To all the people installing or thinking about underdrive pullies
Old Jul 26, 2004 | 11:10 PM
cretinx's Avatar
I hope you guys understand what those crank pullies do . . . .
the crank pulley removes the harmonic balancer. Your driveshaft is now vibrating like a lunatic and just waiting to get all messed up. I've seen more cars than I care to mention blow from an underdrive pulley.
Old Jul 26, 2004 | 11:12 PM
JERCS's Avatar
Awesome Member
Well... a lot of garages like them.
Old Jul 26, 2004 | 11:39 PM
Omicron's Avatar
Thread title edited.
cretinx - How about, if you're trying to say something helpful, that you do it without insulting people in the title of your thread? If you sound like you're trying to incite a flame war, people are less apt to listen to you. And people don't generally like to be called "morons" regardless of your point.
Old Jul 27, 2004 | 12:37 AM
Tamas's Avatar
Registered Lunatic
cretinx - you sure have a funny nick... did you mean "cretin-x"? :D
Old Jul 27, 2004 | 01:06 AM
rotarygod's Avatar
Since I'm not a moron I realize that a rotary doesn't have a harmonic balancer. There isn't much worry about. We have 2 rotors and 2 counterweights. That's it. The front counterweight is underneath the front cover where you can't get to it. I've run underdrive pulleys on my RX-7's for years. No problems.
Old Jul 27, 2004 | 01:09 AM
JERCS's Avatar
Awesome Member
oh wait.... who is a moron?
Thanks RG
Old Jul 27, 2004 | 02:06 AM
robertdot's Avatar
Well, his avatar is an eclipse... Can't expect him to know everything about a rotary engine.
Old Jul 27, 2004 | 07:59 AM
XeRo's Avatar
Normality is Obscene
you've been PUNK'D! Now go back to the Eclipse forum...
Old Jul 27, 2004 | 01:16 PM
Red Devil's Avatar
Also have ran underdrive pullies in the past, they worked perfectly fine.
Old Jul 27, 2004 | 06:09 PM
ScudRunner's Avatar
On time, on target
what I wanna know is how many cars do you have to see blown before you don't care to mention it anymore?
Old Jul 28, 2004 | 11:54 AM
JERCS's Avatar
Awesome Member
i haven't seen any 8s with blown engines, come to think of it, i haven't seen any 8 with a blown engine. Nor heard of one.
Old Jul 28, 2004 | 12:32 PM
Charles R. Hill's Avatar
Owner of BHR
I have had my SR underdrive pulleys for months now and there are no problems. Quieter operation and better appearance. As far as measureable gains, who knows? Physics tells me there are some gains but that deoesn't mean my meager human senses can detect them.
Charles
Old Jul 28, 2004 | 02:09 PM
ScudRunner's Avatar
On time, on target
physics...she can be a tricky mistress...
Old Jul 28, 2004 | 03:45 PM
bgreene's Avatar
Time of your life, kid...
Hey RG,
Are there any worries about underdriving the water pump on a rotary? I could see UD on the alternator being no problem (assuming you're not also trying to run a monster bass box or other excessive electronics), but it seems like you'd still want all the cooling you can get, depending on your local climate.
Old Jul 28, 2004 | 03:58 PM
bureau13's Avatar
I'm not RG, but...
I've always heard that underdriving the water pump can actually improve performance by reducing cavitation during high-rpm driving. My assumption is that the stock drive is optimized for street driving, and a different drive might be ideal for track driving. Now, how much difference it makes REALLY, or any possible negative impact on a street-driven car that has this modification...that I don't know.
jds
Old Jul 28, 2004 | 04:30 PM
rotarygod's Avatar
jds
True. On the older RX-7's, the water pump started to cavitate at about 6500 rpm. THe RX-7 may not rev as high as the Renesis engines but I get higher than that. With an underdrive pulley, the cavitation point was taken up to about 8000 rpm or so. Unfortunately I don't know where the Renesis water pump starts to cavitate at. I do know that I never had any adverse affects using them on a street car though so you should probably be just fine using one.
Old Jul 28, 2004 | 05:02 PM
VividRacing.com's Avatar
Also, it's not a harmonic balancer, it's a harmonic damper. There is no balancing of the crank pully on the stock system. The damper's job is to minimize the amount of engine knock noise and that's it. I've seen separate tests done with and with out the harmonic damper. The tests were done with one of those fancy gizmo's that translates audible noise into a visual wave on a screen. In stock configuration the harmonic damper disapates the amount of noise from combution almost imediatly. W/O the damper unit the noise wave lasts for just a bit longer than a half second. My point is that the harmonic damper isn't a nessessary item and can be removed for performance.
Now under driven pullies in general are usually a hot topic for discussion and everyone will give you a different story about how it blew up someones engine or that it worked just fine. Personally, I prefer a lightened pully as instead of an under driven pully but hey, that's why we are all mature adults able to make our own desisions and purchaces. Do your research and get what you think is best for you and your project.
jay_tibo
22
Sep 13, 2016 08:10 PM
WingleBeast
22
May 23, 2016 09:22 PM
J2daG1990
Series II Wheels, Tires, Brakes & Suspension
Sep 24, 2015 09:20 AM
MolecularConcept
Aug 5, 2015 04:43 PM
iSki123
Jul 27, 2015 12:41 PM
