New owner looking for advice
Old Sep 11, 2004 | 06:57 PM
away_27's Avatar
away_27
Hey guys, I just purchased my RX-8 about 2 weeks ago. It's just a base model 6spd but I got it for about a $1K under invoice so I'm happy with it. So I've got a few questions, how important is this break in period and is 600 miles like the manual says the appropriate break in time or should I give it more time? Also when I need to add some oil what should I use? I was thinking I would switch to synthetic after my first or second oil change but what should I use in the mean time? Other than that I'm just trying to get acquainted with my new baby! Feel free to respond with any other advice you guys can give to a new RX8 owner!
Old Sep 11, 2004 | 07:10 PM
RevTo9K's Avatar
1.3L is enough 4 anybody
Congrats on your new purchase!
Check this link out on break-in of your 8:
https://www.racingbeat.com/RX8%20Break%20in.htm
I'd definitely break it in gently. Also, don't start it up, move it, and shut it down cold or there's a risk of flooding and trouble starting the next time. Last, check your oil every 2nd fill-up and top up when needed - rotaries burn oil by design.
Last, use the search feature above to find all of the great info on these forums. (Although if you search for 'break in' it omits 'in' because it's too short... GRRR....)
Old Sep 11, 2004 | 07:19 PM
manchestah's Avatar
Lightbulb
Fresh oil never hurt an engine, so stick to the 600 mile guidance - I will be cahnging oil every 2,000 miles, not synthetic as that heavy price tag is so you can skip oil changes (generalization).
I swithced from 5W/20 to 5W/30 as all European manuals advise, the 30 will be better for the engine but perhaps dilute Mazda North America's "CAFE" need to go low.
Do not worry about topping up with 5W/30 over the presumably factory 5W/20 - it is not an issue to change "on the run" to a higher viscosity as long as you keep the base (5W) the same.
The rotary engine feeds lub oil (injected delibeartely into each rotor housing) so check the oil level every other fuel fill up.
Summary - change frequently, forget synthetics, use 5W/30.
Hope this helps?
Cheers!
Old Sep 11, 2004 | 07:52 PM
michael d's Avatar
Oil injection
I understand that oil is injected into the back of the rotors to cool them and lube the gears etc, where do the apex seals etc get lubrication, does the oil really get contaminated like a recip??
Old Sep 12, 2004 | 08:33 AM
sexy_black's Avatar
sexxyblack
my dealer told me if i used synthetic oil, it would void the warranty on the car...i had to sign an agreement saying that he had gone over this with me...i'd look into that if i were you.
Old Sep 12, 2004 | 02:34 PM
ggreen29's Avatar
You've got it right in a sideways sort of way, as I understand it. The oil injectors inject oil into the intake chamber. If yer sittin' in your car, imagine yer looking at the engine as a clock. Intake is at about 2:00, oil injection (like fuel injectors, only they squirt oil-apparently two per rotor) is at ~1:00, trailing plug is ~10:00, lead plug is at 8:00, and exhaust is ~4:00; rotors spinning CCW.
The oil injector lubes the apex seals. The oil that is used to cool the back of the rotors and lube the gears etc, comes from oil coolers, thru the e-shaft and into the rotor interior, then to the oil pan. At least this path is the way it worked in the 2nd gen rotaries.
Old Sep 12, 2004 | 03:14 PM
RUmble's Avatar
Racing beat really puts a lot more restrictions on the break-in period. First 1000 miles nothing over 4000 RPMS??? The car will be slower than my Altima!
WranglerFan
Aug 21, 2022 01:29 PM
ndamix
Sep 18, 2015 03:04 PM
teamdipngo
Sep 14, 2015 02:47 PM
stickmantijuana
10
Sep 13, 2015 11:28 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
