View Full Version : Mazda Safety Question!
Haris
04-04-2003, 09:51 AM
Ok, if you have RX8 and if somebody hits you at the back won't the 2 doors get like smashed in each other since there are no pillares. If they get smashed, how would u get out of the car? And in some cases, if it was even on fire?
Lensman
04-04-2003, 09:58 AM
The doors ARE braced, the closure forms a virtual pillar that has been crash tested and proved excellent. Also, the floor of the car is massively braced too which would prevent the outcome you describe.
evel333
04-04-2003, 10:02 AM
There are B-pillars, but they are built into the leading edge of the rear doors. The chances of them being crumpled to the point of non-operation are no different than that of conventional doors. Moreover, the latch is farther from the impact area.
However, I do worry about the rear doors' reliance on the front doors in opening: should the front become inoperative, how would one open the rear?
Puppy1
04-04-2003, 10:04 AM
Exit through the moonroof. ;)
evel333
04-04-2003, 10:12 AM
Bravo! I usually drive w/it open anyway...
But what if you're upside down? (^_^)
Fëakhelek
04-04-2003, 10:16 AM
Rear seat pass-through. :D
gazita123
04-04-2003, 10:29 AM
Same thing you would do in a regular coupe, break the glass.
Superfan
04-04-2003, 11:07 AM
I was in an accident a few years ago that bent the frame of the car to the point that both doors were sealed. I just kicked the passenger door 3-4x around the latch area until it busted open. I knew it was a pretty bad accident because my car spun across 3 lanes, over a side walk, into a glass bus stop. I'll post a pic later of the car :D
