What is a Camber Plate and what does it do?
Old Sep 22, 2004 | 11:33 AM
ScudRunner's Avatar
On time, on target
SR Motorsports sells them...
Attached Thumbnails What is a Camber Plate and what does it do?-rx8_camber_plates.jpg
Old Sep 22, 2004 | 11:49 AM
PUR NRG's Avatar
Easy answer: Camber plates allow you to adjust camber to a greater degree than you can without it.
Maybe the real question you should be asking is what is camber? Google can help with that.
________
List of transmissions
Old Sep 22, 2004 | 11:54 AM
Ophitoxaemia's Avatar
dizzy snake pilot
the other main use of them is to allow cars with highly lowered suspensions to achieve normal camber settings for street use.
james
Old Sep 22, 2004 | 12:19 PM
connor@tirerack's Avatar
Forum Vendor
These are the best reference's i could find for the definitions of alignment terminology.
Camber
The camber angle identifies how far the tire slants away from vertical when viewed directly from the front or back of the vehicle. Camber is expressed in degrees, and is said to be negative when the top of the tire tilts inward toward the center of the vehicle and positive when the top leans away from the center of the vehicle.
Since street suspensions cannot completely compensate for the outer tire tipping towards the outside when the vehicle leans in a corner, there isn't a magical camber setting that will allow the tires to remain vertical when traveling straight down the road (for more even wear), and remain perpendicular to the road during hard cornering (for more generous grip).
Different driving styles can also influence the desired camber angle as well. An enthusiastic driver who corners faster than a reserved driver will receive more cornering grip and longer tire life from a tire aligned with more negative camber. However with the aggressive negative camber, a reserved driver's lower cornering speeds would cause the inside edges of the tires to wear faster than the outside edges.
What's the downside to negative camber? Negative camber leans both tires on the axle towards the center of the vehicle. Each tire develops an equal and offsetting "camber thrust" force (the same principle that causes a motorcycle to turn when it leans) even when the vehicle is driven straight ahead. If the vehicle encounters a bump that only causes one tire to lose some of its grip, the other tire's negative camber will push the vehicle in the direction of the tire that lost grip. The vehicle may feel more "nervous" and become more susceptible to tramlining. Excessive camber will also reduce the available straight-line grip required for rapid acceleration and hard stops.
Appropriate camber settings that take into account the vehicle and driver's aggressiveness will help balance treadwear with cornering performance. For street-driven vehicles, this means that tire wear and handling requirements must be balanced according to the driver's needs. The goal is to use enough negative camber to provide good cornering performance while not requiring the tire to put too much of its load on the inner edge while traveling in a straight line. Less negative camber (until the tire is perpendicular to the road at zero camber) typically will reduce the cornering ability, but results in more even wear.
Even though they have some of the most refined suspensions in the world, the next time you see a head-on photo of a Formula 1 car or CART Champ Car set up for a road course, notice how much negative camber is dialed into the front wheels. While this is certainly an example of wear not being as important as grip, negative camber even helps these sophisticated racing cars corner better.
Caster
The caster angle identifies the forward or backward slope of a line drawn through the upper and lower steering pivot points when viewed directly from the side of the vehicle. Caster is expressed in degrees and is measured by comparing a line running through the steering system's upper and lower pivot points (typically the upper and lower ball joints of an A-arm or wishbone suspension design, or the lower ball joint and the strut tower mount of a McPherson strut design) to a line drawn perpendicular to the ground. Caster is said to be positive if the line slopes towards the rear of the vehicle at the top, and negative if the line slopes towards the front.
A very visual example of positive caster is a motorcycle's front steering forks. The forks point forward at the bottom and slope backward at the top. This rearward slope causes the front tire to remain stable when riding straight ahead and tilt towards the inside of the corner when turned.
Caster angle settings allow the vehicle manufacturer to balance steering effort, high speed stability and front end cornering effectiveness.
Increasing the amount of positive caster will increase steering effort and straight line tracking, as well as improve high speed stability and cornering effectiveness. Positive caster also increases tire lean when cornering (almost like having more negative camber) as the steering angle is increased.
