drop make my car so much fun to drive and being able to really stop is a life saver:D
Old Sep 23, 2004 | 11:39 PM
IZoomZoomI's Avatar
Boost needed
you should change the shocks and springs to something offers more flexibility, like tein or jic coilovers...
Old Sep 25, 2004 | 11:19 AM
mspeed11's Avatar
drift addict
i dont think the stock shoks are that bad for now. i use them with cut mspeed springs and they work great. dont fix it unles its broke:D
Old Sep 25, 2004 | 09:55 PM
Not anymore
Cut springs? Cutting springs, whether stock or aftermarket, is a big no-no. You'll definitely mess up your ride. If you use a cutting torch to cut a spring, I believe the heat can cause deformation, at a visible, or atomic level.
Old Sep 25, 2004 | 11:30 PM
robertdot's Avatar
It's debatable. The book that pur nrg suggested didn't bitch and moan about cutting springs. It's really a poor-mans fix. People have been doing it for decades. My dad used to heat his leaf springs to get a drop because he was poor (this was when you could get a hamburger for a quarter) :P
As long as you aren't bottoming out, you're fine. You might have to replace your springs sooner, or your shocks, but those are meant to take wear. If you are bottoming out, however, you might want to replace them soon.
Old Sep 26, 2004 | 01:56 PM
mspeed11's Avatar
drift addict
my car rides great and every one that rides in it concurs 100% ........poor mans fix? ....bingo . . . . i am a poor man. a poor man with a tight ride. there are no probs with my drop and that with the sways is good enough to go up aginst anyones 8 on here on the skid pad or track:D sorry the mspeed springs droped it about 1/2". . . . . what a joke!!!!!!! but now im tucking them bad boys. and if something brakes......oh well i guess thats why i have friends that work at mazda.
Digitz0070
55
Jul 25, 2017 08:40 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
FubarI33t
Sep 28, 2015 08:45 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
