Wheel spacers, and offsets?
Old Sep 21, 2004 | 07:55 AM
tokenbrit's Avatar
6Spd Blue 230
I was thinking about putting spacers front & rear on the wheels to fill out the wheel wells a little more, but was worried about handling characteristics etc... Has anybody out there gone to the trouble of working out the optimum?? I read somewhere 23mm rear, 18mm front (I think ). I am thinking that this is maybe a little too much?
And, can somebody please explain to me the way that offsets work. I have no clue.
Thanks.
Old Sep 21, 2004 | 12:42 PM
Fanman's Avatar
I thought the factory offsets were 50 mm. I am looking at the 6.5 mm spacers (about 1/4 of an inch). I wa told that 1/2" (13 mm) was about the best, anything else beyond that and it would negatively affect your handling.
Old Sep 22, 2004 | 09:12 AM
tokenbrit's Avatar
6Spd Blue 230
Thanks.
Anyone???.....
Old Oct 21, 2004 | 08:15 PM
RocketMonkey68's Avatar
i was told its not safe to use spacers
Old Oct 21, 2004 | 09:29 PM
Dark8's Avatar
Ride Naked!
From my VW GTI 1.8t days: They can be safe to use if you maintain them and use longer studs. Your lug nuts will have a tendency to loosen up over time so you need to check them periodically (like you should be anyway?) And remember, if you throw a half inch spacer in there you have half an inch less stud for the nut to thread on to, so use longer studs. Before the longer studs I couldn't keep the nuts from loosening when using a 10mm spacer. After the longer studs they never loosened up.
Old Oct 26, 2004 | 10:50 AM
KYRX8's Avatar
typically a 1/4" spacer is safe with the stock studs. We sell spacers all day long at work and as long as you re-check the torque of your lug nuts from time to time you should be alright. Anything bigger than a 1/4" is not recommended without replacing the studs.
Old Oct 26, 2004 | 11:30 AM
Cam's Avatar
Cam
this space for rent
Heres a good explanation from tirerack
http://www.tirerack.com/wheels/tech/offset.htm
92trbolzr
May 18, 2025 09:04 AM
hufflepuff
May 30, 2016 10:45 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
