headlight help
Old Sep 8, 2004 | 11:52 AM
subduedracer's Avatar
Realtor1
headlight help
Okay guys, I need help. Do you have to remove the front bumper to take the headlights out? How about the fog lights as well?
Old Sep 8, 2004 | 09:42 PM
Yes....very easy though... remove side marker lenses, machine screws from the lower pan, and the moulding by the hood latch...then remove the 4 bolts under the moulding, the wires from the fogs, and the hose from the headlight washers if present....then lift bumper assembly, and carefully pull out on corners of bumper near clear corner mounts....should come off easily.............reverse to install. I hope I didn't forget anything :D
Headlights unbolt after the bumper is removed....
Old Sep 12, 2004 | 01:35 PM
Realtor1
Thanks man! I glad to hear its not crazy azz hard to remove. I hope I can do it in a few hours time.
Shankapotamus3
Mar 14, 2021 03:53 PM
drlubell
Sep 26, 2015 11:58 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
