Aftermarket Sway Bars - Which one will feel closest to MS?
Old Sep 6, 2004 | 03:28 PM
brillo's Avatar
Go Texas Longhorns!
Since the MS Sways are so much more expensive, I'm looking at the other options which are Racing Beat and tanabe. Now I will likely get the MS springs and shocks, and I assume those have been tuned for the MS sways. I'm not into mixing and matching, so I'm trying to figure out which sway will feel the closest. I'm not sure how the diameter vs. thickness affects things. I collected the following data on all the sways and I'm trying to see what I can learn from it. I would appreciate any thoughts.
Sway Bars Front Thickness Rear Thickness
Stock 27.0 3.4 16.0 2.5
RB 32.0 4.8 19.0 3.2
MS 27.2 4.0 17.3 2.6
Tanabe 30.4 NA 20.0 NA
Old Sep 6, 2004 | 09:07 PM
310Guy's Avatar
4AT poor mileage king
If you're not into mixing and matching, don't do it. Save up for the Mazdaspeed sways.
Old Sep 6, 2004 | 11:59 PM
AlexCisneros's Avatar
The MS will be most like the MS...
...That said, I highly recommend the Tanabe Bars.
Old Sep 7, 2004 | 10:22 PM
cortc's Avatar
Most of the ones available are good choices...
Alex: Your car looks great, like the wheels...
Old Sep 7, 2004 | 10:31 PM
:D thanks! :D
so are you going to join us on the 26th?
Old Sep 8, 2004 | 05:17 AM
Ophitoxaemia's Avatar
dizzy snake pilot
dont forget a sway bar is just a spring that loads in torsion- you can choose simply by diameter and mounting point. the bushings and endlink design might be better on one or another, but there is no magic here.
it is much more important to make sure there is no pre-load on the bar. that is, when the car is on a level, flat surface, the bar is not twisted at all.
james
Old Sep 8, 2004 | 09:08 AM
cortc's Avatar
I just put in a call to see if the new wheels will be ready... If not I will just grab a demo off the lot and take a stock RX8...
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Brokegang
Jan 3, 2016 12:45 PM
zoom44
General Automotive
Nov 16, 2015 11:38 PM
Steve Dallas
Sep 19, 2015 09:39 AM