What's the downside to positive caster? If the vehicle doesn't have power steering, a noticeable increase in steering effort will be felt as positive caster is increased. Other than that, the effects of positive caster are pretty much "positive," especially increasing the lean of the tire when the vehicle is cornering while returning it to a more upright position when driving straight ahead.
Cross-Camber and Cross-Caster
Most street car alignments call for the front camber and caster settings to be adjusted to slightly different specifications on the right side of the vehicle compared to the left side. These slight side-to-side differences are called cross-camber and cross-caster.
For vehicles set up to drive on the "right" side of the road, the right side is aligned with a little more negative camber (about 1/4-degree) and a little more positive caster (again, about 1/4-degree) to help the vehicle resist the influence of crowned roads that would cause it to drift "downhill" to the right gutter. Since most roads are crowned, cross-camber and cross-caster are helpful the majority of the time, however they will cause a vehicle to drift to the left on a perfectly flat road or a road that leans to the left.
Using cross-camber and cross-caster is not necessary for track-only cars.
Toe
The toe angle identifies the exact direction the tires are pointed compared to the centerline of the vehicle when viewed from directly above. Toe is expressed in either degrees or fractions-of-an-inch, and an axle is said to have positive toe-in when imaginary lines running through the centerlines of the tires intersect in front of the vehicle and have negative toe-out when they diverge. The toe setting is typically used to help compensate for the suspension bushings compliance to enhance tire wear. Toe can also be used to adjust vehicle handling.
A rear-wheel drive vehicle "pushes" the front axle's tires as they roll along the road. Tire rolling resistance causes a little drag resulting in rearward movement of the suspension arms against their bushings. Because of this, most rear-wheel drive vehicles use some positive toe-in to compensate for the movement, enabling the tires to run parallel to each other at speed.
Conversely, a front-wheel drive vehicle "pulls" the vehicle through the front axle, resulting in forward movement of the suspension arms against their bushings. Therefore most front-wheel drive vehicles use some negative toe-out to compensate for the movement, again enabling the tires to run parallel to each other at speed.
Toe can also be used to alter a vehicle's handling traits. Increased toe-in will typically result in reduced oversteer, help steady the car and enhance high-speed stability. Increased toe-out will typically result in reduced understeer, helping free up the car, especially during initial turn-in while entering a corner.
Before adjusting toe outside the vehicle manufacturer's recommended settings to manipulate handling, be aware that toe settings will influence wet weather handling and tire wear as well.
Excessive toe settings often bring with them drivability problems, especially during heavy rain. This is because the daily pounding of tractor trailers on many highways leave ruts that fill with water. Since excessive toe means that each tire is pointed in a direction other than straight ahead, when the vehicle encounters a puddle that causes only one tire to lose some of its grip, the other tire's toe setting will push (excessive toe-in) or pull (excessive toe-out) the vehicle to the side. This may make the vehicle feel unsettled and very "nervous."
Additionally the vehicle's toe is one of the most critical alignment settings relative to tire wear. A toe setting that is just a little off its appropriate setting can make a huge difference in their wear. Consider that if the toe setting is just 1/16-inch off of its appropriate setting, each tire on that axle will scrub almost seven feet sideways every mile! Extend it out and you'll discover that rather than running parallel to each other, the front tires will scrub over 1/4-mile sideways during every 100 miles of driving! Incorrect toe will rob you of tire life.
Thrust Angle
The thrust angle is an imaginary line drawn perpendicular to the rear axle's centerline. It compares the direction that the rear axle is aimed with the centerline of the vehicle. It also confirms if the rear axle is parallel to its front axle and that the wheelbase on both sides of the vehicle is the same.
If the thrust angle is not correct on a vehicle with a solid rear axle, it often requires a trip to the frame straightening shop to correctly reposition the rear axle.
