Royal Purple Tranny/Diff Fluid Swap
Old Aug 21, 2004 | 11:01 PM
brillo's Avatar
Go Texas Longhorns!
Thumbs up Royal Purple Tranny/Diff Fluid Swap
After passing 2K miles, I finalyl got around to changing out my stock tranny and diff fluid over to Royal Purple synthetic, man what a difference. First and foremost, the 1st to 2nd shift is so much smoother, as is the 2nd to 3rd, in fact those gears shift like shifting from 3rd to 4th, no jolting, not nearly as notchy, just very fluid.
the vibration in the shifter is also somewhat less, which is nice. Still feel some vibration at idle, but also not as bad as before. It will be interesting to see over the next few days have it feels as it breaks in. Little early to tell if it will help gas mileage, but this is a must for all you guys. Why don't they put this stuff in stock??? :D
Old Aug 22, 2004 | 12:27 AM
wakeech's Avatar
mostly harmless
so you've used a heavier weight then??
they don't put it in stock because mineral more than suffices, and it's a cost issue (like everything else). i know that was rhetorical, i like being annoying sometimes :p
Old Aug 22, 2004 | 12:09 PM
Fanman's Avatar
I recently saw an episode of "Horsepower TV" where they swapped the differential, transmission & engine oil with Royal Purple and they wound up getting another 8 hp from their Camaro SS. Stated that it really opened up their engine and made it quite a bit more efficient.
Old Aug 25, 2004 | 08:53 PM
ezrider55's Avatar
A DIY or did you take it to a shop? What shop? :D
Old Aug 25, 2004 | 09:32 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Just more reason to make me go out and buy stuff for the 8!
This also helps justify the spending..
Old Aug 25, 2004 | 11:08 PM
brillo's Avatar
Go Texas Longhorns!
I had MazMax do it for me, it was $120 total for fluid and work. You need about 6qt's of the stuff, which isn't cheap, so if you DIY plan on spending about $66 for the material. But it is so worth it. Best thing I have done to the car.
Old Aug 25, 2004 | 11:44 PM
shelleys_man_06's Avatar
Not anymore
Neat. I'll be needing new differential fluid whenever I get some FI. Thanks for the tip brillo.
Old Aug 25, 2004 | 11:48 PM
B-Nez's Avatar
6 quarts? really? The capacity specified in the workshop manual is 1.4 qt. for the diff, and 1.85 qt. for the tranny. I'm purpling my diff tomorrow and red lining my tranny in 2 weeks. I figured 2 quarts each ought to do it. Also, another forum member PM'ed me that he used a total of four. Did MazMax maybe use 2 quarts to "flushed" the tranny and diff?
Old Aug 25, 2004 | 11:49 PM
B-Nez's Avatar
Also wanted to ask you: did you use MaxGear 75W-90 for both tranny and diff?
Old Aug 25, 2004 | 11:57 PM
cgrx's Avatar
DRIVEN
Tomorrow I'm going to "redline" my MT and diff.
Should be fun, I'll post pics on the site somewhere.....
Old Aug 26, 2004 | 08:03 PM
ezrider55's Avatar
When I had mine done they only used 2 qts. of each. I have read that there is no need to flush so I did not ask them to.
Old Aug 26, 2004 | 08:07 PM
bgreene's Avatar
Time of your life, kid...
I did my own with redline, and it only takes 2 quarts of tranny oil and 2 quarts of diff oil.
Old Aug 26, 2004 | 08:51 PM
brillo's Avatar
Go Texas Longhorns!
Yes I used 75W-90 for both, its hard to find a straight synthetic 90 and both RP and MazMax said it was fine. The spec's for the capacities are not including some other reservoir, I'd have to ask MazMax where the other fluid goes. Brian at MazMax is a member of our Houston RX club, so he's a good guy and I know he knows what he's doing since he has 2-3? rotors currently....so I trust him.
Old Aug 26, 2004 | 08:59 PM
B-Nez's Avatar
Yeah, there is also a TSB from MNAO stating that due to lack of availability, 80W-90 or 75W-90 are also acceptable for the diff.
Old Aug 26, 2004 | 09:04 PM
Tony Orlando's Avatar
Bored thread resuscitator
Synchromax in the tranny, Max gear in the diff. Check the sig: Royal Purple RULES!!! :D
Old Aug 26, 2004 | 09:38 PM
bureau13's Avatar
Tony Orlando, why did you go with the Synchromax? From reading the RP site, it appeared to me that MaxGear 75W90 should be used in both tranny and diff.
jds
Old Aug 26, 2004 | 10:16 PM
rx8cited's Avatar
Senior Member
jds
4 u :
https://www.rx8club.com/showpost.php...6&postcount=13
rx8cited
Old Aug 26, 2004 | 10:58 PM
brillo's Avatar
Go Texas Longhorns!
I had the max gear all the way around, as its the only one that meets the specs for both.
Old Aug 26, 2004 | 11:59 PM
whosyourbaba's Avatar
so im about to get some royal purple. let me get this straight, i wanna make sure before i put this stuff in, sorry.
differential - MaxGear 75W90
gearbox - Synchromax
this is for manual. thanks a lot.
Old Aug 27, 2004 | 12:14 AM
Air Force RX8's Avatar
Who Cares?
I'm with who on this...spell it out for me I'm slow sometimes.
Old Aug 27, 2004 | 12:18 AM
B-Nez's Avatar
whosyourbaba, I'm not sure if Synchromax is a good idea for the transmission. Maybe RP specifically told tony it was fine, but the product description states it is primarily for manual trannies that takes ATF. The MaxGear would be the most appropriate for both the diff AND the tranny.
Old Aug 27, 2004 | 12:23 AM
i was just trying to follow what others were saying, thanks for the advice. i found a local shop that carries redline, so im going redline since im positive on what to get.
Old Aug 27, 2004 | 12:53 AM
B-Nez's Avatar
Good choice. I ordered Red Line MT-90 for my transmission. I wasn't convinced that the combined GL-4/GL-5 rating of the RP would result in the best shifting action. It'll do just fine in the differential, though.
Old Aug 27, 2004 | 12:57 AM
cgrx's Avatar
DRIVEN
https://www.rx8club.com/series-i-tech-garage-22/changing-fluids-%3Deasy-fun-37600/
Old Aug 27, 2004 | 11:44 AM
bureau13's Avatar
That tells me not to put Synchromax in the diff, but not the other way 'round.
jds
Originally Posted by rx8cited
