4" exhaust tips
Old Aug 2, 2004 | 03:38 AM
tokenbrit's Avatar
6Spd Blue 230
4" exhaust tips
Does anybody have 4" exhaust tips? I got some Magnaflow one's the other day, and they look kinda large. I am now a little hesitant about putting them on my car. I thought the borla etc.. had 4" tips.
I don't want my car to look like a ricer (or boy racer'ey), but the standard 3" tips look a little small.
Anybody??
Pics of 4" tips would help me make my decision (if anybody has any??).
Thanks.
Old Aug 2, 2004 | 03:50 AM
BIU's Avatar
BIU
why are you double posting in here and the appearance section?
Old Aug 2, 2004 | 03:57 AM
tokenbrit's Avatar
6Spd Blue 230
On this occasion, I want as much info. as I can get. I have posted more than once, because the outcome means me hacksawing my stock muffler...
Old Aug 2, 2004 | 02:42 PM
MrWigggles's Avatar
I think the tips on the Borla RX-8 exhaust are 3.5" and the one on the Greddy are 4" if that helps.
I think everyone feels the Borla tips are perfectly fine. Most people think the Greddy are fine as well. Some do think the Greddy are a little big.
-Mr. Wigggles
Old Aug 2, 2004 | 02:53 PM
MazdaManiac's Avatar
The stock tips are 3". I just installed these 3.5" and I think they are perfect.
I test fitted 4" and I thought they looked ridiculous.
The Greddy exhaust looks too big IMHO.
Attached Thumbnails 4" exhaust tips-dsc00009.jpg   4" exhaust tips-dsc00010.jpg
Old Aug 2, 2004 | 03:36 PM
tokenbrit's Avatar
6Spd Blue 230
It's amazing how much difference 1/2" makes isn't it? I've got to admit that the 3 1/2" tips do look slightly better than the 4" tips in the pictures, but it isn't 'black and white'.
As I already have the 4" tips, I think I will try them now. :o I think I am now ready to take the risk , and I can always change to 3 1/2" ones (or buy another cat-back if these look OTT).
Thanks for your help guys.
Old Aug 2, 2004 | 06:39 PM
BIU's Avatar
BIU
im abit confused..... so do you have the Magnaflow RX-8 catback or just the tips?
Old Aug 2, 2004 | 07:26 PM
Me? I just have tips. I didn't want any more noise and I don't need any more flow.
The stock exhaust is quite good once you get rid of the catalytic converter, which I did with Vivid Racing's BB midpipe.
It was just too buzzy, so I installed a resonator and these resonated 3.5" tips.
Now it sounds pretty good and I only spent $40 instead of $500+ on a cat-back.
Old Aug 2, 2004 | 09:19 PM
rx8cited's Avatar
Senior Member
Originally Posted by MazdaManiac
The stock exhaust is quite good once you get rid of the catalytic converter, which I did with Vivid Racing's BB midpipe. ....
Hi Jeff, How do you get thru the local required emissions test?
Anyone know what size the Racing Beat tips are?
rx8cited
Old Aug 2, 2004 | 09:30 PM
rx8cited
I pass by showing up.
All they do now in Maryland is hook up to the OBD port and look for a code.
No treadmill and no sniffer on cars built after 1996.
Since I have no codes, I have no emissions issue. I won't have to worry about it for 3 years, anyway.
They do look under the car with a mirror and check for an OEM gas cap, but I have a heatshield for the midpipe that looks like a cat just for that reason.
I have the exact same arrangement for my Miata which passed emissions easily in April.
The RacingBeat cat-back has 4" tips.
Old Aug 2, 2004 | 09:54 PM
rx8cited's Avatar
Senior Member
They do look under the car with a mirror and check for an OEM gas cap, but I have a heatshield for the midpipe that looks like a cat just for that reason. .....
Slick If they did the treadmill test, do you think it would pass?
Do you have to hand your Miata keys over to the kids doing the test? My friend who has a Corvette says he never gives them the keys, he sits in the car and does the driving on the treadmill during the test.
rx8cited
Old Aug 2, 2004 | 10:02 PM
cgrx's Avatar
DRIVEN
Borla tips are perfect IMHO
Attached Thumbnails 4" exhaust tips-111_1143.jpg   4" exhaust tips-111_1144.jpg
Old Aug 3, 2004 | 03:33 AM
tokenbrit's Avatar
6Spd Blue 230
I just have the Magnaflow 4" double walled stainless tips. As far as I'm concerned, there's nothing wrong with the standard muffler as it's got pretty good flow, and I have a C.Z. Mid-Pipe + Cat on order for my hp increase.
I'll post some pics when I'm done... :D
Old Aug 3, 2004 | 10:17 AM
That is because they are 3.5":D
Yes. I had it "sniffed" after-hours when I first installed the midpipe.
rx8cited
They wanted to, but I refused. They started to say something about safety regulations, but then I pointed out that the guy in the adjacent lane was doing it. Of course, all I had to do was pull the car up. They plugged in the OBD-II connector and hit the space bar on their PC.
The car was just idling for that.
Old Aug 3, 2004 | 10:36 AM
Japan8's Avatar
Int'l Man of Mystery
Those are some nice tips... where did you get them from Jeff?
Man... that car is sharp from every angle!
Old Aug 3, 2004 | 10:44 AM
They are stainless, resonated, rolled-tip pieces I got from Pep Boys. $20 each.
I think they are "3A Racing", but I'm not sure.
Old Aug 3, 2004 | 03:31 PM
Redlinin 8's Avatar
can you get us a sound clip pleasee
Old Aug 4, 2004 | 10:34 AM
romulus's Avatar
MazdaManiac,
Since you are using the stock exhaust, how did you removed the stock tips. Did you have a muffler shop remove the stock and install the aftermaket ones? How long are those tips?
thanks.
Old Aug 4, 2004 | 12:04 PM
I just pulled off the plastic surround pieces (the ones that the exhaust finishers are attached to) and cut the factory tips off with a air-powered cutoff tool.
Then, I welded the new tips in place.
Old Aug 4, 2004 | 02:46 PM
romulus's Avatar
MazdaManiac,
Thanks for the info.
Old Aug 5, 2004 | 03:07 AM
Mikelikes2drive's Avatar
perfect size exhausts are the racingbeats IMO
Old Aug 5, 2004 | 03:15 AM
Also 3.5"
Old Aug 5, 2004 | 05:39 AM
rx8cited's Avatar
Senior Member
Also 3.5"
What are ya' talking about? The tips are 4".
rx8cited
Old Aug 5, 2004 | 11:44 AM
rx8cited
Oops. Sorry, that's right - 4" stainless 304.
Maybe I was thinking "Tiger Beat"?:D
Old Aug 10, 2004 | 06:53 AM
Kochan's Avatar
Mine is the biggest :D Maybe over 4". Not so bad, because it is slightly shaped, not just a big pipe!
Attached Thumbnails 4" exhaust tips-img_0901.jpg   4" exhaust tips-img_0916.jpg
JimmyBlack
273
Feb 10, 2020 10:23 PM
arexatemate
Oct 28, 2019 08:16 AM
mdl0209
May 23, 2019 05:46 PM
fc2se
NE For Sale/Wanted
Jun 1, 2016 08:55 PM
