RX-8 Loud Squeek
Old Aug 16, 2004 | 05:07 PM
z00m-z00m's Avatar
RX-8 Loud Squeek
I have an issue. After I had new tires put on I started hearing a loud squeek when I was backing out of the garage. A metal sounding sound. I thought it was the brakes. I took it in they said the brakes were fine, couldnt replicate. I sometimes wonder if they even tried to check it out.
So i figured it wasnt when I pressed on the brakes. Because I backed out without using them. And When I take left turns at slow speeds I hear it also and if its early in the morning I can replicate but not so loud with right turns.. I checked the tires at all angels to see if they were touching anything, but I couldnt see any touching.
I dont know if its the brakes, tires, or something else.
Any clue?
Old Aug 16, 2004 | 05:19 PM
zoom44's Avatar
release the parking brake?
Old Aug 16, 2004 | 05:23 PM
z00m-z00m's Avatar
It is released. :P Wish it were that simple.
Old Aug 16, 2004 | 05:27 PM
adrian-1's Avatar
Ex- member.
http://www.finishlineperformance.com...02-002-04.html
Make sure the lug nuts are tighten to 108ft/lbs.
If that doesn't do it, take it in for warranty work. May be a loose endlink nut.
Old Aug 16, 2004 | 05:41 PM
z00m-z00m's Avatar
Ill have em check it out, the noise isnt snapping though unless the definition has changed :P
Old Aug 18, 2004 | 04:47 PM
z00m-z00m's Avatar
Front brakes worn down lower than 10% makes you wonder what that 'full circle inspection' thing is all about couz my brakes are always green.
Old Aug 18, 2004 | 06:27 PM
adrian-1's Avatar
Ex- member.
I thought they checked the brakes?
Old Aug 18, 2004 | 06:44 PM
z00m-z00m's Avatar
Well I took it to a different dealer. They told me it was from the brakes. I didnt believe it so I took it to a third dealer. All showed except the first the brakes were worn down. So we find out if indeed this corrects the issue. :P Ill find out tonight.
nowakm99
Oct 9, 2015 07:10 AM
vapor2
Sep 21, 2015 01:36 AM
czr
Sep 13, 2015 11:37 AM
just1jack
Sep 9, 2015 04:45 PM
Tsurugi
Sep 7, 2015 08:27 PM
