Problem with CZ.1 ?
Old Aug 22, 2004 | 02:14 AM
robotman's Avatar
Question Problem with CZ.1 ?
Hi
As I was pulling out from the garage going to work. A cel popped up on the dash, after I got back from thinking about it all day I turned off the CZ box and the light went out. So I removed the unit and plugged it all back in. Restarted the car, now the cel is back.. I'll be making an appointment with the dealer to have the car checked out. I thought I had it fixed when I turned off the CZ Box.
Old Aug 22, 2004 | 10:51 AM
IZoomZoomI's Avatar
Boost needed
how long you had the cz unit? Did you reset the pcm before turning the engine on? Also check the switch on the unit to make sure its fully on. Might be numerous things. I suggest you do a search b/c there has been a lot written about this issue.
Old Aug 22, 2004 | 02:49 PM
Omicron's Avatar
Do NOT take the car in for warranty service with the CZ box attached! It's not considered to be a Mazda-approved mod, and your dealership is apt to void your warranty. Instead, call Maurice at CanZoomer.
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
