underdrive?
Old Jul 27, 2004 | 08:19 PM
rx8_250f's Avatar
underdrive?
Can anyone tell me what "underdrive" pullies are and what is bad about it? and are all of the sold lightened pully sets underdrive?
Old Jul 27, 2004 | 08:52 PM
StealthTL's Avatar
Metatron
Underdrive......
If you put 'underdrive' pulleys on, the accessories (alternator, a/c, water pump) will turn slower, robbing less power from the wheels and making quite a difference at high revs.
HOWEVER, the alternator will be real slow at idle, lights may flicker at a stop sign.
The a/c is only marginal at full speed, if you slow it down anymore.......
The water pump is kind of important, if you slow it down, you will PROBABLY be o.k., you just won't be circulating the amount of coolant Madza intended, but if you ever have a warranty claim that involves any kind of overheat situation, you are toast.
So for a couple of peak horsepower, you have voided the warranty on the aircon, the engine, and anything electrical.
But they come in some really nice colors....
S
Old Jul 27, 2004 | 09:09 PM
Omicron's Avatar
I agree with Stealth, except that it needs to be pointed out that not all underdrive pulley sets cause problems. A well designed set that only underdrives a small amount (say, 20% or less) will probably be fine.
Old Feb 28, 2009 | 03:12 PM
04-Rx8's Avatar
Would just a underdrive pulley have problems? Not wonting to change alt, and water pump at this time.
Old Feb 28, 2009 | 03:17 PM
x8tuner44's Avatar
How about same size pulleys, but just lighter. Would that make a difference?
Old Feb 28, 2009 | 06:52 PM
staticlag's Avatar
The Professor
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/new-rx8-owner-faq-1-25-09-a-163824/
Old Feb 28, 2009 | 07:13 PM
x8tuner44's Avatar
thanks that helped.
Old Mar 1, 2009 | 06:33 PM
We ran a test and my AC was a consistent 2 to 4 degrees cooler than the RX 8 with an under drive pully.
Old Mar 1, 2009 | 06:34 PM
x8tuner44's Avatar
Shouldnt it be the opossite.
Luckycat
Feb 18, 2009 07:36 AM
tiltmode43
39
Dec 20, 2006 06:55 PM
Jaguar_MBA
Nov 16, 2004 12:44 PM
Relentless
Sep 26, 2004 03:20 PM
