specs on an old 7
Old Apr 1, 2003 | 02:03 PM
RX-Nut's Avatar
8 the HARD way.
specs on an old 7
Anyone know where I can find engine specs on an 84 RX-7? I wanted to see what the HP and torque were..
Old Apr 1, 2003 | 02:20 PM
kwolfman's Avatar
No Gods For Me
I can tell you the 1981 RX7, it was 105HP, 100 FP torque. It was a 12A.
I would imagine the 84 was close to this. When did the GSL-SE come out? Didn't that have the 13B engine?
Old Apr 1, 2003 | 02:33 PM
wakeech's Avatar
mostly harmless
ahahahaha... what a car... the RX-8 has come by leaps and bounds.
if memory serves correct...
2600lb.
110hp, 90ish lb.ft on the 12A
but for the post-1988 RX-7's, i know by heart.
about 2800lb.
160hp, 130ish lbft. (as you can tell, i've never been one to focus on peak torque numbers )
Old Apr 1, 2003 | 02:34 PM
wakeech's Avatar
mostly harmless
ah ha!! right you are: the Series 4 13B...
that was 140hp, +120lb ft.
Old Apr 1, 2003 | 02:41 PM
RX-Nut's Avatar
8 the HARD way.
sweet! thanks for the info!
Old Apr 1, 2003 | 02:56 PM
gettingan8's Avatar
1984 and '85 GSL-SE:
13B engine - 1300 cc, 135 HP, special six port design,
electronic fuel injection. 14 inch wheels standard. Larger
disc brakes. Limited slip differential. Power steering
optional. Improved interior. Separate oil cooler mounted
under radiator.
Old Apr 1, 2003 | 04:02 PM
neit_jnf's Avatar
for 1984:
12A Engine (6 port design)
1146 cc
100 hp @ 6000 rpm
105 lbft @ 4000 rpm
Compression ratio of 9.4:1
redline 7000 rpm
Manual Gear ratios:
3.67
2.22
1.43
1.00
0.83
Final drive 3.91
Curb Wt 2325 lbs
53/47 % wt distribution
Drag coeff of 0.33
13B Engine (6 port design)
1308 cc
135 hp @ 6000 rpm
133 lbft @ 2750 rpm
redline 7000 rpm
Manual Gear ratios:
3.62
2.19
1.42
1.00
0.76
Final drive 4.08
Curb Wt 2635 lbs
50/50 % wt distribution
Drag coeff of 0.31
HOPE THIS HELPS!! :D
Old Apr 1, 2003 | 04:08 PM
RX-Nut's Avatar
8 the HARD way.
daaaaaaang excellent info.. THANKS a BUNCH!
Old Apr 1, 2003 | 05:10 PM
Smoker's Avatar
RX-8: Hmmmmmmmmmmmmm.....
question
Boyz,
If I'm to look up data of vechicles of the past and present, where can I go to quickly look up these spec's ? Any ideas. Thanks.
-Smoker
Old Apr 1, 2003 | 11:15 PM
neit_jnf's Avatar
Re: question
Originally posted by Smoker
Boyz,
-Smoker
Well, I bought the Cartest2000 performance calculation software and it has a database of over 1300 new and old cars, motorcycles and jetskis...
Old Apr 2, 2003 | 08:06 AM
SA22C's Avatar
Oversteer = Bliss
The specs on the early RX-7s are readily available at Beyond the Redline, a hosted site at teamf3cs.org. As for other cars, the free CarTest program has stats for a lot of older vehicles.
Old Apr 3, 2003 | 11:09 AM
Smoker's Avatar
Okay, I'll take a look at those .... thanks !
Quiggs321
Sep 30, 2015 05:34 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
djp6783
Sep 19, 2015 12:12 PM
patriotjj
Sep 13, 2015 08:09 AM