A vehicle with independent rear axles may have incorrect toe-in or toe-out on both sides of the axle, or may have toe-in on one side and toe-out on the other. The suspension on each side of the vehicle must be adjusted individually until it has reached the appropriate toe setting for its side of the vehicle.
An incorrect thrust angle is often caused by an out-of-position axle or incorrect toe settings. So in addition to the handling quirks that are the result of incorrect toe settings, thrust angles can also cause the vehicle to handle differently when turning one direction vs. the other.
Alignment Ranges
The vehicle manufacturers' alignment specifications usually identify a "preferred" angle for camber, caster and toe (with preferred thrust angle always being zero). The manufacturers also provide the acceptable "minimum" and "maximum" angles for each specification. The minimum and maximum camber and caster specifications typically result in a range that remains within plus or minus 1-degree of the preferred angle.
If for whatever reason your vehicle can't reach within the acceptable range, replacing bent parts or an aftermarket alignment kit will be required. Fortunately there is a kit for almost every popular vehicle due to the needs of body and frame shops doing crash repairs and driving enthusiasts tuning the suspensions on their cars.
Old Sep 22, 2004 | 12:26 PM
PoLaK's Avatar
Son what is your Alibi?
If that wasn't all copy and pasted we have a new "longest post record" surpassing rotarygod.
BTW conor im ready to buy some blizzack lm-22's on the rims you guys offer in the package you have a lot left? or should i rush to get them?
Old Sep 22, 2004 | 12:39 PM
Forum Vendor
Stock is still ok with the Blizzak LM-22. The ASA JS1 has temporarily sold out until around the end of December. the next lowest priced wheel i have in stock would be the Kazera KZ-V at 129.00 each and as of right now i have 22 in stock. the sensors are 114.00 each and show 19 in stock.
just let me know when your ready.
Old Sep 22, 2004 | 12:50 PM
Dark8's Avatar
Ride Naked!
What? Correct me if I am wrong, but adjusting the coil-over geometry on the front suspension on an RX-8 will have no effect on camber seen by the wheel. Our camber is set by adjusting the A arms. Why would anyone waste the money?
Edit: I guess if they are selling them as a coil-over pillow ball upper mount and not a true camber plate it would be useful.
Old Sep 22, 2004 | 03:49 PM
dizzy snake pilot
dark8, you are correct, ive seen camber plates mostly for macpherson strut equipped cars where the camber can be directly controlled by the placement of the upper part of the strut.
(for a performance car, the double a-arm suspension in the rx8 is considered superior to the strut. )
what is a pillow ball upper mount?
james
Old Sep 22, 2004 | 06:23 PM
Dark8's Avatar
Ride Naked!
james
A "pillow ball mount" is a spherical bearing usually made of some type of metal. It eliminates the shocks rubber upper mounts to make the shock movement and reaction more precise. It will however transmit more road noise (vibration) to the body. Most higher end coil-overs come with them.
Old Sep 22, 2004 | 07:37 PM
bgreene's Avatar
Time of your life, kid...
The front's a double wishbone, but the back suspension is still a linkage system, and I can attest for a fact that lowering the car will impact rear camber. Still need to get mine in for the adjustment, in fact (it's not too bad, but it is noticable just eyeballing the car).
Old Sep 22, 2004 | 08:00 PM
Dark8's Avatar
Ride Naked!
Correct, but camber plates will not help the rear either. Camber plates will only help adjust camber on strut suspensions. Camber plates have no application on RX-8s. That's why I find it funny that SR Motorsports would advertise "camber plates" instead of "pillow ball shock mounts" or "spherical bearing shock mounts" for our car.
Old Sep 24, 2004 | 07:04 AM
tokenbrit's Avatar
6Spd Blue 230
Great explaination of camber etc.. Connor. Do you think you can provide something similiar with regards to spacers, and offsets please??... Like most people, I like to know what I'm doing to my car before I actually do it.
Thanks.
duworm
Oct 1, 2015 04:57 PM
coolcars44
Sep 24, 2015 05:47 PM
titaneum_grey
Sep 16, 2015 11:51 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
