Hartmut
07-29-2004, 05:39 AM
Hi experts in electronics
I am new here and so far I do not own a sports car powered by a Wankel engine.
But when recalling the rides I had in my father `s NSU Ro 80 I sometimes dream of having a modern Wankel in my 700 kg- Lotus Elise.
This engine should deliver at least 300 HP instead of the scarce 230 HP the actual Renesis is able to make and it should not weight more- better less - than this actually does.
Mazda `s new Wankel for fulfilling these wishes certainly will need a booster and this will require some remapping or in case it cannot be decoded for doing so another ECU will be needed. (Perhaps a Motec?)
But there are still some other companies busy in developing modern Wankel engines.E.g in Germany we have the guys from http://www.wankel-rotary.com[/url] and there are some rumours that Daimler Chrysler is busy in developing even an Diesel –Wankel - engine, too. Using common rail technology together with piezoelectric injectors
(See: http://www.sae.org/automag/techbriefs/05-2003 )
plus a good turbocharger made in Japan or by Borg Warner here in Germany, the chances to achieve an engine which consumes less than 290 g of fuel per kWh @ full power are not that unrealistic; and for sure the weight of such 300 HP engine can and should be less than the 275 lbs the Renesis still has.
( Remember that in Europe fuel prices are ca. 1,2 Euro per litre now ! --And that war in Iraq did not help to reduce it. Also in your country it ´s increasing more and more---)
Questions :
Who makes the actual ECU for the Renesis and which input goes into it?
Is there an air mass sensor like I have in my Miata ? ( Bosch / Denso system )
And the other main point: How does the knock sensoring , anti pinking system work?
Somebody told me that already in the latest RX 7 Mazda used the Ion Sensing Method
(See: http://www.vehicular.isy.liu.se/~larer/ISIS/Doc/NieEri_1998_CSM.pdf and
http://www.adrenalineresearch.com )
for controlling also their Wankel engine but I doubt this, tough I discovered that also Bosch, not only Saab, has been active in this field.
I hope to find some response in this forum because I saw that there are some posters writing more knowledgably and in better English than me.
Cheers Hartmut
Questions :
Cheers Hartmut
